KraftWerks Supercharger Kit Thread 2.0!
Old Mar 7, 2008 | 03:10 PM
  #101
SickFit's Avatar
WOAh WOAH WOAH!
That was such a cheesy Woah woah woah.
Old Mar 7, 2008 | 03:38 PM
  #102
ldweng's Avatar
Originally Posted by KraftWerks
You will get a Check Engine Light with an injector 20% larger than stock on a stock ECU. That's just how it is. You cannot run a 240cc or 310cc on a completely stock ECU, unless you use a type of piggyback that will change what the ECU sees. Remember, the ECU NEVER sees the SuperCard.
Also, you will not have crisp start-up with injectors above 20% on a completely stock ECU.
So no, you will not be able to maintain stock drivability with that large of injector.
So folks, that is why we chose the 205cc. It fits perfectly with the parameters we wanted... A simple bolt-on upgrade, that could work the stock ECU and support our Header/Testpipe customer.
-OJR
Thanks Oscar, I have a lot better handle now on the design decisions that you made.
Old Mar 7, 2008 | 09:28 PM
  #103
Illusive's Avatar
Still need a price on that injector upgrade!!!
Old Mar 7, 2008 | 11:33 PM
  #104
xorbe's Avatar
froogle.google says $45-$75 for 205cc injectors. particularly, rc engineering comes up at $68/$71.
Old Mar 8, 2008 | 12:15 AM
  #105
Mr_ET's Avatar
75$ fpr 4 injectors? You're dreaming if you think the package will be that cheap.
It will probably be around 200-275 plus shipping.
Old Mar 8, 2008 | 12:58 AM
  #106
leonine's Avatar
don'f forget the upgrade also includes injector clips and most importantly a revised supercard chip.
i am guessing 350.
Old Mar 8, 2008 | 10:39 AM
  #107
smirff07's Avatar
compatability question
first off, i love kraftwerks, the quality and reliability of their products is top notch, some friends of mine have used your s/c.
will this base kit work with the ingalls engine torque damper?
Old Mar 8, 2008 | 10:57 AM
  #108
REXXXXXXXXX's Avatar
Frequent FitFreak Poster
Ive asked this question a few times as well. I just want to know so if need be, I can take it off now and sell it instead of having to do it the day of the install... thanks...
edit: btw leo ur mani cover looks sick! sry 4 off-topic...
Old Mar 8, 2008 | 02:31 PM
  #109
xorbe's Avatar
per injector! it clearly said that on the page i pulled up.
Old Mar 8, 2008 | 04:27 PM
  #110
leonine's Avatar
Thread hijack - sorry!
Thanks bro. The pick next to it is what is going in the center of the seibon oem hood surrounded by flames similar to the manifold cover
I'll be very busy in 2-3 weeks.
Old Mar 8, 2008 | 05:47 PM
  #111
Illusive's Avatar
RAWR!!!
Back on topic...DAMMIT another couple bills down the drain!!! Oh well, it'll be worth it...
Old Mar 9, 2008 | 11:25 AM
  #112
Midnightfit's Avatar
OK, i have a few question for Kraftwerks first on the base kit or high boost do you need to run a colder range spark plug
Next, should i be able to run water-meth injection with your kit
third, since the supercard doesn't piggy-back the ecu, can i run a afc neo with the supercard or hondata reflash to fine tune, and lean the engine out to gain power
also, i would really like to know what all hondata changes in their reflash
Old Mar 9, 2008 | 09:59 PM
  #113
FitSport2007_5spd's Avatar
x2 for question regarding spark plug recommendations for the base kit with injectors!
Old Mar 9, 2008 | 10:30 PM
  #114
Illusive's Avatar
Kraftwerks USA
Old Mar 9, 2008 | 11:02 PM
  #115
Thanks Justin.
Which plugs and thermostat are folks contemplating for the S/C?
Old Mar 9, 2008 | 11:06 PM
  #116
Illusive's Avatar
Thanks Justin.
Hmmmm I'm curious as well...always thought of NGK or Bosch...then again I don't usually go shopping for spark plugs haha. What is the temp and what would be considered one cooler?!?!
Old Mar 10, 2008 | 12:27 AM
  #117
claymore's Avatar
Jeeze there is a giant thread just on this subject must have been before your time. Here is the one step colder NGK if you want some other brand just use this number in the conversion charts and NO there is no stock Iridium plug one step colder, there may be some other Iridium available but the ones that come in the car doesn't have a one step colder equivalent.
Old Mar 10, 2008 | 10:42 AM
  #118
claymore's Avatar
Any Civic thermostat will work. Get a buddy or friendly parts guy to browse through their thermostat book and pick out a 160 degree "F" one and save big bucks rather than buy a "Name" one for like $70.00.
Not 100% sure on the fan switch but again MAYBE they all FIT as you can see in the photo it's also marked EK-9 so possibly all civic ones again may FIT the USDM FIT.
These are the Spoon 160 degree ones installed in my Jazz and they work in the USDM also but are expensive at $70.00 EACH. They have been installed for two years with no problems.
But they don't reduce the temperature to 160 on the button. We have normal weather at about 85 F every day and the best I get is 180 degrees operating temperature at 85 ambient temperature. If it gets down to 60 degrees then the operating temperature drops to 165-170 depending on how hard it's pushed but it's still better than the normal operating temperature of 210 -215 degrees.
Old Mar 10, 2008 | 11:16 AM
  #119
Illusive's Avatar
So reading up on NGK's spark plug information and tech stuff, they state:
"Another consideration that should be taken into account is the extent of any modifications that you may have made to the engine. As an example, when you raise compression or add forced induction (a turbo system, nitrous or supercharger kit) you must reduce the gap (about .004" for every 50 hp you add). However, when you add a high power ignition system (such as those offered by MSD, Crane, Nology) you can open the gap from .002-.005"."
So for a SC or TC application such as the KW SC, you'd need to reduce the gap by 0.004" or 0.1016mm. The last number in the spark plug is the gap, and stock replacements in a USDM Fit is 13 or 1.3mm. Therefore, we need to reduce by ~0.1mm, so we should be aiming for something with an 11 or 12.
Old Mar 10, 2008 | 11:49 AM
  #120
JDMchris.com's Avatar
I run THIS
BTW... NONE of these mods ARE NEEDED on the Fit... but you can always do them
