DIY (GE): Parts needed for aftermarket double-DIN stereo
Old Jun 20, 2010 | 02:47 PM
  #121
jookybanana's Avatar
^what compact disc square? do you mean the air bag light? that is just held on by 2 screws just transfer it from your stock bezel to the new one, same with the hazard lights button, its got 2 screws too just transfer it from stock to the new one
Old Jul 11, 2010 | 02:04 PM
  #122
Cutstain's Avatar
Originally Posted by blythe
Alright, I know a lot of folks are wondering what you need to install an aftermarket double-DIN stereo in a GE Fit. I've got an '09 Sport, and here's what I used (successfully):
  • Stereo (I picked the AVIC-F90BT)
  • OEM Honda Navi dash (I got mine at Bernardi) - 77251-TF0-G01ZA
  • OEM Honda Navi bracket (I got mine at Bernardi) - 77255-TF0-000
  • Metra wiring harness - 70-1729
  • Metra antenna adapter - 40-HD10
  • Used the Metra kit for the Honda Pilot for the faceplate surround. It's not a perfect fit, but it works.
I'm not doing a full DIY because I think the installation is pretty straightforward. I've never wired anything before or worked with car electronics before, and it's not a big deal. The metra wiring harness comes with a listing of what color wire matches what, and you just have to solder it to the wiring harness for the F90BT or whatever stereo you end up with. After that, you pretty much just plug everything in and you're good to go. You'll have to run the USB cable from the F90BT to where the USB cable is in the glove box (if that's where you want it to go), but you can just pull out the lower glove box and it's a piece of cake.
Questions welcome.
Hi,
I'm a little confused.
What's the difference between (in function)
and
Old Jul 11, 2010 | 03:42 PM
  #123
the oem honda navi braket, is the console/dash part of it,
but the problem with the oem bracket is it is made for the oem navi heaunit, so it will leave a gap around the aftermarket headunits, cause they are smaller 2din
so the metra honda pilot kit has a trim ring that is used to fill that gap
Old Jul 11, 2010 | 04:30 PM
  #124
Cutstain's Avatar
I see; thanks for clarifying.
So if I want to go OEM, I need a workaround such as using the metra pilot kit.
Overall, is the metra honda fit kit a better fit then?
Old Jul 11, 2010 | 07:21 PM
  #125
yes, i think the metra honda fit dash kit is a better fit for the aftermarket headunits, but in my opinion the metra kit's color is not as close match than the oem, which is why i went with the oem kit, and live with the less than perfect fit for the headunit
Old Jul 11, 2010 | 07:54 PM
  #126
Cutstain's Avatar
decisions, decisions... thanks for your input.
Old Sep 11, 2010 | 12:21 AM
  #127
suttonschinook's Avatar
Does anyone have any pics of how to mount the pilot trim ring using the factory panel. I have the kit and the panel, just want to see how you guys did it so I don't screw anything up.
Thanks!
Old Oct 5, 2010 | 11:31 PM
  #128
pdstc's Avatar
maybe it's burried in these post somewhere, but wouldn't a dash kit that's NOT designed to ONLY fit the OEM navi work better such as this one:
Scosche HA1708B - Dash Kits - Sonic Electronix
Just thought I'd point it out to make everybodies job easier if it wasn't mentioned already. That way you wont need to buy another trim piece to make it fit. Plus it's cheaper than the OEM dash piece but looks like it includes the brackets as well...
Old Oct 6, 2010 | 04:12 PM
  #129
jcuecker's Avatar
I tried the Scosche kit the first time but switched to the OEM bracket and trim. The aftermarket ones are "OK" but you will notice there is a slight color difference and the fit and finish isn't as nice.
Also the OEM is metal and mounts to the rest of the dash with screws. The aftermarket solutions are all plastic. I could rip out the entire stereo with one good tug, its much harder with the OEM.
Old Oct 6, 2010 | 10:35 PM
  #130
mugen666's Avatar
I've always said, you cannot beat OEM.
Old Oct 18, 2010 | 01:29 PM
  #131
Java^FiT's Avatar
Im just gonna throw this out there because im not sure if anyone said it but you get an entire installation kit free (129.00 worth) when you order the receiver from crutchfield.com
Ive used that site for every car ive owned because its just a dang good deal to get the bezels, and harnesses free with almost every receiver either double din or not. Check it out.
Old Aug 29, 2011 | 04:06 PM
  #132
lowkeymods's Avatar
I want to replace my Metra Kit with OEM for the color match. So to clarify:
1) Do I just need the OEM Honda Navi dash - 77251-TF0-G01ZA & OEM Honda Navi bracket - 77255-TF0-000?
2) Is it safe to assume the Metra Kit trim piece for the Fit will be able to fill the gap in the OEM kit?
Thanks so much everyone!
Old Aug 29, 2011 | 05:51 PM
  #133
1- yes
2- no, the metra kit trim piece for the honda fit will not sit flush with the oem kit, you need to get a metra kit for a honda pilot, which is alot cheaper then the honda fit kit metra kit, i think the honda pilot metra kit is only $12
Old Aug 29, 2011 | 07:30 PM
  #134
V-fit's Avatar
1- yes
I always see use a honda pilot kit, but theres never any specifications as to what model year honda pilot.
Old Aug 29, 2011 | 08:39 PM
  #135
Java^FiT's Avatar
Why is it that no one just goes to crutchfield.com and buys their kit. I have it for mine and its perfect, comes with trim rings and everything...
Old Aug 29, 2011 | 10:21 PM
  #136
crutchfeild kit is the metra i believe and to some the metra's color is slightly off, and also i like the oem one better because it uses metal brackets which makes it harder for thieves to steal the headunit, the metra's plastic backets seems like they can snap if sonemone pulled on the unit hard enough
the honda pilot kit you need is metra 95-7861, it is the 2003-2008 honda pilot double din dash kit
Old Aug 29, 2011 | 11:56 PM
  #137
Java^FiT's Avatar
The one I received from crutchfield is the top one in the pic you posted and it came with the necessary trim ring:
Old Aug 30, 2011 | 12:00 AM
  #138
yes the top is metra, and bottom is the oem, notice the top one is more grayish, and the oem is brownish-gray color
Old Sep 20, 2011 | 11:24 AM
  #139
V-fit's Avatar
Originally Posted by 2JZfan
One tip on the wiring - and I plan to make a separate post about this to make it more obvious to hopefully save others the trouble - the Metra harness adapter seems to have the "dimmer" and "illumination" lines swapped. The "dimmer" one goes from ground to +12 when the lights turn on. This is what the aftermarket HU's want. The "illumination" one, which is supposed to do what I just described actually is a variable voltage that changes when you dim the dash lights. Hooking this up the wrong way can lead to blown fuses or fried dash lights so it's important to test beforehand. I'm glad I did. I also downloaded the factory wiring diagram from Helm and it verified what I saw in testing - the "illumination" wire was being hooked to what the factory calls "ILL-" (pin 1 on factory connector, red wire) and the "dimmer" wire was being hooked to what the factory calls "ILL+" (pin 13 on factory connector, grey wire)... So bottom line, your HU's illumination wire needs to be routed to the grey ILL+ factory wire, regardless of how the Metra harness is labeled.
Other than that, everything else on the Metra harness matched up properly...
Does anyone have any confirmation that this is the case with the metra 70-1729 wire harness? I'm about to install my deck in a couple of days, and wanted to see if there is any insight about this problem?
Old Sep 20, 2011 | 08:41 PM
  #140
B-Blue's Avatar
Yeah I'd like to know this as well.
