Another KW AT kit- INSTALLED!
Old Dec 23, 2008 | 12:17 AM
  #101
R@ymun2's Avatar
If anyone could also post vids aside from the pics it would be awesome also...
Old Dec 23, 2008 | 11:44 AM
  #102
jsensk's Avatar
I've been needing to shoot some pics-- will try this weekend as the family will be out of town. But it looks just like everyone else. If you've seen it once you've pretty much seen it.
Vid-wise, I don't have a video camera but can borrow one. It's just 0-60 type stuff you guys want to see? I still don't really know how to do it in a quality manner, but will try. I was thinking a helmet-mounted cam would work. Is it not sufficient to just post 0-60 times? That's the same data ultimately. I'll tell you they are MUCH faster than NA AT for sure, but thr proofs in the pudding as they say.
I will make an effort to get something cool this weekend since I will have time to myself for a change.
Old Dec 23, 2008 | 04:17 PM
  #103
xorbe's Avatar
Yep, on a flat road slam the gas pedal and a stop watch button simultaneously, depress again at 60. Do two or 3 runs and average... not super accurate, but good enough for the general idea. Whoever does this, please don't use the added throttle controller. Report temp and general wind.
I measured two A/Ts at ~12.2 stock, and one at ~11.9 with light weight rims and light weight crank pulley. On a hella hot day, the stock is almost 13!
Old Dec 24, 2008 | 12:44 PM
  #104
eldaino's Avatar
in all honesty just posting the stats would be more than enough for me. sometimes i feel that 0-60 vids are underwhelming, because you can't FEEL the speed of the car, it doesn't translate into fast. (unless ofcourse the car is ridiculously fast, which as we all know, most fits, even modded, are not.)
i will ask one thing of you though jensk: try you runs: 1 paddle shifting and 2 just leaving it in sport. they both result in faster real world numbers without f.i., so i can imagine that they would be better with. if i could get my fit to do low 8 second runs, or even into the seven's, i'd be thrilled. i could stop worrying about wanting another car, or wanting to sell the fit for an older ef or ek.
Old Dec 24, 2008 | 01:27 PM
  #105
explosivpotato's Avatar
Vids are cool, because you get to hear the motor after the upgrade.
Nothing quite compares to sitting IN the fit as you floor it and watch the front end rise up through 2nd gear until you bust the tires loose just before you shift though...
Old Dec 25, 2008 | 12:18 PM
  #106
eldaino's Avatar
that would be the only reason i wouldn't mind a video, but i'd rather have the times if i had to choose.
jmsplitfyre
14
Oct 27, 2012 08:50 PM
Kittengolf
Oct 10, 2009 08:34 PM
projekz
Dec 29, 2008 09:41 PM
rvall004
25
Oct 27, 2008 11:50 AM
jsensk
15
Mar 3, 2008 12:36 AM
