Afr?
Old Apr 21, 2009 | 10:52 AM
  #61
artieman's Avatar
Originally Posted by im the fit
nope! it starts around 13.4 at WOT then as the rpm's go up it gets to 14.1 or a little leaner then when it gets to 6k its 13.8
you need something to richen it up a bit....the increased heat from lack of fuel will cause the piston to expand more wearing the rings out quicker...increased heat also will wear the valves out quicker....bla bla bla you get where im going with this....
Old Apr 21, 2009 | 11:12 AM
  #62
im the fit's Avatar
thats why I would want to know if I can use a colder plug for now because im saving up for a F/ic
Old Apr 21, 2009 | 11:19 AM
  #63
artieman's Avatar
colder or hotter plug doesnt effect the amount of fuel going in...need a way to control the ecu...for someone like yourself the apexi afc would do the trick cheaply and easily
Old Apr 21, 2009 | 02:25 PM
  #64
Sugarphreak's Avatar
Push My Button
How does timing play into this; the way I understand is that when you add a lot of fuel, you can subtract a bit of timing. But when subtracting fuel, it is not good to add timing... or is it?
Old Apr 21, 2009 | 04:15 PM
  #65
artieman's Avatar
timing does not change the a/f ratio....when tuning get your a/f ratio set and then adjust timing....only way to set timing correctly is on a dyno...
the term to remember here is MBT or minimum best timing....your want the least amount of timing that creates max power...
Old May 9, 2009 | 08:26 AM
  #66
im the fit's Avatar
Gotcha,
Basically I will want to try and run a nice smooth 13.1 then all the way accross (I heard 13.1 is the Fit N/A Special )
So I tried the 13.1 , 13.2 and I think its a little rich for me,right know as I tested so far is runnning 13.5 from 3,000 to 5,500 then after that 13.2 feels really good and gives me a good amount of torque,as for half throttle I have it running 14.3 wich is giving me better acceleration with less throttle.
Old Aug 12, 2009 | 04:22 PM
  #67
im the fit's Avatar
My N/A special is 12.9, Which i found out by messing around with the F/ic = ) , Big butt laod more power as for butt dyno
Old Aug 12, 2009 | 06:04 PM
  #68
DOHCtor's Avatar
How do you like the FIC I'm the fit?? Heard pretty good things about it on SRT Turbo Powered 1st gen DOHC Neons but didn't know for the fit!?!? What Part number also?
Marko!
Old Aug 12, 2009 | 06:41 PM
  #69
im the fit's Avatar
Marko!
I can tell you that its been the best upgrade for my car after all the mods, The part number is 30-1910 boomslang makes a harness so you dont have to cut the wires but its $200 I ended up cutting the wires.
Old Aug 13, 2009 | 04:50 AM
  #70
homohumane's Avatar
äðåâî ïîçíàíèÿ äîáðà è çëà
Áèáëåéñêîå "äðåâî" - ýòî ÏÀÐÀÄÈÃÌÀ.Áèáëåéñêèé "ïëîä" - ýòî ÈÑÒÈÍÀ.Ïóòü ê Èñòèíå íàõîäèòñÿ ïî àäðåñó: truenewworld.ruÈ "äðåâî", è "ïëîä", è "ïóòü" - ÍÀÑÒÎßÙÈÅ.Âû ìîæåòå â ýòî íå âåðèòü, íî âû ñìîæåòå ýòî ïðîâåðèòü.Ñ÷àñòëèâîãî ïóòè!
Old Aug 13, 2009 | 09:39 AM
  #71
im the fit's Avatar
Holy crap?
Old Sep 9, 2009 | 10:19 AM
  #72
awptickes's Avatar
Old Aug 28, 2024 | 05:16 PM
  #73
ifitfitsitships's Avatar
Is a 13.8 AFR good or ok or ?
I have headers,cat delete, catback,CAI,weapon-r intake manifold,crank pulley.BTW i just installed AEM wideband.
My 2008 GD3 Sport has had a liberal amount of heat soaking tape applied to both the inside of my header cover and to the outside of my HKS air intake. My idle A/F is 15.1. when I'm driving it never goes below 14.1 13.8 is a hair on the rich side.
Jazzl13a
23
Oct 13, 2022 06:24 PM
apexanimal
Feb 22, 2016 11:51 AM
F1Flagger
Jan 18, 2015 12:15 PM
kurisux92
Jan 11, 2011 07:56 PM
Spooling
Feb 13, 2009 09:30 AM
