Mileage reports: Automatic transmission (5AT)
Old Feb 17, 2007 | 10:47 AM
  #581
FondaFit's Avatar
My AT Fit will be with me one year on April 22 (official release date). Within the next couple of days the odometer will hit 20,000! Mileage is consistently averaging between 31 and 33 mpg over the last couple of months. For a few days I changed my route. Instead of driving on I-95, which varies between gridlock and the Daytona 500, I was doing a mix of steady highway at 55-60 and frequent lights with more gridlock, and I got 34.5 mpg. Also during that time I wasn't hauling another passenger. The first several months with my Fit the mileage for my regular commute was lower, as little as 27-29 mpg, so I'm guessing it's completely broken in. I'm waiting to see how it does when the hottest summer months are here and I'm blasting the a/c.
Old Feb 18, 2007 | 12:46 AM
  #582
Gumpster's Avatar
I got my worst milage the past week, 23 MPG!!! Sheesh, If it does not improve, I am getting rid of this thing. Buddy of mine has a Nissan Maxima that gets close to 30 MPG and has a V-6 with a ton more power.
Old Feb 18, 2007 | 09:24 AM
  #583
clintthayer's Avatar
I'm on tank #3 and got 23.5MPG... first 2 tanks were ~21ish.
Live in Madison WI and have had very cold temps (below zero many mornings and highs in the single digits), and short ~3/5 mile trips around town.
Going to be getting warmer temps this week so I'm looking forward to checking out how much that effects the MPG.
Checked the tires yesterday and they are all at the recommended 32. SHould I put a little extra in?
Old Feb 18, 2007 | 05:43 PM
  #584
Terry F's Avatar
FIT automatics are defective leading to poor milege
There is no other conclusion to draw than that the automatic transmission Honda is putting in the FIT is defective. Looking at the forums, the manual gets good mileage but most FITs seem to get low mpg with the automatic. That would rule out all of the drive train except the transmission. My dealer's best mpg in their tests was 30.2mpg and the factory called to state this is within the "acceptable" range. I get 25 city and 29-30 highway. My son's Civic with 65,000 miles gets 30 city and 36 highway. Given the size of the FIT one can only say it is defective as there is no excuse in 2007 to build something that poorly designed.
I am also watching my oil dipstick as the oil level on the dipstick is dropping about 1/4" for every 400 miles. I think my engine is burning oil which would indicate bad rings leading to low compression and poor mpg. I am watching it closely. If it is burning oil then the only fix is a new engine.
My other concern is that if the poor mileage is caused by a bound up transmission due to design flaw then the durability is going to be reduced. I have found that it does not matter how we drive, easy or hard the mileage is always the same. Even on the highway it gets 29-30 whether you go 70-75mph like I drive or 85-90 like my son did on a 1600 mile trip.
I would not advise any one to buy a FIT with the automatic. There is something wrong with them. This forum knows it, the dealers know it and Honda knows it.
Old Feb 18, 2007 | 10:06 PM
  #585
bestfit's Avatar
i am just waiting for my first oil change.. i think it will make some change.. (crossing my fingers)...
Old Feb 18, 2007 | 10:33 PM
  #586
wyy183's Avatar
Thought that I would chime in here -
Today I drove to Atlanta, GA. I have a ScanGauge. Mileage for the trip was 35.4 mpg. My cruise was set on 77 mph and except for traffic - I maintained that the entire trip.
I turned over 20K miles today, too.
I've changed my oil twice, and am at 50% oil life right now. Using Mobil 1 5W-20. Tires are set at 38 psi front, 35 psi rear.
My cumulative mpg since I purchase on 5/17/06 is just over 30. I'm consistently getting 32-35 driving about 80% highway, 20% city.
YMMV
Old Feb 18, 2007 | 10:48 PM
  #587
bestfit's Avatar
YMMV
you changed your oil twice so far? that means.. you followed "Oil Life indicator oil change interval" right?
was it like every 8k or so for oil change??
Old Feb 19, 2007 | 08:24 AM
  #588
BuddhaKhan's Avatar
I am getting about 32mpg, all city on an 07 Fit Sport Auto. Love those paddle shifters.
Old Feb 19, 2007 | 01:02 PM
  #589
wyy183's Avatar
Just over 7,000 miles for first oil change. 14,200 miles at second oil change. I'm at 5,800 miles on this one and I'm only down to 50%! Go figure!!
