TIRE questions,sizes, mounting,pressures ANY tire questions
Old Oct 28, 2009 | 08:29 PM
  #901
IIEZ's Avatar
what I run
I think it really depends if you drop the GE or not. I am running 215/35r18 ET 42 with no rubbing. I also had run 195/60r15 ET 40 with no rubbing. Note that I was on stock suspension. Also with both setups I had over 400lbs in the car and it did not rub. I want to mention that I read somewhere in this forum that someone was running 205/55r16 on the stock sport wheels. I was thinking of running 205/50 on the stock wheels with winter tires.
Old Oct 29, 2009 | 08:16 AM
  #902
jim@tirerack's Avatar
Former Vendor
On the OE wheels the 205/50R16 will fit. You do need to be careful with the offsets on this car. The higher the better so around 45mm if good.
If I can help with the tires let me know.
Old Oct 29, 2009 | 11:22 AM
  #903
edhaswell's Avatar
OK. Thanks, runbikerun, IIEZ, Jim. Nice to know that 205/50-16 will work on the stock wheels. I should have mentioned, btw, that I plan to leave the car stock otherwise. Just want better tires.
Apparently the problem is more on the outside, the fender side, than the inside?
Old Oct 29, 2009 | 12:37 PM
  #904
Former Vendor
We do not show any issues with the factory wheels and the 2105/50R16.
Old Oct 29, 2009 | 12:48 PM
  #905
edhaswell's Avatar
Cool. One more question. Since 205/50-16 on stock wheels works, I assume that 195/55-16 would also work: the specs of (for example) the Potenza G019 show it being only .1" larger radius than the OEMs and not as wide as the 205s.
Old Oct 29, 2009 | 12:50 PM
  #906
Former Vendor
They would be .4" taller than the 185/55R16 so I can't be sure but there are guys running the 195/60R15 so they might work.
Old Oct 29, 2009 | 01:14 PM
  #907
jordan jazz's Avatar
I just installed bridgestone potenza 205/50/16 on a jazz 2009 and it works perfect. Braking and the grip in corners is much better. The roads in Jordan, Middle East are great for testing a tire!
Old Dec 3, 2009 | 10:14 AM
  #908
Black3sr's Avatar
I just had my BFG 185/65R/15 put on. Can anyone tell me how much my speedo will be off if any?
Oh why did they put those green valve caps on? I must get center caps or cheap hub caps.
Wow quite the dif in the ride. Much softer.
Pics later
Old Dec 3, 2009 | 11:23 AM
  #909
Former Vendor
The height on the tire is .6" taller than stock. Maybe a mile or 2 at 55 mph would be all. That is of course if it is correct to begin with.
Old Dec 3, 2009 | 11:37 AM
  #910
awptickes's Avatar
generally green valve caps mean they put Nitrogen in the tires.
Old Dec 3, 2009 | 03:53 PM
  #911
Black3sr's Avatar
Thanks Jim
I learnt something today. Green is Nitro. Will I go faster? Thanks awptickese
Pics just added. Talk about clashing. Green, blue, silver and black and a bit of rust in center. I may look for some cheap hub caps.
Old Jan 11, 2010 | 12:17 PM
  #912
jay villains's Avatar
ok. looked and searched...but freaking out a bit..
i got a set of rota subzeros that are 16x7 with a 40 offset with 205/45 ...
i have a 08..
will these fit?
can i lower it?
Old Jan 11, 2010 | 12:55 PM
  #913
Former Vendor
What year and model car are they for? Let me know and I can make a recommendation.
Old Jan 11, 2010 | 12:58 PM
  #914
Sorry Jim,
they are for a 2008 base fit...
Old Jan 11, 2010 | 03:13 PM
  #915
Former Vendor
The 16X7 witht he 40mm offset could cause some rubbing. You really need higher than a 45mm offset. You could roll the fender lips to give yourself more room.
If I can help let me know.
Old Jan 11, 2010 | 05:08 PM
  #916
xorbe's Avatar
I think my 205 15s on et42 (enkei rpf1) rub on big bumps ... that wasn't supposed to happen I thought. I think it's in the back from the sound of it. It has to be a damn big bump, it's rare.
Old Jan 11, 2010 | 05:28 PM
  #917
Former Vendor
We have a note that list anything less than a 45mm offset wheel may rub. You can try running a little more negative camber.
Old Feb 17, 2010 | 10:19 PM
  #918
Tiu's Avatar
Tiu
Hi, I'm from Australia SYD.
I've just purchased the GD3 '04 VTI-S, the size of the tires on the car are 185/55 15 on the stock rims. I just want to know is this the stock tyre size for the stock car? I need to replace these tires soon but i want to see my opinion on sizes.
Old Feb 18, 2010 | 09:52 AM
  #919
Former Vendor
What year Make and model car do you have?
Old Feb 18, 2010 | 10:18 AM
  #920
Tiu's Avatar
Tiu
Honda Jazz VTi-S MY04
