HKS Turbo kit
Old Dec 26, 2008 | 01:08 PM
  #381
YeeFit's Avatar
Originally Posted by gd3kamiwanaB
well on just the base kit with an exhaust the first dyno number i layed down was 145 thats with no tuning or boost upping. i spent a few hundred bux on injectors and a boost controller and an HKS certified tuner got about 180 to the wheels. and BTW that 370z is a great car i recently saw one at the local auto show and was very impressed.
I think he was asking if you were CARB legal still... and if you installed a cat-delete or test pipe then you are no longer going to be CARB legal. Even still with bigger injectors and running that much more power with the cat still in I don't know if you would pass CARB.
Old Dec 26, 2008 | 04:14 PM
  #382
couragethedog's Avatar
thanks for the replies yeefit and gd3kamiswanab. So if I do get the base hks turbo kit, I can expect to see around 145 whp and still stay carb legal? I would be satisfied with that, as I am not a speed maniac but I would like to take it to the track one day and I hate having to downshift just to pass someone on the free way hehe.
Old Dec 26, 2008 | 07:05 PM
  #383
Shaggs2Dope's Avatar
Frequent FitFreak Poster
hopefully someone at honda reads all the forums and decides to make a fit Si, 160-200hp. That would be perfect with just a couple bolt ons. Whenever the economy gets outta the gutter I would love to do the HKS kit. This fit needs some balls
Old Dec 27, 2008 | 12:35 AM
  #384
Spooling's Avatar
Which electronic boost controller are you using? I'm thinking of raising the boost to 8.5psi or even higher.
Old Dec 27, 2008 | 12:42 AM
  #385
kylerwho's Avatar
spoon fed
what is the highest numbers someone is putting out with the hks kit? im still sorta on the fence between the hks and t1r kit. no hks certified tuner around here makes me lean toward the t1r kit though.
Old Dec 27, 2008 | 12:44 PM
  #386
YeeFit's Avatar
Both kits will be able to yield about 170-190whp with upgraded injectors, test pipe, and tuning. The limiting factor with both kits will be the stock fuel delivery system. I believe the stock fuel pump can only handle around 190-200whp max. If you build up the internals and upgrade the fuel system the turbo should be able to handle around 15psi safely which could get you around 220-250whp. But thats a big MAYBE since no one has done it and there are very few internals offered for the L15A at this time.
From what I know, if you do the right mods you will be able to get more out of the T1R kit only because it has an external wastegate. With the HKS kit you will be limited on the exhaust end of things since the wastegate is internal and the extra exhaust will go back into the system where the T1R kit goes straight out to the atmosphere. (this is the main reason why the T1R kit is considered "off road" use only). But I daily drive my fit.
Both kits use the same turbo, the only real differences is the engine management system and the wastegate type. Both EMS need tuning and a lot of it comes down to who does it and how good they are.
Not having a certified HKS tuner near by makes things difficult as only they can unlock and tune the F-Con IS. GReddy Emanage Ultimate is simple to tune and many more ppl know how to do it. The emanage comes with the software included so you can install it on your own laptop and do your own data analysis and tuning.
I pulled 170whp @ 13.6 AFR (I know its a tad lean) on a dynojet at 6psi with my kit. I'm gonna go talk to the shop I went to that screwed me over to get my dyno graphs to prove it in the next couple weeks. After I left that shop that screwed me over I uploaded a new map for 8.5 psi and I haven't found a place to go to get retuned and dyno'd. It feels a lot faster at 8.5psi... my guess is that I am in the 180-190whp range now.
Old Dec 27, 2008 | 05:50 PM
  #387
kylerwho's Avatar
spoon fed
are you still planning on running at 10psi?
thanks for the info yeefit.
Old Dec 27, 2008 | 06:28 PM
  #388
YeeFit's Avatar
Ya, I plan to get to 9-10 psi in the spring time... no point on going to that psi til I get a new clutch and motor mounts installed.
Old Dec 27, 2008 | 06:31 PM
  #389
kylerwho's Avatar
spoon fed
im planning on going t1r this spring. what should i plan on buying along with the turbo kit? thanks
Old Dec 27, 2008 | 08:26 PM
  #390
YeeFit's Avatar
1-step colder spark plugs is about all you really need. I have the NGK Iridium IX plugs. You'll want to change the oil to a synthetic oil (I'm using Redline 5w40), and if you plan to put in a water temp gauge then you'll want to pick up a jug of honda coolant.
I have added gauges (boost, oil temp, water temp, oil press, and a wideband AFR), added the T1R oil cooler kit, and changed out the BOV that came with the kit to an HKS SSQV.
Old Dec 27, 2008 | 08:48 PM
  #391
kylerwho's Avatar
spoon fed
im running the colder plugs and royal purple synthetic oil. i would want to stay in the safe so i plan on running boost, oil temp and pressure, and wideband afr gauges. im looking at getting the oil cooler but is that required? why would you want to run a differant blow off valve?
Old Dec 28, 2008 | 01:39 PM
  #392
YeeFit's Avatar
We're getting off topic a bit on this thread, I'll PM you the answers to your Qs
Old Dec 30, 2008 | 12:46 PM
  #393
gd3kamiwanaB's Avatar
Luvs Dah b00st!
well i have been running 10-11 psi for about 4 months now and still not one problem the fit motor can take it with the right tuning,
Old Dec 30, 2008 | 03:37 PM
  #394
eldaino's Avatar
200 engine producing hp would be cool, but do you realize how much the si would have to be putting out to justify the higher price point? we'd have to have like a 250hp si, which is ok with me, but i just can't see honda doing that.
160-170 sounds more in line with what would work.
Old Dec 30, 2008 | 07:19 PM
  #395
Spooling's Avatar
Does anyone know how to get the F-Con to display A/F ratio, etc?
also, what's the little button switch for?
Old Dec 30, 2008 | 08:01 PM
  #396
Nabisco's Avatar
Senior Member
Probably something better left alone. I don't know if it would be displaying AF ratios from the factory sensors.
I can't wait to stabilize financially and get dental work done because I'm so ordering this kit.
Old Jan 2, 2009 | 06:02 AM
  #397
200psGD3's Avatar
you have to get optional HKS A/F sensors in order to display A/F properly
the littel button switch is used to change 3 type of F-Con display menu(pages).
the first page is the picture above
Old Jul 28, 2009 | 09:07 PM
  #398
FitnessJay's Avatar
Bring this thread back to life!!!!
Bump cuz i wanna get one of these soon and i need to learn more about it!!!
Anybody have some input or new things that have been found with this kit?
Old Aug 18, 2009 | 01:01 PM
  #399
WSRPRED's Avatar
Its true. I know this thread has covered nearly everything (if not more) on the HKS kit, but we should bring it back to life so some of our new members don't have to read back 20 pages worth of posts...
So i got some questions to get us started
1)Overall PROS and CONS of the HKS turbo kit.
2)HKS turbo kit vs. T1R turbo kit
----Parts the T1R turbo kit comes complete with, that which the HKS turbo kit lacks. Vise-Versa.
----Side by Side Dyno Comparison Tests?
----Conclusion: Best Bang for your Buck?
3)Members' own personal pics of HKS/T1R kits installed.
Old Aug 18, 2009 | 01:08 PM
  #400
Luvs Dah b00st!
i wana turbo my fit one day
