ETC 12 step Adjustable Throttle Controller
Old Apr 15, 2011 | 05:27 AM
  #261
twpanson's Avatar
Sir,
This is normal. Controller will go off within 5~10 mins after car being turned off.
Let me KNOW
Panson
Originally Posted by Java^FiT
I installed mine tonight and so far my car isnt blowing up. I have not drove it around yet because i was worried about one thing. I started my car, and it came on obviously then i turned the car off and it still stays on. I giggled with my shifter a little bit and by chance it happened to go off. Is this supposed to stay on that long after turning off the car? would i have better results if i hard wired it rather than using the obd port?
Old Apr 15, 2011 | 07:33 AM
  #262
cr4zy3lgato's Avatar
abbbsolutely normal! did you program it?
Old Apr 15, 2011 | 09:20 AM
  #263
Java^FiT's Avatar
Originally Posted by twpanson
Sir,
Let me KNOW
Panson
Ok that makes me feel a little better, I was worried because my ultra gauge always goes off immediately and this didn't. Is there a reason it takes so long to go off? I feel like it will slowly drain the battery if it stays on that long after shut off.
Yes I did, exactly from the instructions. I haven't played with it yet because im letting the ecu relearn but by tomorrow im gonna try some other modes.
Side note: If you already installed an In dash navi it most likely had a reverse signal wire hookup so tying this up to that wire i already had made it so much easier!
Old Apr 20, 2011 | 03:20 PM
  #264
Per-fit-ion's Avatar
Please quote me a price for the street version to 96797. Thanks!
Old Apr 21, 2011 | 05:35 AM
  #265
jazzista's Avatar
Hello Panson,
money sent and I saw that my Eu spec Fit (Jazz) has a different throttle sensor location (it's in the engine bay).
I'd like to get a pair of pics of the two possible connectors you have on stock in order to understand which one would "fit" mine.
Thank you,
Old Apr 21, 2011 | 01:11 PM
  #266
twpanson's Avatar
Sir,
Got it. However, I am concerned about the connector location.
Pls let me know if you want me to refund your money or to send you the 4A harness for your JDM GD.
Let me know
Panson
Originally Posted by jazzista
Hello Panson,
Thank you,
Old Apr 21, 2011 | 02:52 PM
  #267
Jamy's Avatar
Could I get a price for the Racing version to 70808 please?
Old Apr 22, 2011 | 05:06 AM
  #268
jazzista's Avatar
Hi,
may I ask you a picture of your 4A harness?
Thanks a lot,
Sir,
Let me know
Panson
Old Apr 25, 2011 | 06:07 PM
  #269
Tauwolf's Avatar
I just found out there's a new etc that has an 8 and 9 setting. Does this etc use the same harness as my current twp etc? How much is just the etc if i don't need to buy the harness?
Old Apr 26, 2011 | 03:14 AM
  #270
twpanson's Avatar
All pm replied!
Sincerely,
Panson
Old Apr 28, 2011 | 08:46 AM
  #271
Saved's Avatar
I just picked up my 08' GD3 yesterday, and come to find my ETC waiting for me on my door step when I got home. Perfect timing! But that wife of mine through away the instructions before I got a chance to program it... If anyone can post up a "program procedure" I would be grateful.
Old Apr 28, 2011 | 10:27 AM
  #272
Java^FiT's Avatar
NOTE - This next part is VERY important, please complete
this procedure before strarting the car
THROTTLE CONTROLLER INITIAL SETUP:
1. turn the ignition to the on position (position just before cranking)
2. the unit should light up and go through a couple different things then it should stop and display
"nor" on the display
NOTE - if it doesnt say "nor", press the mode button until it does
3. once the display reads "nor", hold down the MODE button
NOTE - the display should start counting down from 7 on down to zero
4. when it hits zero, hold is for one more second and the display should start blinking reading "LO"
"1.3" (the number is volts and may not say exactly 1.3)
5. without press the accelerato pedal press "set"
6. the display should now read "HI" "1.3" (the number is volts and may not say exactly 1.3)
7. press the accelerator pedal all the way to the floor and hold it
8. the display should say "HI" and a volt of 3. something or 4. something
9. press "set"
10. the TC is now set.
11. look at the TC display and press the accelerator pedal all the way to the floor and release a few
times. all the way to the floor and the display should say "100"
12. turn the key off
13. wait 5 seconds
14. start the car
NOTE - The Harness has a blue wire on it that is there by itself. that is for the Reverse
Disable. With that hooked up, what it does is revert the Controller back to normal mode for
reversing situations. That wire does not have to be hooked up. it is truly by preference.
NOTE - the car will go through its normal re-learning phases and wierd runing and etc. it
may even stall and idle way funny and surge a it more than usual.
Old Apr 28, 2011 | 10:36 AM
  #273
Java^FiT's Avatar
All pm replied!
Sincerely,
Panson
Question for you:
I am planning on hardwiring my unit but i was curious if I might be able to do this by tapping into the +12V constant and Ground wires on my head unit harness?
I am installing speakers soon and I need to pull out my in-dash nav anyway so this would probably be the easiest way for me to hardwire it. Do you see any possible issues with doing this?
Old Apr 28, 2011 | 12:10 PM
  #274
Saved's Avatar
Thanks Java & Panson for the info!
Old Apr 28, 2011 | 09:18 PM
  #275
Java^FiT's Avatar
Question for you:
just an update: i hooked it up to these wires tonight and it works perfectly in case anyone else wants to do this!
Old May 3, 2011 | 02:49 AM
  #276
twpanson's Avatar
All pkg sent!!!
Sincerely,
Panson
Old May 9, 2011 | 03:06 AM
  #277
twpanson's Avatar
Bump~~Bump~~~
Sincerely,
Panson
Old May 12, 2011 | 03:15 AM
  #278
twpanson's Avatar
PM replied!
Tks
Panson
Old May 17, 2011 | 03:47 AM
  #279
twpanson's Avatar
Pkg sent!
Tks
Panson
Old May 19, 2011 | 10:07 PM
  #280
SSMTEN's Avatar
Racing version to 32404 please?
tyty
