ETC 12 step Adjustable Throttle Controller
Old Mar 26, 2012 | 01:30 PM
  #441
RiverFitter's Avatar
Will this work on an automatic, and will it decrease the life of the engine components?
Old Mar 26, 2012 | 02:43 PM
  #442
twpanson's Avatar
Yes, it works perfectly on an automatic. And No, it won't shorten any life expectancy of you engine components. Because this unit simply assists throttle regulator to open up/close down faster/slower.
It doesn't change any setup in your ECU.
Pls feel free to post up if you have other questions
Sincerely,
Panson
Old Apr 10, 2012 | 04:01 AM
  #443
twpanson's Avatar
Late night bump~~~~
Sincerely,
Panson
Old Apr 11, 2012 | 05:32 AM
  #444
Diasoul's Avatar
looks fun i just dont exactly get the purpose of this.. could someone do a quick rundown on what this does?
Old Apr 11, 2012 | 03:12 PM
  #445
Texas Coyote's Avatar
It is used to speed up throttle response or slow it down... The drive by wire throttle is much slower in opening the throttle as a means of improving fuel mileage. Having an adjustable throttle controller allows you to choose how quickly or slowly the throttle responds to your right foot... It really helps acceleration in the sport settings and the slower economy settings with slower response to your right foot is helpful in improving fuel mileage..
Old Apr 11, 2012 | 06:49 PM
  #446
Diasoul's Avatar
sounds very awesome, but its a tad expensive. so if i do have some extra cash after im done with my car as of now. ill be sure to hit you up!! thanks.
Old Apr 11, 2012 | 07:57 PM
  #447
preludetofit's Avatar
bump because these are awesome to use. worth every penny
Old Apr 12, 2012 | 01:10 PM
  #448
twpanson's Avatar
Sorry for the late reply.
Thanks Coyote for the awesome feedback!!!
Sincerely,
Panson
Old Apr 16, 2012 | 04:30 AM
  #449
twpanson's Avatar
Bump~~
All pm replied, 1 pkg will be sent on Monday morning.
Sincerely,
Panson
Old Apr 20, 2012 | 03:08 PM
  #450
cocobinga's Avatar
I tried to install mine, but I am having serious problems. The control box would not power up at first and, even when it did, I could not start programming on it - I kept getting an error. When I tried to drive my car, the throttle would not respond at all. I panicked and reconnected the stock throttle wire. My car seems to be working normally again, but the check engine light is still on - PLEASE HELP!
Old Apr 20, 2012 | 03:32 PM
  #451
twpanson's Avatar
Sir,
No Panic. Just sent you the walkthrough now. Pls follow the walkthrough step by step.
We had 1 similar report as yours and turned out that installer only connect 1 head of the harness to stock connector but forget to insert the other head into the signal box above pedal.
Also, pls check and see if all wires coming out of control box and harness are firm. This might also be one of the causes.
Remember, never drive w/ TC on if you haven't done correct programming steps.
Sincerely,
Panson
Old Apr 20, 2012 | 05:15 PM
  #452
cocobinga's Avatar
It seems that maybe the loose-fitting ODB2 female plug may be causing the issue. Any advice, please?
Old Apr 26, 2012 | 12:51 PM
  #453
twpanson's Avatar
Sent you pm on troubleshooting a while back.
Just to follow up if you get all the issues resolved?
Sincerely,
Panson
Old Apr 27, 2012 | 05:54 AM
  #454
LeAJazz's Avatar
May i just add, this throttle controller is great! Helps me get great fuel economy than usual, and very spritely when in sports mode. Definitely recommend to those who are thinking about it
Old Apr 29, 2012 | 12:54 PM
  #455
twpanson's Avatar
All pm replied!!
Sincerely
Panson
Old May 2, 2012 | 11:06 PM
  #456
cfran55's Avatar
this product is a definite must, ive had it for a while now and i must say i can not drive in eco 1-2-3-4-5 or nor ever again i always keep it in sp7. best money ive spent on my car so far
Old May 10, 2012 | 06:27 PM
  #457
Rollerboots666's Avatar
Installed this batboy today. Wow what a difference! This ETC is killer. I def recommend this to anyone that wants a little more fun from there FIT. Thanks Panson.
Old May 11, 2012 | 09:28 AM
  #458
neutral's Avatar
Alright Panson, sign me up.
Old May 11, 2012 | 01:39 PM
  #459
User modes I played with on day 1.
EC7 - Driving Miss Daisy mode - Serious gas saver. I stalled while taking off on a hill. There is a lot of hesitation in the pedal. Be careful she'll be a putter. Takes some time to get use to.
EC5 - I found this to be really good on the street. Slows ya down some but easy to get use too.
Norm - This feels fast after you are in any EC mode. Crazy how you feel the difference when switched while driving.
SP5 - Fun. Really moves. Get rid of that hesitation in the pedal. You can really feel a difference in the performance.
SP9 - "KITT, turbo boost NOW"!!!! Be careful on this one. Its way to much fun. No kidding the second you get on the pedal my FIT would spin the tires out of first every time. I can see johnny law & me meeting on this mode.
I have to say is the best bang for the buck part I have ever gotten.
Old May 13, 2012 | 11:38 PM
  #460
twpanson's Avatar
PM sent!
Cheers
Panson
