What is wrong with my Fit??
Old Jul 25, 2012 | 09:49 AM
  #541
seb9316's Avatar
Originally Posted by malraux
What media outlets haven't discussed it? What does the decline in most of Hondas offering have to do with your fit? If people here were telling you to trade to fit for a civic, then the disappointing civic resign would be relevant. But noone here is white knighting Honda in general, just that
1. Based on your descriptions, there is no mechanical defect in your car.
2. The millage numbers you give are in line with the published EPA numbers and the variance is most likely explained by driving style and local conditions.
Congrats! You finally, without realizing it, figured out what I did- that, since there is no mechanical defect in the car, Honda exaggerated their real world numbers to sell cars. It's the only explanation. Explain how, otherwise, I could possibly be getting as good (or better is some cases) fuel mileage around town, in a quite larger, more comfortable vehicle that I am driving under the same conditions and in the same style.
Did I finally get through to you?? That you need to stop for a moment and back up and see the forest instead of the trees??
Old Jul 25, 2012 | 10:00 AM
  #542
malraux's Avatar
Hondas reported EPA numbers are in line with independent tests like those done by CR. there's no evidence of dishonesty here. Beyond that, different cars are different.
Old Jul 25, 2012 | 10:45 AM
  #543
david223's Avatar
Nothing Wrong
There's nothing wrong with your Fit. It's designed to shift very frequently because the engine is so small. Also, the drive by wire feature makes the gas pedal super sensitive. I picked up my 2012 Fit Sport Auto Trans on June 8th. It acts just like yours does. On the highway it downshifts on every hill. I'm a retired guy in my early 60's and I've always been a slow gentle driver. I also think that a car this small and light with a very small engine should get better gas mileage than it does. Now, overall I like my Fit Sport, but the gas mileage and ROAD NOISE is not good.
Old Jul 25, 2012 | 11:36 AM
  #544
fujisawa's Avatar
Originally Posted by seb9316
Your friend sounds like a smart guy, longtime Honda fan due to past ownership with great luck, and now sees the downward trend Honda has taken. They don't make anything impressive anymore, and the fact that the media lauded so much praise over such an underpowered, average mpg car, it makes me wonder how Honda got them in their pocket.
The difference between him and me is that I also think the Fit is the best thing that Honda makes .. but I DO like it
I also like the Accord, although, for very different reasons. But overall dhe mainstreaming trend that Honda has been on for several years, and the rise of the Yen, has caused a decline in their focus on intelligent, innovative engineering solutions and an increased focus on cost savings while still meeting benchmarks.
There are a few simple fixes (not even innovative) that Honda can and probably will do, starting with the next Accord. But take just the Fit as an example - what would make it back at the top of heap vs peers?:
1. Direct & port injection (better fuel economy)
2. CVT (even though I would hate this)
3. Aero tweaks to encourage airflow separation.
4. Cloud-based infotainment system a la sync
5. Independent rear suspension (some packaging downside here)
6. A crossover option. Cheap to build on the same body (a sedan is less so), better profit margins.
7. Domestic production. Allows more cost flexibility.
So you can see I am not blinded by the badge. The Fit could be better than it is, even though, I would not like some of the things I mentioned above. And they all add $$ except the last one. No free lunch
And heck if it were up to me I would scrap that CRZ and make them turn out a simple 2+2 convertible on the Fit wheelbase. The same packaging that makes the magic seat possible also makes a convertible easy to engineer. This definitely will not happen.
Old Jul 25, 2012 | 12:48 PM
  #545
kgb4187's Avatar
If the rear headrests are such a problem, then I've got a pretty good explanation of why your fuel economy numbers are lower than expected.
I wonder what he would say if you pointed out the heads of the rear seat passengers block the view regardless of headrest position...
Old Jul 25, 2012 | 01:05 PM
  #546
kgb4187's Avatar
So you didn't do research into real world numbers, instead relied on a number, expressly stated, to only be used for comparison shopping and may not reflect real world numbers? You breathe through your mouth, don't you?
Old Jul 25, 2012 | 05:04 PM
  #547
Rampo's Avatar
Per Edmunds: Here's Why Real-World MPG Doesn't Match EPA Ratings
Why Your Car Could Have an MPG Gap
Here's Why Real-World MPG Doesn't Match EPA Ratings - Edmunds.com
Old Jul 25, 2012 | 05:46 PM
  #548
Goobers's Avatar
Nothing, he'll just ignore it and pretend you didn't say anything.
Originally Posted by Goobers
I just noticed one of his complaints...
Rear passengers HAVE to raise the head rest to sit comfortably, but that SEVERELY limits the view of the driver.... right?
