Quote:
Originally Posted by claymore
I sorry if I missed it somewhere but is this a modification to make shifts shorter? Or is it just making the shift handle itself shorter. If it's made to have shorter shifts how can the shift lever be longer without raising the shifter body for clearance like the skunk 2 spacers?
Yes, this is to make the shifting throw shorter. Eventually the shifter is longer at the bottom portion.
The T1R shifter does not need to raise the change level housing because that the way we designed it.
