K&N Filter kit for a Jazz
Old May 8, 2006 | 03:30 PM
  #101
Bruce Shaffstall's Avatar
Thanks,
That was really good the part about K&N and replacment Filters.
It's kind of what I thought, but had nothing to back it up.
The Honda dealer Guy reminded me of a domestic Car dealer VS a Honda Car dealer,,
Geeezee,
Thanks again,
Bruce
Old May 11, 2006 | 12:55 PM
  #102
4dr4life!'s Avatar
I'll be participating in K&N's prototyping performance intake kits within a week. Im so excited!
Old May 15, 2006 | 02:39 PM
  #103
Paulo107's Avatar
how did you get that hook up???
Old May 15, 2006 | 02:42 PM
  #104
Paulo107's Avatar
i wanna see what other companies come out with the intake
Old May 17, 2006 | 08:37 AM
  #105
s3561999's Avatar
Hi: I just wqant to ask what does the orignal intake system look like? mine one is a square shape but i heard there are rectangle ones too!?
Chen
Old May 18, 2006 | 08:58 PM
  #106
RICELVR's Avatar
Does this K&N kit fit the North American 1.5's??
Old May 22, 2006 | 03:01 PM
  #107
4dr4life!'s Avatar
Just dropped off my car to K&N in Riverside for prototyping. There gonna be fabbing up a Typhoon Air Intake System.
Old May 22, 2006 | 03:17 PM
  #108
impreza's Avatar
does k&n make panel filters for fit?
Old May 22, 2006 | 03:20 PM
  #109
4dr4life!'s Avatar
What do you mean by panel filters? Are you talking about the drop-in kits?
Old May 26, 2006 | 03:51 PM
  #110
Wave's Avatar
Was thinking the exact same thing...
Old May 28, 2006 | 10:31 AM
  #111
4dr4life!'s Avatar
picked up my car yesterday, the intake will be developed within 6 weeks. its gonna be a short ram with a heatshield. it almost looks like an S shape and the filter will be located in front of the battery.
Old Jun 10, 2006 | 04:14 PM
  #112
MaybeFit's Avatar
Originally Posted by strepto
Adding an aftermarket intake system is probably the most common upgrade today. However - in most cases it will increase the fuel consumption. The reason is simple. The Jazz ECU uses the output of the primary O2 sensor to calculate injector Duty Cycle. This is done in whats called a Closed Loop operation - a part of the OBD1 and OBD2 systems.
In Closed Loop Mode - the ECU will use the output of the O2 sensor to correct the fuel injectors output to match an Air Fuel Ratio (AFR) of 14.7 units of air, to 1 unit of fuel. An AFR @ 14.7:1 is called Stoich. This is the point where the blend of fuel and oxygen is optimalized to perform its best without causing too much exhaust - and without sacrificing performance. The lower the AFR value, the more fuel is consumed.
When you add a new performace Intake System the engine gets more air. ECU will get a feedback from the primary O2 sensor saying that "Hey, I got more Air today, toss in some fuel there!" and ECU increases the Duty Cycle of the injector - thus adding fuel.
Closed Loop operations are usually located between 1500 and 4000 RPMs. On the higher revs the ECU uses static maps programmed into the ECU to calculate injector Duty Cycle. This is called Open Loop. Regardless of amount of air entering the engine, the ECU will tell the injectors to spray the same amount of fuel. This causes another problem with the aftermarket intake.
The stock ECU has its fuel and ignition maps made based on the stock intake, and the supplied air the stock intake can take - of course with a certain degree of variation based on climate, temerature, etc. When you add a new intake to the car, which gives the engine more air - you can end up running lean on the higher RPMs. Ultimately - this can cause the engine to overheat and in rare cases die on you due to overheating (high AFR causes more heat). A more common problem is engine knock and reduced performance from the engine.
