TIRE questions,sizes, mounting,pressures ANY tire questions
Old May 10, 2010 | 11:19 AM
  #941
Btrthnezr3's Avatar
2009 Honda Fit Sport
and I'm lowered on Swift Springs which are like 1.2" in the front and 1" in the rear.
Old May 10, 2010 | 11:31 AM
  #942
jim@tirerack's Avatar
Former Vendor
On the newer cars the 205/50R16 will work. The 2009 uses a taller tire than say the 2007 car uses. The DWS would be a great tire on the Fit. If I can help let me know.
Old May 10, 2010 | 11:38 AM
  #943
Btrthnezr3's Avatar
Great, thanks! Yeah--let me figure out my rim situation and I will let you know about getting those tires. They are like $105 each right?
Old Aug 30, 2010 | 06:51 PM
  #944
AshtonatBL's Avatar
How's the handling with these springs? I'm thinking of lowering mine. Thanks.
Old Aug 30, 2010 | 11:01 PM
  #945
Texas Coyote's Avatar
I don't think she would mind me speaking for her... The springs are great handling with a slightly firmer but not at all rough ride.... I like them on my GD3 too.
Old Sep 6, 2010 | 10:58 AM
  #946
stockrex's Avatar
i have a 2010 base with 175/65/15 on my steel oem wheels now.
will this size fit and ok to use on my steel wheels?
khumo P185/60R15
Old Sep 7, 2010 | 09:08 AM
  #947
Former Vendor
Yest they will fit no problem. If I can help let me know.
Old Dec 13, 2010 | 02:11 AM
  #948
Draako's Avatar
i have a 2008 sport , can i use 195/60/14 on stock wheels?
Old Dec 13, 2010 | 08:02 AM
  #949
mahout's Avatar
If your sport has 15" wheels, which is the diameter of the wheel at the base of the tire rim, you can't use 14" inside diameter tires.
If you find someproper 14" wheels that fit Honda Fits, then you can use those 195/60x14 tires. They're a little shorter than stock (.2") but not enough to matter.
Old Dec 13, 2010 | 08:30 AM
  #950
Former Vendor
They would work. The wider tires would not be as good in the snow though. If I can help with the tires let me know.
Old Dec 13, 2010 | 12:33 PM
  #951
nxtfit_08's Avatar
all i can say is http://tyerstretch.com they will tell you what size tire you need on what size rim
example: my wheel are 15x8 and it will tell me every size that is compatible but then you have to see what the best for your drop and stance you are going for!
Old Jan 13, 2011 | 02:32 AM
  #952
Draako's Avatar
im going to lower on pro kit , but for the moment ( money issue) im gonna stay with the sport wheels, but soon ill have to change tires so i was thinking getting something wider so 205-60-15 will work? the wheels got 55 offset
Old Jan 13, 2011 | 09:57 AM
  #953
Former Vendor
A 20560R15 is too tall and will not fit. You can go with either a 205/55R15 or 205/50R15 though.
Old Jan 13, 2011 | 12:35 PM
  #954
mahout's Avatar
I might disagree with the 205/55x15; they are too tall if he lowers. as long as the offset is 55 the 205/50x15 should work.
Old Jan 13, 2011 | 02:53 PM
  #955
Former Vendor
A 205/55R15 is the same height as the OE tires on the 09 Honda Fit. A lot depends on the width of the wheels as well. A 55mm offset if very high and may cause issues on the inside.
Old Jan 13, 2011 | 04:49 PM
  #956
mahout's Avatar
Agreed and even a trifle less but when you lower the car the original tire height becomes a shade on the risky side. The only saving grace is the 55 mm offset. When you lower a couple of inches even that isn't enough insurance. The 205/50x15 is a better choice.
Old Mar 21, 2011 | 08:38 PM
  #957
EDU's Avatar
EDU
hey guys noob with a fit here... quick question: anybody running 205/45 R16 on stock wheels?
2009 Fit sport.
reason im asking is cuz i need new tires and i found a good deal on a set of those brand new. otherwise ill go with 50's
thank you
Old Mar 21, 2011 | 09:06 PM
  #958
Goobers's Avatar
2009 Fit sport.
thank you
What is it you are worried about?
It is less likely to rub compared to 50s.
The speedo will be more off than the 50s (you will actually be going slower than the indicator).
The odo will be more off (you'll be adding more "miles" than you really got).
While the 50s will also be off, they're only off by .3%... where as the 45s will be off by more than 3% (that's 0.3 vs 3.0).
If you understand all that and are willing to accept it as a compromise... there shouldn't be anything wrong with using them.
Old Mar 21, 2011 | 09:48 PM
  #959
EDU's Avatar
EDU
thank you for the reply.
Old Mar 28, 2011 | 05:38 PM
  #960
lady_z's Avatar
Is running a set of 195/60/15 on a 15 x 6 ET35 wheel not so great an idea? I have the chance at picking up a set of wheels with new tires mounted on them on the cheapey-cheap.
Need a reply asap please!
