ETC 12 step Adjustable Throttle Controller
Old May 22, 2011 | 01:36 PM
  #281
twpanson's Avatar
pm sent
Sincerely,
Panson
Old May 30, 2011 | 11:06 PM
  #282
twpanson's Avatar
Bump~ for a nice add-on to smooth out your launch.
Sincerely,
Panson
Old Jun 1, 2011 | 12:59 PM
  #283
twpanson's Avatar
PM replied! and Bumpz~~
Sincerely,
Panson
Old Jun 12, 2011 | 12:55 AM
  #284
phenoyz's Avatar
does this thing help improve your gas mileage?
thanks
Old Jun 12, 2011 | 01:21 AM
  #285
Texas Coyote's Avatar
thanks
Most people use the ETC as a means of opening the throttle faster than the stock drive by wire controller is setup to open it for quicker response.... It does also have slower than stock settings. I have found that when I use the slowest responding setting and make some effort toward trying to drive more economically I can get 3 MPG better than using a setting close to but slightly faster than the normal (stock) setting.... Using the fastest responding setting and driving really fast on hilly twisting back roads I will see about 25MPG... Driving the way I normally do I am able to get about 33.5MPG give or take 1 MPG.. My car is supercharged so I would expect much higher figures if my engine tuning was closer to stock...
Old Jun 12, 2011 | 01:34 AM
  #286
phenoyz's Avatar
another question: is this similar to the ones that the 2012 civics/crz have? the ECON=only this is aftermarket.
i plan to keep my engine stock, so if i buy this and put it at the slowest responding setting will it give my gas mileage a higher figure.
(i have a 2011 sport manual)
Thanks again for your reply and sorry for being a noob...hehe
Old Jun 12, 2011 | 02:22 AM
  #287
Jamy's Avatar
See I got the best mpg's from the Sport 6 setting. But I'm a lead foot. So idk. I went from 25 mpg to 29 mpg after installing it. Guess it depends on how you drive. I have the 2010 Fit base manual if that helps you out.
Old Jun 12, 2011 | 02:38 AM
  #288
another question is this similar to the ones that the 2012 civics/crz have? the ECON, only this is aftermarket.
i plan to keep my engine stock, so if i buy this and put it at the slowest responding setting will give my gas mileage a higher figure.
I don't know anything about the Civics/CRZ's have but more than likely what they have works in the same manner... The only differences between the ones for differing models is the OBD2 adapter harness and guys here have been using one brand or the other for 3 1/2 years or longer... Using it for economical driving in a slower reacting setting will mean that you have to push the pedal down further to open the throttle the amount needed to reach a certain speed or RPM in which ever gear you are in... Being that you will need to be more deliberate two move the pedal the extra distance to accelerate or decelerate will make it easier to be precise smoother than it would be if in the stock or performance mode... I find that by slowly pressing down on the pedal until it reaches the point where I want to shift gears or reach the speed limit is easier to do without opening the throttle further than necessary when I am using the slowest opening setting... If you need to accelerate faster you can still open the throttle all the way by putting the pedal to the floor... When the ETC is set in the fastest mode you will be at full throttle with out putting the pedal to the floor so your engine responds much more quickly in gaining rpm, your car accelerates more quickly and you use more fuel, but it's fun to do at times for grins.
Old Jun 12, 2011 | 02:40 AM
  #289
Jamy's Avatar
TC knows how to have fun
Old Jun 12, 2011 | 02:49 AM
  #290
I had a lot more fun before I got too old for young women and my pecker wasn't interested in responding to the ones closer to my age.
Old Jun 12, 2011 | 11:08 AM
  #291
SilverBullet's Avatar
Whats you mpg and average distant driven? Short trips less than 6 miles really hurt mpg and using A/C hurts mpg by putting a higher load on the motor which requires more fuel. Try using higher octane and get gasoline from a busy station. A busy station means fresh gasoline which helps in mpg.
I notice that when I am on the Interstate at 65 my ultra gauge says 35 mpg but I can lift off the gas a little and still maintain that speed and the mpg goes to 60mpg. If you drive city and short trips there is nothing to do to bring the mpg up except to shut the motor off at lights but I dont recommend that unless its for a freight train. Excessive Heat soaking is not good for the fuel system and for the piston rings plus the starter wont last and that adds to electrical problems.
Old Jun 12, 2011 | 11:56 AM
  #292
phenoyz's Avatar
I am content with my mpg, on my recent trip to California i check the mm
it says 41, i didnt use a/c and 60-70 was my average. Only me and wife.
My car is stock, except from the afe air filter change.
But i want to increase my gas mileage like the one i was getting from my
'98 civic sedan LX also m/t. On that car its like the needle never drops
Thats why i am looking for more information on what mods i need to do
to increase mpg. Coz i wanna use a/c especially during summer, and i also
want to go w/ the flow when i drive in the highway and it means going
more than 65 mph.
my bro. in law came here to vegas 3 weeks ago from san francisco, and they rented that new KIA sedona van, that has that ECON, there were 6 adults and two infants,A/C was obviously on, 80mph, and he says it (ECON) help alot w/mpg. Thats why im asking if this "adjustable throttle controller" is that same thing on those newer cars/van to increase fuel efficiency.
Old Jun 12, 2011 | 12:22 PM
  #293
94 civic sedan LX also m/t. On that car its like the needle never drops
more than 65 mph.
Thank you, now I know where your coming from.Its hard to compare different makes of vehicles because they are different. ECON is mostly a sale point because of high fuel prices. I dont know anything about the 12 step controller except to say the throttle body is electric and the controller would work by change signals to the TB and have not heard anything bad about it.
I do know that running premium and doing a few full throttle passes (2-3 seconds) with a warm motor the TB acts different and is easier to get better mpg. If there is Knock the ecu will add fuel and retard the timing and that could use 25 percent more fuel at certain loads. More like 10 percent average loss per tank.
Old Jun 12, 2011 | 01:41 PM
  #294
phenoyz's Avatar
Thanks again.
Old Jun 12, 2011 | 04:23 PM
  #295
fawbusha's Avatar
PM me a price shipped to 23455 please and thanks
Old Jun 13, 2011 | 12:23 PM
  #296
circa40's Avatar
Price shipped to 92870
Old Jun 19, 2011 | 12:06 PM
  #297
sp1365's Avatar
PM a price shipped to 60647?
Thanks!
Old Jun 19, 2011 | 01:10 PM
  #298
twpanson's Avatar
All pm sent!
Sincerely,
Panson
Old Jun 19, 2011 | 05:26 PM
  #299
theindiearmy's Avatar
Price for each street and racing shipped to 98059 please. Thank you.
Old Jun 21, 2011 | 04:52 AM
  #300
creasechan's Avatar
price for each shipped to 92069?
