*Built Fit Motor, build thread*
Old Mar 29, 2009 | 03:46 AM
  #101
qbmurderer13's Avatar
Man I cant wait to see what numbers that thing puts out, gotta get a drive in that thing
Old Mar 29, 2009 | 04:27 AM
  #102
dewthedew's Avatar
awesome! what are you using to tune it?
Old Mar 29, 2009 | 05:01 AM
  #103
doctordoom's Avatar
Supervillain
ooh let's see what it can do with a tune
Old Mar 29, 2009 | 03:42 PM
  #104
ghg78's Avatar
now if only someone would make parts for the head!
catcams does.
Old Mar 29, 2009 | 03:44 PM
  #105
artieman's Avatar
Originally Posted by ghg78
catcams does.
Cat Cams - Honda L15 Street Performance Camshaft (Fit/Jazz) drop in
main problem is we need springs and retainers...
Old Mar 29, 2009 | 04:20 PM
  #106
dewthedew's Avatar
Sweet $600 for a single camshaft...
Old Mar 29, 2009 | 05:24 PM
  #107
leonine's Avatar
they have springs and retainers as well.
CATCAMS racing parts [camshafts-valve springs-retainers-connecting rods]
Edit: they have 6 different cams. 3 of them do not require upgrading the oem springs/retainers (according to them).
Old Mar 29, 2009 | 05:46 PM
  #108
artieman's Avatar
ive seen other companies claim the same thing and later hear about how the retainers failed from the extra lift...im currently trying to find some extra parts so i can have a local guy build a set of prototype springs and retainers for testing and later public purchasing
Old Mar 29, 2009 | 07:19 PM
  #109
leonine's Avatar
cool then their will be 2 companies that sell them. Hopefully some other companies as well will come out with more parts since more people will probably be needing them soon. Boost is too addicting.
on a side note does the F-Con allow you to advance timing as well as retard it? I wish there was a piggyback that did it all. I believe e-manage does i think but does not bias the o2 sensor to prevent running lean in closed loop. The AEM F/IC does bias the o2 sensor but only allows timing retard.
I have a spare engine/tranny which i was planning on building up but if i invest all that money and have no piggyback to run more agressive timing then i will not be running to the full potential of the built engine right?
Old Mar 29, 2009 | 07:51 PM
  #110
artieman's Avatar
there is plenty of aftermarket engine management systems...just none that are plug n play...
we run the honda drag cars off this http://www.fuelairspark.com/Products...s/xfi/over.asp
Old Mar 29, 2009 | 08:13 PM
  #111
leonine's Avatar
what would you recommend. not a standalone because then i would lose all functionality of the oem gauges and stuff.
Edit: didnt see the link you put in but that looks like a standalone. so basically if i run a standalone then what about all of the oem gauges/ac/heater/etc...
Old Mar 29, 2009 | 09:17 PM
  #112
artieman's Avatar
you can run the aem stand alone but you would need to know how to wire it in. aem also has the piggyback unit.
Also jet can reprogram your stock ecu for your setup and amount of boost and it will be close and you can use something like apexi afc to fine tune it
Old Mar 30, 2009 | 10:01 AM
  #113
ghg78's Avatar
i was actually quoted $460 by qed power.
Old Mar 30, 2009 | 07:02 PM
  #114
FitFlowjoe's Avatar
Keep us posted on the Tuning!!! In the mean time break the new pistons in
Old Mar 30, 2009 | 08:25 PM
  #115
dewthedew's Avatar
Is that for a single cam shaft? thats still retarded! I paid $90 for a single cam for my vw.
Old Mar 31, 2009 | 12:21 AM
  #116
ghg78's Avatar
yeah.just the cam.yeah my boss was saying that also as he has used there cams before in his previous vw's.and honda single cams have always been between $300-$450 price range.
Old Mar 31, 2009 | 12:46 AM
  #117
gimme's Avatar
Master FitFreaker
just read...just finished hahahahahahahhaha
nice build, sir!
Old Mar 31, 2009 | 01:59 PM
  #118
gd3kamiwanaB's Avatar
Luvs Dah b00st!
thanks everybody should be tuned with in the month
Old Mar 31, 2009 | 03:10 PM
  #119
LUii_FiiT's Avatar
Congrats bro! Can't wait to see that motor in person!
Old Apr 2, 2009 | 06:44 PM
  #120
Gbaby2089's Avatar
how many miles you have on her so far since the rebuild???
