DIY: $50 (or less) Intake For The GE. CAI / SRI
Old May 18, 2010 | 05:38 AM
  #41
Lyon[Nightroad]'s Avatar
Originally Posted by j1nNju1c3
My Injen SRI is 2.75" filter and I would love to modify it to a 3" filter, is there anyway that I can do that??? Any input would be great!
You could go with 2.75" straight pipe and 2.75" to 2" coupler. These are tougher to find parts but they are out there.
Old May 19, 2010 | 05:00 PM
  #42
j1nNju1c3's Avatar
Thanks, I'll try to look for 'em. Where can one usually find pipes like this? Home Depot? Autozone?
Old May 20, 2010 | 02:25 AM
  #43
I doubt you'd find them anywhere but custom made online. Google: "silicone turbo couplers"
Old May 20, 2010 | 03:15 AM
  #44
j1nNju1c3's Avatar
Haha, when you said tough but it's out there, I thought you really meant that it was out there available somewhere, not just custom made. I will try that out though when my sri/cai shits out on me
Old May 23, 2010 | 08:20 AM
  #45
A small warning about using a 2 1/2" to 3" coupler on the MAF tube. If you bought a 2 1/2" to 3" coupler instead of 2" to 3" you will have to find a way to increase the diameter of the MAF tube. For me I just wrapped it in vinyl tape until it reached the desired width. However....
This can happen if you don't do a really good job wrapping it tightly and evenly. A portion of the vinyl tape was sucked inside of the tube, creating an obstruction. I strongly recommend not using a 2 1/2" coupler on the MAF tube. I have since corrected the problem a used a wider clamp to ensure it does not happen again but it would have been easier to just buy the correct coupler.
Old May 23, 2010 | 06:45 PM
  #46
fitisbamf's Avatar
did my intake last night took idk 20 min... with the cutting but i went a little different route i got a coupler from the tb to a 3in. 90 deg. bend to another coupler to the mas/maf then from that to my filter. i noticed the there was a smaller filter in autozone so i used that
Old May 24, 2010 | 01:04 AM
  #47
Very nice, that's why I like this, you have the freedom to install at any angle and with any filter you want. How's that look from rain though? Check it a few times after it rains to make sure you aren't running a risk of hydrolock.
Old May 24, 2010 | 01:10 AM
  #48
If anyone gets bored you can always try to make it "ram air" by removing the fog lights and using some of the acordion tubing they sell with these filters. Bonus points if you use a Y-pipe to get it to feed from both fog light housing.
Old May 24, 2010 | 01:13 AM
  #49
bmxman's Avatar
yeah I wouldn't run the filter facing the direction the car travels. You do run the risk of getting water into the engine...although I doubt you could get hydrolock unless someone fed a hose to it. There is the risk of some water making it way through the grill and your filter is right there waiting for it. It's also going to be pulling hot air since it's close to the header. You're better off positioning it like Lyon did.
Old May 24, 2010 | 01:21 AM
  #50
Only other thing I can think of is that it is directly above the radiator which should be a hot spot. I wish this engine bay had a little more room so you could route it to a fender or some other safe spot from there.
Old May 24, 2010 | 11:10 AM
  #51
Vash's Avatar
its prety hard to hydrolock a car, the filter would have to submerge
Old May 24, 2010 | 02:40 PM
  #52
Committobefit08's Avatar
Interesting. Why didn't you want to utilize the under hood scoop?
I would also recommend making some sort of heat shield on the left side of the filter. You don't want the intake to get heat soaked from the engine right next to it esp. since there is no real cold air being fed to that location directly.
Old May 24, 2010 | 09:40 PM
  #53
bmxman's Avatar
lol..why didn't I think of that in my post
Old May 24, 2010 | 10:09 PM
  #54
fitisbamf's Avatar
haha ya, i thought about pluging off the rad. plate that had holes for the intake but, when i noticed how the hood sat, taking off the scoop on the hood made the air flow straight to this filter location. then if any1 has noticed i dont have fogs.... i made a velocity stack fit in one of the holes for the driver side fog then i took 3in. dryer piping and made a ram flow right into the filter
and in the second pic. you can see the little tube from the ram. and there is a small area of the rad that you can see its blocked off so air is forced into the rad. ( for those with questions i will post in "what did you do...." thread)
Old May 24, 2010 | 10:50 PM
  #55
sk8pw1's Avatar
I was wondering if this will work on my 2008 Sport?
Old May 24, 2010 | 10:53 PM
  #56
bmxman's Avatar
well it's a custom mod so you can make it work
Old May 25, 2010 | 03:45 AM
  #57
You GD people have it so easy because you don't have a MAF. You can just hook any universal intake to it with no cutting
Old May 25, 2010 | 07:29 AM
  #58
I get you. Smart design. I would still utilized some sort of heat shield on the left side of the filter (between the engine and filter) to block off some of that engine heat. Utilize that ram air cold air even more. You obviously are good at fabricating stuff. A simple heat shield should be easy for you. You can probably use the stock air box screw hole locations to mount the air box.
Nice custom setup.
Old May 26, 2010 | 04:37 PM
  #59
j1nNju1c3's Avatar
I think you should make me one, since your down here in San Diego
Old May 26, 2010 | 09:43 PM
  #60
fitisbamf's Avatar
ok i will hahah what parts you want made?
