DIY: $50 (or less) Intake For The GE. CAI / SRI
Old Jul 9, 2010 | 07:58 PM
  #101
jnesselroad's Avatar
just finished this and my CEL came on right away. first time i started it, i forgot to actually plug the MAF back in, so i'm assuming thats what threw the code, but do i have to get this erased, or will it go away? any ideas?
Old Jul 9, 2010 | 08:17 PM
  #102
Lyon[Nightroad]'s Avatar
I've done that before! No worries. It will clear itself after a couple driving cycles but since you have changed the intake let's reset the ECU anyway and let it relearn the fuel trims. You can either disconnect the battery cable for a couple minutes or reach behind the ecu (black box behind the battery) and uncouple the top wiring harness (there are 3, make sure it's the top one since its the one that has the power wire) then disconnect it and replug it in. That will reset the ECU and clear the code but keep your radio stations. Let it idle for a few minutes to relearn the idle, then drive it as you usually do to let the ecu relearn the MAF, MAP, O2, IAT, etc. settings.
Old Jul 10, 2010 | 03:17 AM
  #103
GE swag's Avatar
anybody's check engine light come on?
i've been running mine for the past year and i noticed that it comes on after continuous-high-mile drives and also in the winter...
any solutions (besides unplugging the battery)?
Old Jul 10, 2010 | 04:38 PM
  #104
perfect, it reset itself this morning, but that's really good info on resetting the ECU without losing your radio stations!! thanks
Old Aug 23, 2010 | 02:20 PM
  #105
jcuecker's Avatar
Just did mine this weekend. I'm very impressed so far, especially with how the engine sounds when vtec kicks in. The fit feels about the same in the city but things open up quite nicely at highway speeds.
BTW I found a rubber 3" -> 2" connector at Home Depot in the plumbing dept.
Old Sep 1, 2010 | 06:15 AM
  #106
Awesome! Post a pic when you get a chance. I love seeing different interpretations of the design.
Old Sep 10, 2010 | 10:39 AM
  #107
Java^FiT's Avatar
Originally Posted by Speedee 09 Fit
I am curious to know if Spectre's part #9405 ( Spectre Performance - Official Site ) would work to prevent having to chop up the airbox. It seems to have the right size adapters inside so you wouldn't get a CEL. Just curious, good DYI!!!
Friggen awesome find, this looks perfect and i love that i dont need to cut anything. 35 instead of 18 for a replacement top with maf tube is fine with me especially since its still less that 280 or whatnot!
This will make my upcoming design work perfectly!!!
Check it out here
https://www.fitfreak.net/forums/2nd-...-air-idea.html
Obv, the prm would be replaced by this, the told me they cant custom make a 90deg turn with the maf section...WHY NOT!!?!? what good is saying you have a custom shop and make them to order if you refuse. grr,, its up to me now
Old Sep 10, 2010 | 10:45 AM
  #108
GE swag's Avatar
Can u all post some pic? I wanna see all the different styles and designs
Old Sep 11, 2010 | 07:48 AM
  #109
BobsUrUncle's Avatar
Bought rubber plumbing parts from the local hardware store, the coupler was too long for the assembly to fit between the manifold and ECU, so I had to notch it to give me more play in the assembly. The over sized 2-3" coupler allowed the assembly to pivot the filter. Bought a chrome tube from Ebay for the 3" extension/transition to the filter.
Old Sep 14, 2010 | 11:57 PM
  #110
Lil Blue's Avatar
I love well written DIYs.
Pulled up this thread at Checker(O'Reilly) today on my phone, bought the parts which cost me $57.05. (I bought the same filter as in the original example, so it should fit) I had already bought a new cover at Honda for $18.00 (since I am one of those people who has to have the stock part to easily go back to) so total out of pocket is $75 and now I have this to install.
after 20 minutes, stock unit pulled, new SRI installed
Old Sep 15, 2010 | 02:32 PM
  #111
jcuecker's Avatar
Finally got around to taking a pic:
Old Sep 17, 2010 | 04:42 AM
  #112
Looks good y'all! I'm happy to see so many different ones. Even though we all followed the same rough idea each one is unique to us as individuals.
Make sure you check on the breather filter from time to time. Mine was saturated with oil from months of use and was making it hard for the crankcase to vent.
Old Sep 17, 2010 | 11:22 PM
  #113
Lil Blue's Avatar
Has anyone tapped the breather line back into the intake at all?
Old Sep 18, 2010 | 01:42 AM
  #114
Java^FiT's Avatar
i was considering this for my new intake but i like the look of that little filter alot better
Old Sep 18, 2010 | 02:33 AM
  #115
Lil Blue's Avatar
The original purpose of the hose to the intake creates a slight vacuum which draws out any fumes created in the crank case. With out it, I believe we are relying on thermal expansion only to do that job.
Old Sep 21, 2010 | 10:47 AM
  #116
Java^FiT's Avatar
just got my parts today, will be installing after work today or tomorrow. Will post pics when done.
Old Sep 21, 2010 | 11:16 PM
  #117
Java^FiT's Avatar
Ok, got the parts and omg was I excited! lol Here is a pic of the assembled unit that I will be installing tomorrow.
Beautiful
One question for you guys, im pretty sure after I do this i need to do an ecu reset? is that right?
Also what is the procedure for disconnecting and pressing brake etc.... Detailed instructions please? I remember seeing them somewere i just dont know where.
Thanks in advance
Old Sep 22, 2010 | 06:19 AM
  #118
I've done alot of thinking about this. The only fumes in the crank case come from blow-by. Even brand new engines have some degree of blow-by. blow-by creates pressure. Pressure is relieved via the tube in question. The purpose of the vacuum draw is probably just to eliminate the need for an additional filter (which 99% of buyers would not want to have another filter to replace) Besides, that tube feeds oil and hot air into your intake tract. Old school big bock engines sometimes had filters directly on the pcv valve on the valve cover :/
Old Sep 22, 2010 | 06:25 AM
  #119
Beautiful
Thanks in advance
Might as well reset the ecu, the air is certainly going to be metered at least a bit differently with the spectre tube, so the fuel trims it has learned from the current MAF voltage profile are going to be slightly out of whack when you stick in the new one. It will relearn on its own but resetting the ecu should make it faster. Still, just gotta warn ya, the fit runs 'conservatively' for about 50 miles while it re-learns the fuel trims whenever I reset my own ecu. I'm far from an ecu tuner but closed loop seems to be at least somewhat 'adaptable' in the fit. As in the the fuel trims will change even durring wide open throttle based on MAF, IAT, maybe even from the wideband pre cat A/F-S (oxygen sensor)
""Also what is the procedure for disconnecting and pressing brake etc.... ""
huh? If you mean how do you reset the ecu just disconnect your battery or unplug the top connector to the ecu.
Should be interesting to see if the spectre MAF metering tube hurts or helps or just works. Either way, Nice work.
Old Sep 22, 2010 | 09:16 AM
  #120
Java^FiT's Avatar
ooo, ok i diddnt realise it was as easy as disconnecting the cable from the ecu, thanks for the heads up!
