KraftWerks Supercharger Kit Thread 2.0!
Old Mar 10, 2008 | 12:12 PM
  #121
Illusive's Avatar
hmmmm if it isn't needed would new spark plugs reduce too much heat and cause problems? Did you swap your spark plugs JDMchris?
Old Mar 10, 2008 | 12:39 PM
  #122
JDMchris.com's Avatar
I run THIS
I dont think it would cause any problems, Oscar stated in the pre consolidated (dont know if it was kept for this one) That these are NOT needed. I have OEM plugs.
Old Mar 10, 2008 | 12:45 PM
  #123
claymore's Avatar
The 13 is for IRIDIUM plugs only, for regular plugs it's 11 with a smaller gap. And as I said there is no colder replacement for IRIDIUM plugs.
Replacing your stock plugs with one step colder will cause no problems. I run them in my car with no SC and minor mods and they work just fine.
The only way you may cause problems is if you drive like a little old lady grannie and the only problem would be that they load up a bit and that is easily corrected by a blast on the highway to "CLEAN THEM OUT".
Old Mar 10, 2008 | 01:08 PM
  #124
OJRKraftWerks's Avatar
Former Vendor
Remember, the website services all of our supercharger kits, not just the Honda Fit kit.
Plugs and thermostat are not needed, especially at 5 PSI.
If you feel the need to change your plugs at only 5 PSI, one step colder with standard gap will be fine. We run stock plugs on all of our cars during testing to ensure proper operation of our kit on completely stock engines. We have run the Fit kit with stock plugs to over 10 PSI, without a hiccup.
If you are preparing for heavy track abuse and/or a hot summer, you should consider the cooler thermostat. If you are in Canada, you do NOT want that cold thermostat in the winter. Your engine will finally warm up, just as you arrive at work.
Remember, this is a bolt-on kit. NO ADDITIONAL PIECES REQUIRED OR NEEDED. We have track tested and abused our kit with a stock thermostat and stock plugs, and never had any issues.
It is great to hear everyone enthusiastic to take care of their vehicles, and put the proper pieces in for smooth operation. But I want to make it clear that this equipment is certainly not required.
-OJR
Old Mar 10, 2008 | 02:20 PM
  #125
REXXXXXXXXX's Avatar
Frequent FitFreak Poster
Okay so Sat. night, i was kind of, um... inebriated... and kind of forgot my appt to get my car dyno'd on Sun. , but as soon as i get in there, i'll make sure to post any/all info, and then as soon as my kit's installed, i'll post my after numbers too
And for the 734,652nd time (this question is asked at least once every 5 minutes), do we know when its shipping yet?
Old Mar 10, 2008 | 02:36 PM
  #126
Illusive's Avatar
LOL I think the response will be "End of March" Need to know how much that upgraded injector kit is going to run us too!!
Old Mar 10, 2008 | 02:38 PM
  #127
my gut says you're probably right
Old Mar 10, 2008 | 03:11 PM
  #128
Illusive's Avatar
LOL I don't wanna be right C'mon KW! We need a specific date and price ASAP!
Old Mar 11, 2008 | 12:40 PM
  #129
eldaino's Avatar
BTW... NONE of these mods ARE NEEDED on the Fit... but you can always do them
thanks chris, all this spark plug talk had me going for a bit.
ojr: kudos on the inclusion of the decals and license plate, that awesome, and i'm sure many folks will be representing!
Old Mar 11, 2008 | 12:43 PM
  #130
eldaino's Avatar
ah man this sucks! i was looking forward to the numbers!
Old Mar 11, 2008 | 12:44 PM
  #131
eldaino's Avatar
-OJR
how hot of a summer? nc doesn't get super hot, but the weather has been so weird the last couple of years, you never know. its usually because of all the humidity.
Old Mar 11, 2008 | 12:46 PM
  #132
I run THIS
I see triple didgets during the summer regularly. I was making trips in 110+heat with no problems.
Old Mar 11, 2008 | 12:57 PM
  #133
eldaino's Avatar
good to hear! but i'm also a native so.californian, and lemme tell you, 80 degree weather here in nc feels 10x worse than 80 degree weather in cali!
but 110 is another story...i think we've been up there, but not exactly one ten. its miserable. But i don't think our engine and this kit are so sensitive that this is going to affect them much. besides, i'm usually coasting, on the freeway, so it shouldn't be an issue.
Old Mar 11, 2008 | 02:36 PM
  #134
Illusive's Avatar
okokok, I know those plugs aren't needed, but will we see any gains with new spark plugs or will it just be there to prevent detonation? I definitely can't do the thermostat as advised by OJr. since I'm in Canada.
Old Mar 11, 2008 | 02:41 PM
  #135
Of what year?
sorry, i had to...
This is me ---->
How about u just send me the decals now so i look cool lol
Old Mar 12, 2008 | 04:09 PM
  #136
gotfitted's Avatar
what the...what happened to the posts??
Old Mar 12, 2008 | 04:19 PM
  #137
Illusive's Avatar
Let's stay on topic folks
So my big question is if colder plugs will help gain some extra hp or tq. Or is this simply to prevent detonation?
  #138
HeadButtUrNuts's Avatar
Yup yup? that would be nice...
Old Mar 12, 2008 | 05:26 PM
  #139
Former Vendor
You're not going to see any significant increase, if any, with the colder spark plugs at 5 PSI.
-OJR
Old Mar 12, 2008 | 05:57 PM
  #140
Illusive's Avatar
Cool, I'll pass on those cooler spark plugs, thanks OJr!