An aftermarket intake system can yield great results performance wise - but like all other engine parts - it needs to be tuned to perform its best
I noticed that Mugen doesn't make an intake for the Fit, but just a replacement hi-flow filter for the factory airbox. They do however, have headers and an exhaust available. So does that mean having that setup (hi-flow filter replacement, headers, and exhaust) would match the factory tuned ECU more perfectly than would an aftermarket intake? And thus, have a more optimal performance effect?
Old Jul 19, 2006 | 04:38 PM
  #113
docjim2's Avatar
K&N filter kit for a Jazz
I just got my FIT (2007) here in the USA. I have read that short ram intake decreases the milage a bit. K&N has said that they are having Fitting problems because of restrictive space. Maybe will have one out in Aug or Sep. I have a AT. And the AT at regular driving and less pedal (drive by wire) will shift at 4000 rpm except for 4th. My engine is supposed to be a VTECH L15A.
I am impressed with the car and don't expect to do as much as I did with my Accord Coupe V6...
Old Jul 30, 2006 | 09:40 PM
  #114
gary w's Avatar
Hey, I didnt know there was an actual speed limit in the P.I.? he he. Looks real nice. Could you please provide me with the cost for the intake and the total cost for installation. Thanks, take care. Gary w.
Old Aug 16, 2006 | 08:19 PM
  #115
2hot6ft2's Avatar
Intake size
Originally Posted by archonpsi
Greetings, I want to start with a K&N filter, the pipe could be in stainless steel? What is the right diameter of air entrance? ,sorry but i am a rookie in tuning.
To answer your question the intake is 2 1/2" as you can see by the intake that I made.
http://img60.imageshack.us/img60/5463/airintakeve8.jpg
If the picture shows up this is my first post here. I also made a pipe to turn it down to the bottom of the radiator but I suspect that water would get in when it rains. I have it out to sandblast it tomorrow.
I'll have to make a snorkle for it. By the way I used 409 stainless and I'm going to use a ceramic paint to help keep the pipe from getting hot.
Good luck it's not a difficult mod.
Old Aug 28, 2006 | 01:22 AM
  #116
KnifeEdge_2K1's Avatar
just to clarify on this a bit
in closed loop operation the engine is trying to get lowest emmisions possible by using only the oxygen sensor outputs to try to get as close to stoichemetric as possible
in open loop operation the engine takes different inputs (coolant temp, throttle position, map/maf sensor readings, air temp readings, etc.) and takes these values and compares to a chart stored in the computers memory to determine how much fuel should be injected
the argument that a new air intake lets more air into the engine is somewhat wrong, in most cases the stock airbox isn't a bottleneck and the amount of air entering the engine with an aftermarket intake is exactly the same, the aftermarket intakes are usually less restrictive and at top end conditions (by this i mean WOT or high rpm operation) allow more air into the engine thereby increasing volumetric efficiency
the ecu will see that more air is entering the engine through either a map or maf sensor and inject more fuel accordingly (this is ofcourse assuming air temp, coolant temp, throttle position, and all other relevent variables remain constant)
Old Sep 1, 2006 | 06:31 PM
  #117
coldstorage5's Avatar
Hey,
I would like to get some info on Air Intakes.
My last post was closed with out any real info given. ( hey moderator, relax, )
So, are( sorry) these Air Intakes worth it??
What do you think.
Will you get one?
Thanx
  #118
Fray Adjacent's Avatar
Senior Member
"So, do these Air Intakes worth it??"
huh?
Old Sep 1, 2006 | 07:11 PM
  #119
Joe_Schmoe's Avatar
Sure most of them work, as long as you don't expect too much. Lets all be honest here, we drive 100HP cars, and that 5 or so added HP is not much more than a placebo. Are they worth it... I guess it depends on how you want to justify it. I will add an exhaust to my car but thats because I like to hear it. But I don't know that I want to hear the intake too. I have no illusions that I will be able to run with any car that I couldn't before.
Old Sep 2, 2006 | 07:58 PM
  #120
Are any of these air intakes availble now in the US?
How much roughly??
thanx
