ETC 12 step Adjustable Throttle Controller
Old Jan 24, 2012 | 01:34 PM
  #421
twpanson's Avatar
16 step Adjustable Throttle Controller
All pm sent
Sincerely,
Panson
Old Jan 25, 2012 | 02:19 PM
  #422
Rollerboots666's Avatar
PM'd ya didn't hear back.
Price shipped to 92104, Thanks.
Old Jan 27, 2012 | 08:35 PM
  #423
SSMTEN's Avatar
Hey I just bought one off a member here. Dont have the instructions though. Got it hooked up and everything. Little red light is flashing on the larger black box. What do I need to do to set it up?
Nevermind! Found Java's instructions in this thread. Got it working.
Old Jan 27, 2012 | 08:41 PM
  #424
dled1286's Avatar
1) Turn the ignition to "ON" but do not crank car.
2) Press and hold the "set" button on the small module until the screen starts counting down.
3) Once the countdown is complete press the accelerator all the way down until the voltage number levels out. Press the set button once.
4) Let off the accelerator until the voltage number levels out. Press set one more time.
5) This should complete the setup and you should be able to crank the car, set it to your desired setting (EC 1-7/nor/SP 1-9) and you should see the difference in throttle response.
HOPE THIS HELPS!
Old Jan 29, 2012 | 10:44 PM
  #425
twpanson's Avatar
Bump~~
If you need official installation guide, pls kindly pm me your email address
Sincerely,
Panson
Old Feb 6, 2012 | 11:05 PM
  #426
twpanson's Avatar
Bump for a great add-on that every Fit owner should have one~~
Sincerely,
Panson
Old Feb 12, 2012 | 12:40 AM
  #427
xalx02's Avatar
how much shipped to 90275? for a GD3
Old Feb 13, 2012 | 08:36 PM
  #428
CJSdrftFlat's Avatar
how much for a race version (the one that remembers the settings) for a 2012 sport?
Old Feb 13, 2012 | 08:42 PM
  #429
dled1286's Avatar
I wasnt aware there was a "race" version. From what I understand theres no need for a "race" version. The regular throttle controller is all thats needed to change the point at which you reach WOT.
Old Feb 13, 2012 | 08:46 PM
  #430
I was referring to this:
We are offing 2 different version to fulfill market demand.
1. Street version: T/C kit will revert back to normal mode when engine being shut off (safety concern, prevent family member launching your car at driveway w/ Sport7 mode on setting)
2. Racing version: T/C kit will retain last setting when engine being turned off. We only recommend this versio if you are the only driver on your car.
Old Feb 13, 2012 | 08:48 PM
  #431
dled1286's Avatar
AH. So they just messed with the programming for the control module. I have one from before they did that and mine would be considered the "race" version. I like it because i keep it in EC7 to buffer my heavy foot and i like not having to set it everytime i get in and start up.
Old Feb 13, 2012 | 10:47 PM
  #432
twpanson's Avatar
All pm replied/ sent!!
Sincerely,
Panson
Old Feb 16, 2012 | 05:44 PM
  #433
dwhopson's Avatar
How much for the racing version shipped to 27410?
I'm assuming the eco settings work like the "eco" button in the new Civics?
Just what is the install process for this device? Is it two plugs and a cable splice?
Thanks!
Old Feb 16, 2012 | 06:02 PM
  #434
Java^FiT's Avatar
Thanks!
Basically you unplug the wire going to the accelerator pedal, plug your new harness cable in that spot and the wire you removed to the other end. Then that plugs into the control module. Another wire goes from the "Set"/"Mode" Display unit to the control module. Then you plug it into the OBDII port for power or splice a ground and +12V constant wire for hard wire power. takes 10-25min depending on power choice. then program. PM me if you have questions.
Old Feb 22, 2012 | 01:02 AM
  #435
payment sent
Old Mar 7, 2012 | 10:28 PM
  #436
twpanson's Avatar
Bump~~~
All pm replied,
Sincerely,'
Panson
Old Mar 8, 2012 | 12:53 AM
  #437
bdogpot's Avatar
i need to know price plus shipping for racing one to 78163, for AT 2012.
Old Mar 8, 2012 | 09:32 AM
  #438
dled1286's Avatar
BTW I may or may not have one of the "race" models for sale for a 07-08 Fit. I haven't decided if I want to put it on my Si yet or not. Gas savings = -vs- Slow throttle response on a high-strung 6sp manual =
Old Mar 8, 2012 | 03:16 PM
  #439
Texas Coyote's Avatar
The slower eco settings have worked out well as a means of getting more miles out of a tank of gas... It has made a difference of 4 MPG and better as long as I was a good boy and didn't submit to the temptation of using the sport mode and a heavy throttle foot.
Old Mar 8, 2012 | 03:35 PM
  #440
dled1286's Avatar
this i am aware of but the question is how driveable my si will be with the slower throttle response. i might try it for a little while before i make my mind up.