Old Feb 19, 2007 | 02:32 PM
  #590
bestfit's Avatar
thanks for your reply... is guess it is okay to change oil according to "Oil life indicator"!!... i am around 2k now and OLI still says only 80% or so..
i been wondering ... should i just change oil around 4k or 5k regardless of OLI...
thanks. again..
Old Feb 19, 2007 | 02:46 PM
  #591
put the PSI at 36 all the way around... I doubt this will change things much, but we will see. It will be tough as we have a warming trend as well going on
Old Feb 22, 2007 | 02:03 AM
  #592
Phit's Avatar
Fray for giggles I might just flush my tranny when I get my first oil change. I am another AT owner whom has not seen a 300 mile tank yet. I am a mixture of highway and city about 15miles a commute. I was using the thumb shifts for a while and it was working a little better (26mpg) and I just ran the tank without using the thumbs at all and am coming in at (23mpg). To make the matter stickier for me is that if my mileage doesn't improve I already got plowed from behind by an F350 and can no longer sell the car as a certified used Honda. Lets hope the tranny fluid does the trick. I am curious whether it is a computer prob. though.
Old Feb 22, 2007 | 10:03 AM
  #593
phoenity's Avatar
Wow...how did that turn out??
Old Feb 22, 2007 | 02:48 PM
  #594
JamesBizzle's Avatar
I've never seen 300 on a tank either and i'm at 10,000+ miles already. and to top it off I have a M/T. lemme know how the trans flush works out for you.
Old Feb 25, 2007 | 07:52 PM
  #595
mobortho's Avatar
I think that's a pretty strong statement. My Auto Sport is getting 30MPG mixed use over the last 5k miles, total is now about 15k. I had one tank on the highway that was actually 38 MPG. No vehicle out there is expected to get the EPA numbers, that's why they're lowering all of them for the 2008 modles, but my Fit is doing well.
Old Feb 25, 2007 | 07:57 PM
  #596
mobortho's Avatar
thanks. again..
I would do what the MM recommends. It truly adjusts the oil life based on your driving. My 2007 Civic was using 10% oil life for each 600 miles around town. Then when I took a 1300 mile trip, I watched it carefully, and a 10% increment was 1000 miles of constant road miles. Most enthusiasts change oil too often based on marketing by the oil change companies. Honda has recommended 7500-10000 intervals since my 2001 Odyssey and maybe before. As long as you do it regularly with good oil, and a new filter, I think you're fine. Changing it twice as often, just wastes oil, money, & time.
Old Feb 25, 2007 | 08:53 PM
  #597
bestfit's Avatar
i too have 2002 Odyssey.. i heard i could do 5k oil change.. but i change it like every 3-4k ...when you look at owner's manuel.. "for severe driving condition you got to change your oil often"... and what i've been told by my mech.. obivously every 3k..
one thing i like about Fit is It calculate Oil life for me.. and i plan to follow it...
once again thanks.
Old Feb 26, 2007 | 12:01 AM
  #598
scorpmatt's Avatar
I'm at just above 8k on my fit sport auto and have been averaging about 33mpg. If i drive the car a couple ticks above granny style and hit the cruise between 60 and 65 mph, then by my calculations im getting between 35 and 40 mpg. of course its not always wasy to do this so this is why my average is lower than peak.
btw, checked the tripometer the other day, and its acurate to less then 1%, in other words, im going about .04 to .06 miles on the trip than an actual miles.
Old Feb 26, 2007 | 01:34 AM
  #599
big Fit's Avatar
mmmm
I had previously owned a mt fit which did at and above the sticker statement for mpg. My best was 46.4 on hwy which had some traffic slow downs in seattle. Most offten I did 38 mpg on the hwy. around town it usually was 33 mpg. the worst around town for me in that car was 28 mpg. the bottom line is the AT fit I drive now gets 7 to 12 mpg less. thats the sad facts. I think manypeople that post here dont get enough credit for being objective.
think about it, what kind of person would visit this site/thread in the first place?
Gas milage was on the top three required things on my list to make the purchase.... wah wah.
Old Feb 26, 2007 | 11:26 AM
  #600
jacksan1's Avatar
A total of 8,000 miles on our Sport AT. Overall MPG: 31.2 on almost exactly 50/50 split between true city and highway. The best highway MPG so far was 38.9 MPG. The worst ever was 26.8 MPG, when it was 80/20 city/highway.
