K&N Filter kit for a Jazz
Old Nov 22, 2006 | 04:31 PM
  #161
805FitSport's Avatar
Originally Posted by kocba
Its not true in general - depends on construction of CAI.
I know a guy, who is a pro in engine tuning. He has been dynoing a car (Civic with B18 engine).
1st with CAI
2nd with Short Ram
Conclusion was, that the engine torque and power curve was constant (a smooth line without drops) with Shot Ram. With CAI the curve showed a significant drop of T and P in the mid range of RPM. In both cases ECU tuning was applied and dynoed. Both applications used the same filter.
Of course it depends on the engine disposition and construction of CAI.
One more thing (imho), if you are applying any open pod systems (CAI or Short Ram), you need to reset the ECU for max. achievement (so ECU will adjust from scratch) -> its simply done by disconecting the main supply at the battery.
a civic is not a Fit, the Fits ECU like most new cars today will respond better to cold airs everytime.
Old Dec 21, 2006 | 06:39 PM
  #162
4dr4life!'s Avatar
Just got word that my K&N filter kit should arrive sometime next week
Old Jan 8, 2007 | 10:45 AM
  #163
4dr4life!'s Avatar
For you members waiting for this product
https://www.fitfreak.net/forums/112649-post12.html
Old Jan 9, 2007 | 12:49 AM
  #164
Oofie's Avatar
Is it worth it? How's your gas mileage? I drive about 200 miles a day and Im looking for something that will help my gas mileage. Im still debating on whether I should get the drop in filter or the short ram intake.
Old Jan 9, 2007 | 12:57 AM
  #165
4dr4life!'s Avatar
Cant tell right now since I just installed it. I did have the drop-in and it help.
Old Jan 9, 2007 | 11:14 AM
  #166
docjim2's Avatar
BUT they look cool!!
Old Jan 9, 2007 | 11:23 AM
  #167
manxman's Avatar
Oofie & 4dr:
I registered with the K & N site for info. on new products in the works for Fits back in September. When they Emailed about the drop-in filter, I bought and installed it. But because the OEM air box has a "muffler", that translates to me as restrictive baffling to reduce noise. I did notice a slight MPG increase with the drop-in filter. I just ordered the "Typhoon" SRI kit because with no muffler, restriction must also be reduced. Although the Fujita SRI is somewhat cheaper, I have read complaints about its crooked fit in the engine bay. I decided to spend more on the K & N because of decades of good experience with their quality and effectiveness. I do not expect huge gains in fuel economy, but believe that this will pay for itself over (a long) time.
Dave
Old Jan 9, 2007 | 01:04 PM
  #168
4dr4life!'s Avatar
Originally Posted by manxman
Oofie & 4dr:
Dave
I wonder which part is the "muffler" on the air box. Never really like any of the SRI that were released right away.
Old Jan 9, 2007 | 10:44 PM
  #169
sonorliteman's Avatar
It is actually called a resonator chamber, and believe it or not, I've read that they actually can promote air flow by cancelling harmonic frequencies at certain engine rpms which can contribute to air flow resistance.
The Fit's stock intake box has a small bulbous chamber right above the snorkel, and there is another more complex chamber molded into the bottom side of the main air box....what is interesting is that this chamber has an opening to the area beneath the filter, exposed to unfiltered air, and the other end is open at the throttle body. So it is conceivable that the intake could be pulling in a small portion of unfiltered air, but I'm betting that by design it does nothing other than equalize the pressure between the two areas of the chamber. For those who don't understand what I'm talking about, take out the stock air filter and look for a small notch opening in the bottom of the intake torwards the front of the car. That passage leads all the way beneath the intake and opens up at the throttle body.
Old Feb 7, 2007 | 12:22 PM
  #170
Bounty Hunter's Avatar
I'm thinking about buying a K&N drop in panel filter. Auto Anything has them for $34.XX and that includes free shipping.
Old Feb 7, 2007 | 02:12 PM
  #171
docjim2's Avatar
Then what about the so called electric 'superchargers' ... no not the Turbonator... the e-ram, SEMA International New Product Award 2007... claims increase the CFM to 800 ?
Old Feb 7, 2007 | 02:42 PM
  #172
docjim2's Avatar
dark jazz: What kind of filter in the pic? K&N? if so what stock number?
Old Feb 19, 2007 | 09:16 AM
  #173
jazzista's Avatar
Originally Posted by strepto
Adding an aftermarket intake system is probably the most common upgrade today. However - in most cases it will increase the fuel consumption. The reason is simple. The Jazz ECU uses the output of the primary O2 sensor to calculate injector Duty Cycle. This is done in whats called a Closed Loop operation - a part of the OBD1 and OBD2 systems.
...mega snip...
- it needs to be tuned to perform its best
Hi Todd, all,
so, I wonder that also a simple flat panel filter (a-la K&N, or similar) would behave similarly... What would you recommend (if any) as a filter upgrade for my wife's Jazz 1,2l ?
Thanks a lot,
Stefano
Old Apr 30, 2007 | 11:07 PM
  #174
utnorris's Avatar
I am too also interested in how well these devices do. Do they really work?
Utnorris
Old May 1, 2007 | 09:14 AM
  #175
docjim2's Avatar
then would insulating the outside of the tube help keep more heat out?
Old May 4, 2007 | 02:24 AM
  #176
SiLvEr_JeZi's Avatar
I logged on the K&N website and found out that the part number for the Typhoon Intake System 69-1016TS. Does anybody know if this will fit in a 1.3L IDSi Jazz? Because it said in the website that it is for a 2007 1.5L Fit. Is there any difference?
Old Sep 17, 2007 | 04:01 AM
  #177
hoey888's Avatar
Just a question, with the K&N filter will it matter if i want to install into my aussie jazz with CVT?
Old Sep 17, 2007 | 06:57 AM
  #178
utnorris's Avatar
I know the K&N SRI had some problems with fitting when it first came out, is this still an issue?
Thanks,
Utnorris
Old Sep 17, 2007 | 10:57 AM
  #179
manxman's Avatar
Thanks,
Utnorris
IT IS STILL AN ISSUE with USDM Fits!! K&N SRI does not fit properly with USDM. The previous poster was asking about his Australian Jazz. I don't believe that there are any fitment problems with K&N intakes on JDM 1.3L Jazz.
Old Sep 17, 2007 | 11:18 AM
  #180
utnorris's Avatar
Thanks, I was hoping the issue had been resolved by now. Oh well, guess I will go to a different brand.
Thanks again,
Utnorris
