Waxing Your New FIT, questions,techniques,products
Old Sep 14, 2006 | 04:28 PM
  #141
onebyone1958's Avatar
Best easy to use wax for the Fit ?
As some of you have more time to take outstanding care of your Fits I need some advice. I am looking for the best and easiest to use wax for my Fit.
Any suggestions ?
Old Sep 14, 2006 | 05:10 PM
  #142
milano sol's Avatar
i like the Meguairs NXT Spray Wax (wal-mart for under 10.00 and comes with applicator...but i like using my microfiber towels).
its quick, easy and painless. theres also the traditional paste wax and liquid wax which are usually thicker and more time consuming. but as you would expect give a better result and last longer.
Old Sep 15, 2006 | 02:18 PM
  #143
Originally Posted by accordselux
Personally on a daily driven car I use collinite wax. It will actually last quite long. I wouldnt recommend waxing it only once a year, but if you put two coats of 476s on your car before winter it should last through until spring. It's a pretty rock solid wax for a daily driver. Mothers and Meguiar's and such seldom last more than a month. But honestly don't expect a 'once a year' wax to last more than 4 or 5 months, but in general they last longer than normal waxes.
Where you able to find Collinite wax locally or did you have to order it (there are no distributors in my area) ?
Thanks !
Old Sep 15, 2006 | 02:24 PM
  #144
carlosalicea's Avatar
FORMULA 1 and Meguairs quik detailing spray, tho my tafeta has about 3 weeks dirty.
Old Sep 16, 2006 | 11:48 PM
  #145
davej147's Avatar
Thanks for the tip!
Originally Posted by 743power
There are alot of great waxes available today to fit any price range. One that I love is p21s/s100.
I stopped by the local Harley dealer this morning and picked up a tub of s100 for my new Silver Storm. It was easy to apply...easy to buff out...and my car looks great! At $16, it cost half of what I found on-line (just as you said!) - and the salesperson couldn't have been nicer. The Harley dealer had some sort of bike show going on...the place was packed, and there must have been a couple hundred Harleys lined up outside the showroom. I had visions of accidently knocking the end bike over, setting them off like a line of dominos (reminiscent of Pee Wee). Thankfully, that didn't happen.
Old Sep 17, 2006 | 06:30 PM
  #146
FondaFit's Avatar
Waxing your Fit
Originally Posted by Lilbigwheelz
Ok now, this is way tooooo much info.
Can not compute Will Robinson(lol)
Will someone kindly tell me which wax is best for my BOA.
Thanks much
LBW
Have a great weekend!
We've been back and forth before on which brand is best. There are a lot of people on the Forum who are way ahead of me and much more knowledgeable about cars, but I think that as long as you use a good quality wax and take good care of your car, you'll do fine. I started using Meguiar's about 10 years ago because a friend who reconditions Jaguars swore it was the best. When my Accord finally started having major mechanical problems after 11 years and 280,000 miles, I sold it. The body and paint still looked perfect. Water beads on it, and for me that helps me know that there's still a good coat of wax on the car and that I didn't miss a spot. I hope to keep my Fit 10 years or 300,000 miles, whichever comes first -- unless a new generation Fit comes along that I can't live without.
Old Sep 17, 2006 | 07:00 PM
  #147
Thanks !
FYI - I bought it on Amazon !
Old Sep 19, 2006 | 02:29 PM
  #148
mrsdrdirt's Avatar
Question Is Simonix worth it?
Someone posted this question already, but didn't get an answer so I thought I'd repost.. does anyone have experience with the Simonix teflon paint protection system? It's expensive but if it works, great...any feedback? Thanks!
Old Sep 21, 2006 | 01:02 PM
  #149
Originally Posted by 29FSE
What is a "BOA"? And it really depends on what you want. Do you want to spend more time waxing? How often do you want to wax? How do you want your car to look (very shiner or deep lustered shine)? In what condition do you drive? Do you need a lot of protection? How often do you drive your car?
Answer all these questions and I'll suggest something.
I wouldn't recommend Collinite products since they contain some petroleum based solvent. Although, it is minuscule, overtime a car's clearcoating might disappear and the paint coat might get damaged. Water based waxes are the best.
Thank you very much for the tip. I am sending back the Collinite back and just purchased P21S wax along with some microfiber towels.
Old Sep 21, 2006 | 03:07 PM
  #150
FondaFit's Avatar
Getting bugs off
clay with lube is what I use, just have to rewax it every time as the clay will strip te old wax. There is sponges out there that get bugs off pretty easy without messing up the paint. Also, spraying a mild degreaser on the lower half of the car, and the front bumper grill area will make the bugs dissolve while you wash, but you will also have to wax those areas.
