View Single Post
  #20 (permalink)
Old 11-20-2008, 08:46 PM
ICIN235's Avatar
ICIN235 ICIN235 is offline
ICIN235 is an unknown quantity at this point
Shifter
With the stock shifting, whether in neutral, or in gear, you can wiggle the stick and you'll notice a good amount of slop (play). I found that this comes from loose tolerances in the shifter design, especially at the shift cable that connects to the bottom of the stick.
Is any of this slop reduced with addition of the T1R?
Also, where can I order the shifter from?
Thanks.
