How many miles on your 2009-2013 Fit?
Old Nov 18, 2021 | 11:49 AM
  #321
Nibis's Avatar
Awesome, I hope to get 300 to 400
Old Nov 25, 2021 | 11:34 AM
  #322
usert_l's Avatar
I'm more interested in keeping mine running as long as possible in the long run, not mileage, because it doesn't get driven that much daily. I think it has about 82k miles right now (2013 model). It's going to be a loooong time before it gets close to the 250k milestone.
My parents Camry was close to hitting 250k before the transmission had some major problems. I don't drive my Fit hard and maintain it regularly so I hope it continues to stay in top shape. I think I want to get at least 20 years out of this car.
Old Nov 25, 2021 | 06:21 PM
  #323
john21031's Avatar
Keep in mind that life span of the engine means a limited number of heat cycles... heat up-cool down, so even if you haven't driven much but got the engine warmed up and cooled down often enough, your engine will be subject to wear and eventual failure, possibly sooner than a very high mileage engine.
When the engine warms up, parts expand at different rates and cause deformation. Head gasket and cylinder head are the main components that suffer from these cycles... engine block does too but to lesser extent.
Old Nov 26, 2021 | 12:15 PM
  #324
NancyL's Avatar
Only 49k on my 2009! I have a very short commute and on the weekends we generally use my husband's car.
Old Nov 26, 2021 | 01:38 PM
  #325
Mister Coffee's Avatar
If you put the car in a jar with some formaldehyde, it will last even longer.
Old Nov 26, 2021 | 01:59 PM
  #326
steve37's Avatar
^^^ don't forget to throw in a few desiccant packs!
Old Nov 29, 2021 | 10:33 AM
  #327
usert_l's Avatar
Hmm ... makes me think about electric vehicles. Electric motors don't go through these thermal cycles like internal combustion engines do.
Old Nov 29, 2021 | 12:46 PM
  #328
Frenzal's Avatar
Yes they do. The insulation degrades over time with the heat-cool cycles.
  #329
Pyts's Avatar
I wouldn't fret too much on the matter. My girlfriend's 07 Escape Hybrid has 240k on its original engine with nothing more than oil changes and TSBs tended to. That thing cycles on and off quite frequently (though it does utilize a cylinder head temp sensor which I'm sure gets some input on the cycling.)
Engines just need tending to. Even sitting on a shelf, a paper gasket is only good for 20 years at most. I'll be pulling the head off the L15 in the coming year or two, just to de-goop and freshen up. One thing I love about our engines is the gaskets. They're so robust, multiple (at least on the intake side) are allowed repeated use in accordance with the service manual.
I'd offer that the greatest threat to modern machinery is sitting unused. It lets lubricants drip out and/or dry up. Then when you go to fire a thing up it, it fails. @julianachos made it so far because he stayed in motion (and maintained, of course.)
Old Dec 3, 2021 | 10:34 AM
  #330
Nixx's Avatar
GP1 hybrid, JDM 220.000km 2010y
Old Dec 3, 2021 | 10:50 AM
  #331
Dduelin's Avatar
165,xxx on a newly acquired 2009. It has a P0847 code and a noisy left front wheel so I have a little work to do. I've been working on my own stuff for over 50 years.
We have had many high mileage Honda automobiles & motorcycles in my family. 1995 Civic EX coupe 199,xxx, 2000 CR-V 260,xxx, 1999 CR-V 245,xxx, 2005 ST1300 179,xxx. I expect not much different with this Fit.
Dave
Old Dec 8, 2021 | 09:38 AM
  #332
siguy's Avatar
100,700 on 2013 Fit Base. Just turned 100,000 a month or so ago.
Old Dec 17, 2021 | 01:37 PM
  #333
kortnie's Avatar
Holy Hannah!
Is it a manual? And, can I buy it from you?
Old Dec 17, 2021 | 01:44 PM
  #334
kortnie's Avatar
My '09 Sport MT just turned 13yo two months ago, and she's rockin about 185k miles. ^_^
Replaced tensioner last year - It got noisy after sliding over a giant ice chunk (soul crushing, I know).
Replaced condenser early on - Rock bounced in from underneath. I've since learned to not ride close behind semi trucks.
Old Dec 24, 2021 | 02:57 AM
  #335
Buzzle64's Avatar
Originally Posted by rossftn
I hit the 175,000 mile mark on my 2009 Fit last week. These are the only problems I have had:
- Bad battery at 20,000 miles. It never stranded us. Dealer replaced for free.
- Belt tensioner was making noise at 100,000 miles and I replaced it. Old tensioner tested fine upon removal. It was probably fine and I was just paranoid because I had just replaced the drive belt.
The only maintenance I have ever done was what the maintenance minder told me to do. All oil changes have been at 10,000+ miles. We have had zero problems other than what has been described above, however the car is definitely slowing down a bit at this point. The MPG has gone down by about 3-5, and it's slower on acceleration. But it's still running strong, and I hope to get another 100k out of it. Love this car!
2009 Honda Fit Sport-at 100,000 miles my ignition coil had to be replaced, but other than that no problems
Old Jan 2, 2022 | 07:43 AM
  #336
Fit Angel's Avatar
Original
ALMOST
39,000
2010 Base Fit original miles
Old Jan 4, 2022 | 01:41 AM
  #337
moolman's Avatar
2009, got it Dec 2008, brand new. 174k. Paid invoice back then, which right now for a car is impossible...haha .. even haggled for the 8y/120k warranty for a $1000. I never go with extended warranty but for $1000 since I saw that it was posted here, I couldn't resist, especially since towing came with it and I don't have AAA. It worked out. Navigation went out, the control know wouldn't go left, they replaced the whole unit, which is over $1000 just got a knob. Replaced leaky shocks in the rear, so with 8 years of towing coverage, I came out ahead.
Old Jan 8, 2022 | 07:53 PM
  #338
Fit09Pete's Avatar
Original owner of 2009 AT Sport and just hit 200,000. Been amazing car! Started running winter tires 4 years ago to make winter driving a breeze Had both transaxles replaced under the Honda recall. Other than that I have done and actually enjoyed all the maintenance myself plugs, belt, brakes, fluids, new headlight lenses, and the oddest thing…every 2 years I pull the starter to clean and lightly lube the internals to resolve the solenoid hanging up/grinding on the flywheel. Hate that noise lol
At this point, I joke with my wife about going for 300,000 😁
Old Jan 8, 2022 | 08:06 PM
  #339
steve37's Avatar
Nice car! Does the extra lubeing totally eliminate the grinding when starting?
Mine is fine in the summer...but when the temps get around freezing or lower, it grinds every start. I keep wondering how harmful it is?
btw...your tire sensors might need new batteries!
Old Jan 8, 2022 | 08:48 PM
  #340
Fit09Pete's Avatar
Thank You! The ole Honda rear wheel well rust has started, but what can you do in the rust belt lol. Yes, the grinding is completely eliminated and like you it’s when the cooler temps start as early as the Fall that it will start hanging the starter on the flywheel. I did some research and learned it can cause flywheel issues after a while…I just got tired of my neighbors or coworkers staring with a concerned face when I started her up with that grinding noise lol. Removing the starter tips I learned from watching vids on line…it was a challenge the first time but I have it down to a 1-2 ours now. Regarding the tire sensor dash light, I deal with that during the winter while I run my blizzak tires on steel rims….all returns to normal and the dash light goes out when I change to the factory alloys in the summer that have the tpms sensors installed 👍