Griots garage makes a spray on bug remover/repeller. I am going to try it when my car comes in.
I'm not a detailer, so I've been using trial and error to find something that gets bugs off -- and none are bigger, gooier and stickier than Florida bugs hitting the car at highway speeds. Ever have to deal with love bugs? Meguiars Detail spray takes them off nicely, even off the bumper, where they tend to cement themselves on. I'm not sure if the wax is coming off, too, so I wax every other wash (wash weekly). I've tried a couple of products made specifically for bug removal, and they didn't work well -- too much elbow grease required.
Old Sep 21, 2006 | 03:23 PM
  #151
That is completely true! I didn't even like washing cars, but I am like a paranoid with the front end because once you let those bugs there, they will become part of the Fit's body. I use Meguiar's detali spray with a microfiber cloth, and it takes them off, the only thing! So you can sometimes through the week see my taffeta dirty, but with a shiny new front end
By the way I use Formula 1 carnauva wax, and don'tknow if is even good, but makes a hell of a job. Maybe will try some spray wax to use it more often.
Old Sep 21, 2006 | 03:37 PM
  #152
gimme's Avatar
Master FitFreaker
eagle 1 nano FTW! well, in the case of black cars
Old Sep 21, 2006 | 09:53 PM
  #153
I don't have any experience with this however I had a product like that applied to a new car - it looked good for about 6 months but it really lost it's luster. The place wanted me to pay them to get the car properly cleaned before they re-applied it. I bypassed this and waxed the car myself. My suggestion is to check out the "wax" thread here of FitFreak.net - it covers everything from the easy to use to what the pro's use. If you want to have someone do it check out the good detail shops that use the better products - make sure you ask what they use before you get it done.
Old Sep 23, 2006 | 01:08 PM
  #154
mrsdrdirt's Avatar
Hi Onebyone1958, thanks for the suggestion. something that sounds too good to be true, like Simonix, probably is, I guess!
Old Sep 26, 2006 | 07:17 PM
  #155
Ordered the following from "Auto Geek" through Amazon:
P21S Carnauba Wax
Pinnacle Foam Wax Applicator Pkg. of 3
Cobra Microfiber Towel Combo Kit
I will be waxing her on Saturday and will take pics and post afterwards ! I am so excited !
Old Sep 26, 2006 | 07:22 PM
  #156
joe d's Avatar
I have it on mine. Not because I wanted it, but because it was already applied, it was April 17th, and I knew if I didn't buy the one on the lot I'd have a long wait ahead of me.
I wax it anyway because I'm neurotic... clay, layer of synthetic, layer of carnuba. I've seen some other SSMs and mine definitely looks more way "crisp" with a much deeper shine. But, I'm not sure whether it's due to the Simoniz treatment or because I'm a freak about keeping it nice.
Old Oct 18, 2006 | 06:54 AM
  #157
AdvonSpaanDC5's Avatar
I would use Klasse AIO then followed by P21S. I wouldn't need to wax it for at least 3-6months (on my dc5 and z33). the unusually thing is that even after i AIO'd and P21S'd it, it still doesn't look much different because the paint is kept in very good condition over time anyway. So can i say durability? o yeahhh...
also, p21s is so easy to apply it's ridiculous. cuts down a lot of time for you busy folks out there. the only catch to this great product is the cost. but hey, pay the cost to be the boss, and nothing less than great goes on my cars.
Old Oct 22, 2006 | 08:42 PM
  #158
Talon's Avatar
Ok I"m just weird.. I use the car wash spray on once a month, and rain-x the rest of the car the rest of the time..
Old Nov 2, 2006 | 12:46 PM
  #159
lasersailor's Avatar
Zaino
Originally Posted by simons2k
Anyone here tried Zaino products? My brother swears by them.
I'll post my experiences in 2-3 weeks. I'm picking up my NBP 5MT around the 14th. I have ordered a Zaino Total Protection Show Car Kit based on the strong endorsement and positive experiences of a friend that has an Astro Black MINI Cooper S.
Old Nov 2, 2006 | 10:14 PM
  #160
zaino products are very good. they claim it's very durable. the only thing is that it IS very durable to protect your paint, but overtime as with any other product, the car will start to not look as good without maintainence of some sort. most people will zaino every 6 months and it will look fantastic if done right. mostly it's the process and not the product.
