DIY (GE): Parts needed for aftermarket double-DIN stereo
Old Sep 22, 2011 | 03:11 PM
  #141
V-fit's Avatar
Originally Posted by V-fit
Does anyone have any confirmation that this is the case with the metra 70-1729 wire harness? I'm about to install my deck in a couple of days, and wanted to see if there is any insight about this problem?
Well I figured this out on my own, the dimmer wire on my pioneer HU was orange/white, and putting it to the orange/white on the harness didn't dim. I routed it to the orange wire on the metra harness and now the unit dims.
Old Oct 5, 2011 | 02:48 PM
  #142
B-Blue's Avatar
I think I ran into the same issue as you V-fit. When I looked into the color codes for the Metra wire harness, it says:
Orange - Illumination
Orange/White - Dimmer
On my Clarion CX501 install instructions:
Orange/White - Illumination lead
According to Crutchfield the CX501 does dim. It tells you to connect the orange/white to each other. But solid orange doesn't connect at all, don't I need that?
Old Nov 10, 2011 | 01:30 PM
  #143
wakali's Avatar
Did you figure out what wire to connect to what for dimming? Thanks again in advnace.
Old Nov 10, 2011 | 02:47 PM
  #144
B-Blue's Avatar
Both worked for me. I did one, turned the lights on, dimmed, same with the other.
Old Nov 10, 2011 | 02:56 PM
  #145
wakali's Avatar
Thanks. You are most helpful.
Old Dec 12, 2011 | 01:19 AM
  #146
Vash's Avatar
so following the stock instructions worked and using orange as a dimmer worked as well?
Old Dec 12, 2011 | 03:03 PM
  #147
1SickVeilsideZ's Avatar
Installed my PIONEER AVIC with the metra harness and blew 2 fuses before I found this thread.
The Orange Illumination on the metra harness is way wrong and it blew the fuse for the radio itself and then the fuse for the HVAC.
Old Dec 12, 2011 | 04:47 PM
  #148
Vash's Avatar
so what do i need to do to NOT blow fuses? my stuff come in today.. seee...
Old Dec 12, 2011 | 06:15 PM
  #149
^^What unit are you running?
Old Dec 12, 2011 | 09:41 PM
  #150
Vash's Avatar
iam running a clarion vx401
Old Dec 12, 2011 | 11:18 PM
  #151
Vash's Avatar
ok clarion headunit here... iam about to weld together the wires tomorrow morning... just follow the colors right? or are the colors wrong?
Old Jan 4, 2012 | 12:56 AM
  #152
True Adrian's Avatar
Will probably be my first modification I do come this summer
Old Jan 21, 2012 | 11:17 PM
  #153
fbpearce's Avatar
Quick question, how do you fit the honda pilot metra trim piece onto the pioneer with the factory honda fit dash piece (I can't figure out a way to lock it in)? Thanks!
Old Jan 23, 2012 | 03:57 PM
  #154
wakali's Avatar
I never been able to fugyre that out. I just left it on without locking it and it never fell off, so I'm leaving it alone.
Old Jan 23, 2012 | 08:34 PM
  #155
lowkeymods's Avatar
Yep put it in, put tape on the back, and let gravity do the rest.
Old Jan 23, 2012 | 10:30 PM
  #156
nyczzzjohn's Avatar
If anyone is looking for the harness, dash kit and antenna harness I have a set. It came with my radio from Crutchfield, but I didn't need it.
Old Jun 24, 2012 | 08:26 PM
  #157
connor55's Avatar
Did you ever figure what to do not to blow a fuse? I'm getting the jvc kwnt700, and am hoping the metra harness and antenna adapter work with this.
Old Jun 24, 2012 | 09:27 PM
  #158
Rampo's Avatar
I don't think the Clarion is able to dim using the Fit's dash light dimmer control. I have the NX501 with the orange/white illumination wire and the Metra harness with the orange, and the orange/white wire. I went crazy looking all over different threads for the correct connections and just ended up more confused because of conflicting information. In the end I didn't connect any of these wires. What I believe is that the Clarion looks for a 12V signal when you turn on the headlights so that it can dim the display for night driving. If you use the Metra orange/white wire the Clarion does not see the correct voltage. There were even rports of electrical damage if you go orange/white to orange/white. So this leaves the option of connecting the orange/white on the Clarion to the orange on the Metra. I was thinking of making this connection when I had my HU out this weekend to connect a microphone. Then I decided to leave well enough alone. I don't really need my HU to dim. It's not all that bright to begin with. Btw PM me if you want my wiring diagram. It has the connections for the antenna adapter, as well as the parking brake bypass.
Old Jun 24, 2012 | 09:52 PM
  #159
connor55's Avatar
hmm I supposed its possible to test it with a multimeter or test light. then you can find out for sure what does what. Reading an older post on this thread, it would seem that the illumination and dimmer pins on the metra harness should be the other way around. apparently following their layout can cause fuses to blow.. I just ordered the metra harness and antenna adapter. Hopefully these will work properly with my JVC unit. I will have my installer double check the dimming and illumination pins just to be sure the info in this thread is correct.
Old Jun 24, 2012 | 10:24 PM
  #160
Rampo's Avatar
Crutchfield:
"Illumination Dimmer: The receiver's display automatically dims to a preset brightness when the vehicle's headlights are turned on. The wiring harness includes an orange/white lead that should be connected to the vehicle's parking light circuit in order for the dimmer feature to operate."
From other research it's pretty clear that you shouldn't connect the Clarion orange/white to the Metra orange/white "dimmer" lead. Apeears that you can connect the Clarion orange/white to the Metra orange "illumination" lead. This should dim the unit when you turn on the headlights, however you will not be able to use the vehicle's dimmer rotary control to adjust the level of illumination.
If you leave everything disconnected the HU will remain the same brightness regardless if the headlights are on or off. You can manually adjust the brightness through the HU controls.
