KraftWerks Supercharger Kit Thread 2.0!
Old Mar 18, 2008 | 04:42 PM
  #221
leonine's Avatar
Originally Posted by 08XR
When is the release date? I see a ton of data but no date? As I am anxious to get some more ponies out of Fit. But yet I also see the Doug Thorley s/c kit that is available now.
where did you find this info? please post a direct link. i saw no information on the KW site like someone else mentioned.
Old Mar 18, 2008 | 04:46 PM
  #222
Illusive's Avatar
What were you looking for?
Old Mar 18, 2008 | 05:16 PM
  #223
GAFIT's Avatar
Maybe time for a clean up and Version 3.0?
Old Mar 18, 2008 | 05:18 PM
  #224
Illusive's Avatar
ROFLMAO! I think it'll be fine in 2.0 status...maybe KW needs a Consolidated information thread that is locked from general posts
Old Mar 18, 2008 | 06:28 PM
  #225
OJRKraftWerks's Avatar
Former Vendor
Well I guess my questioned was avoided, but again, is there a release date?
We will be announcing our firm release date very soon.
Unfortunately, some delays are unavoidable. We are making sure this kit is stone reliable for the Fit market. We have no development worries; the kit is perfect. We must make sure that these new kits has the ability to upgrade to High-Boost easily, and we are testing that process now. Once this final procedure is complete, we can release the Fit kit to the Fit community. That release will be followed instantly by Automatic, and then a High-Boost kit.
We are pretty thorough, and have been testing hard in the last year. There have been so many changes made. For example:
-The SuperCard electronics are built by us and tested to ensure that the chip tuning for the kit is correct. It is through our testing we discovered it is unsafe to add a header to the system without adding larger injectors than stock... even at 5 PSI. Revised mapping with better fuel delivery throughout the power band has been added to the new kit and we are able to further improve the kit with the new injector pack chip.
-We have changed the supercharger positioning in the engine compartment to optimize the belt life, belt clearance, and create an area to put an automatic belt tensioner.
If you hit a bad pothole with our old design, the axle will hit the supercharger and belt causing failures. That is not at all the case with our new kit.
-We tested intake pipe lengths to create a flatter, more consistent torque curve. We realized we needed to change things around to help the supercharger breathe better at low speeds AND high speeds. So you see the new intake piping. Also, we run away from the header as much as possible to avoid pipe heat soak now.
All these changes were done in the past year of development. As you can see, our new kit is much improved from last year and I am glad we held off the release to continue our development. I am sure the Fit community can understand the delays to ensure quality. We put our heart and souls into each kit, whether its a Fit or S2000.
So now after all of our hard work, the release is around the corner! I look forward to hearing the reviews by FitFreak, as I am sure you guys will not be disappointed.
-OJR
Old Mar 18, 2008 | 06:30 PM
  #226
Illusive's Avatar
OMGOMGOMGOMGOMG!!! It's so close I can SMELL it!
Old Mar 18, 2008 | 06:37 PM
  #227
TOOL's Avatar
Are you getting it Illusive?
Tyler
Old Mar 18, 2008 | 06:39 PM
  #228
Illusive's Avatar
LOL dood, you gotta keep up with the Jones' on this one I've got my pre-order in already...for a few weeks now
My sig gives it away haha...shhhhh!
Old Mar 18, 2008 | 06:41 PM
  #229
GAFIT's Avatar
Will there be a pre-order discount for the high boost kit? BTW, thanks for all the great info!
Old Mar 18, 2008 | 06:44 PM
  #230
FaceYogurt's Avatar
Exclamation
There has been reports of harassment. Please note that our Forum Rules are short and simple.
Forum Rules: https://www.fitfreak.net/forums/fit-...rum-rules.html
Permanent IP bans will be put in place once we review system logs, posts and user IP addresses.
Old Mar 18, 2008 | 06:48 PM
  #231
leonine's Avatar
-OJR
I am sure i will not be disappointed either. i have been eagerly anticipating the release since day 1. i am sooo psyched that it is almost here. Thanks again Oscar for all your hard work and support.
Old Mar 18, 2008 | 09:33 PM
  #232
jman245's Avatar
Keep your catalytic converter, and save the world!
-OJR
good to hear since thats my plan!
Old Mar 18, 2008 | 09:39 PM
  #233
jman245's Avatar
btw,is there a ballpark price for the 10lb kit?
Old Mar 19, 2008 | 12:16 PM
  #234
ldweng's Avatar
Oscar,
Any update on the injector kit? Will it be available by the time the supercharger kits are to ship? I really don't want to put the original header back on unless there will be a long wait. I still have the scar on my arm from the last time.
Old Mar 19, 2008 | 12:17 PM
  #235
Illusive's Avatar
Originally Posted by ldweng
Oscar,
I believe that the injector upgrade will be available for purchase when the kits are ready to ship. Still waiting on that price though!
Old Mar 19, 2008 | 06:29 PM
  #236
ldweng's Avatar
The 144whp graph on our website is with a header, cat delete, and 50mm cat-back exhaust. I don't know how much of an increase you will see with 60mm, but it would not hurt your system.
The catalytic converter has some restriction, and you might see a small decrease. But I wouldn't fret over it. We only saw 2whp and 4wtq with a cat -delete on our 364whp S2000 kit. Keep your catalytic converter, and save the world!
-OJR
OJR or JDMChris,
I was trying to decide which mid-pipe to buy. You said that the 144 whp dyno was with a 50 mm mid-pipe (cat-back exhaust.) I found on the older thread that JDMChris had a Megan mid pipe. Was this dyno on another car, or did Megan used to make a 50 mm mid-pipe. The recent Megan info says 2.25"?
Old Mar 19, 2008 | 06:43 PM
  #237
JDMchris.com's Avatar
I run THIS
its the same mid pipe
Old Mar 19, 2008 | 07:22 PM
  #238
gloryhound's Avatar
have i missed the posting of the price for the 5lb kit with injector upgrade? BTW is there any problem running this kit with the upgraded injectors on oem headers/exhaust until i get new headers?
another question, are upgraded injectors emission legal?
*btw all this bickering back and forth over sc kits soured me... but i can't help myself i really do want this
Old Mar 19, 2008 | 08:06 PM
  #239
Illusive's Avatar
No injector upgrade price yet, just the base kit with 10% discount if you pre-order. I can't see it having any problems with upgraded injectors with OEM headers. Better to let KW answer though.
Old Mar 19, 2008 | 08:23 PM
  #240
ldweng's Avatar
So it's 57mm rather than 50mm.