Um, if you have a rear passenger, wouldn't their head rest be behind THEIR head? So therefore, wouldn't THEIR head actually be what's blocking your view?
As for the spark plug complaint not being mentioned in reviews.... simple, car reviews are done from driver's perspective, not a mechanic.
Personally, if you're comfortable enough to be yanking spark plugs, who gives a damn about a cowl that's "in the way"?
Nitpick much?
Old Jul 25, 2012 | 09:13 PM
  #549
fujisawa's Avatar
I hate when mai passengarz have heads! Arrrg, heads are so annoying! They block the viiiieeeewwww out the BACK! I make all my passengarz remove theiyar hedz before boarding! Rear visibility now GREAT! Passengar comfort not known, they have yet to respond to survey!
At least the headrests retract. They could also block the view and NOT retract, a problem Honda fixed in its hatchbacks after poor feedback on the pre-05 CRVs, and has been attendant to since.
Peace
Old Jul 25, 2012 | 10:02 PM
  #550
Goobers's Avatar
This thread is going nowhere.
The OP refuses to acknowledge that its is simply his driving habit that isn't giving him that extra 1 MPG he claims Honda failed to deliver. A fact proven by being able to actually achieve OVER the EPA estimates on highway driving when he forced himself to drive the way people have been recommending. And that was being consistent and at a more economy friendly speed of 55-65 MPH. But he won't adjust his city habits to compensate for the bigger fuel drain.
Then brings up other issues. While admittedly, a number of them CAN be valid to some degree and a few are strictly personal (some like, some don't like the exact same aspect). But then makes up garbage arguments... a retractable rear seat head rest being in the way... when having passengers in the rear seat?!?!?
I'm half expecting him to throw up a picture of the GD Fit's head rest to "validate" his argument, despite supposedly having GE Fit.
Old Jul 26, 2012 | 10:10 AM
  #551
SgtBaxter's Avatar
City driving is a big fuel drain. However, over the weekend going from Baltimore to Hersheypark up I-83 and back I was averaging about 80-85mph with the A/C on, and I pulled a little over 38MPG for the round trip. 184 miles, used 4.81 gallons. The only time I was doing significantly under 80 was around York, PA where there was construction, and a little stop and go traffic.
This car is plenty capable of great mileage at fast highway speeds.
Old Jul 26, 2012 | 01:19 PM
  #552
kgb4187's Avatar
You are really dumb. Like, really really dumb. I hope the sale goes quickly so you may never post here again. Amen.
Old Jul 26, 2012 | 01:41 PM
  #553
SgtBaxter's Avatar
I'm not the one unhappy with the car, dumbass.
Old Jul 26, 2012 | 05:11 PM
  #554
david223's Avatar
I wonder what I'm doing wrong. With the cruise control on and highway driving at 60mph I can't even get 38mpg. I like many things about my Fit Sport but the fuel mileage is not one of them
Old Jul 26, 2012 | 05:57 PM
  #555
Jango_Fit's Avatar
Ha. Try gettin no more than 28mpg ever! And thats on my 2011 auto and this after trading in my 09 for it wich did wayyyyy better! Lol im over it, honda made excuse after excuse after excuse. I finally gave up. I have a love/hate relationship with my fit due to this! Freakin sucks!
Old Jul 26, 2012 | 07:11 PM
  #556
Goobers's Avatar
There are too many factors for most to give a reason why, let alone a noobie like me to attempt to explain.
All I can say is, if I cruise (via control or my foot) at 80 MPH on the highways around Chicago, I will pull similar MPG numbers as if I were driving city streets (or suburban streets)... that being about 30 MPG.
Old Jul 28, 2012 | 07:32 PM
  #557
Steve244's Avatar
I was somewhat nonplussed this week to experience Pig-Fit. Driving 700 miles to Key Largo it sucked the fuel going 85mph down the FL Turnpike (get a sunpass before trying this yourself!). I could barely manage 33mpg. I think I shall write a pointed letter.
Coming back was 35mpg. Must've had a tail wind.
edit: the A/C performed well though. Leaving out in FL sun all morning, it had the inside comfortable in about 5 minutes. What's up with that? (no freeze-ups either). And it wasn't nervous around big rigs (might be the better tires). And my butt didn't hurt (much).
Old Jul 29, 2012 | 01:05 PM
  #558
SilverBullet's Avatar
Whats your point and who is the pointed letter too? Florida state police for driving reckless or to Honda to say I was beating on the car and the mpg was not as promised.
Old Jul 29, 2012 | 01:19 PM
  #559
AC7880's Avatar
Open a dictionary (book or online) and look up "sarcasm".
He's making fun of the OP, not being serious.
Old Jul 29, 2012 | 01:33 PM
  #560
Thanks steve244, when did you become sarcastic?
