Quality Issues with new Fit
Old May 11, 2015 | 08:36 PM
  #581
thedrummingfish's Avatar
This will sound super simple, but I did it myself a few times. Make sure you aren't bumping the lanewatch button at the end of the stalk when you signal or the camera will stay on until you hit home or press the stalk button again.
Old May 13, 2015 | 04:32 AM
  #582
FITEsq's Avatar
Originally Posted by Maxxx
Hey guys, I've had my new 2015 ex fit for a week and I noticed twice that after turning right, the camera stayed on until I pressed the home button ??
Any ideas
The lanewatch has it's own settings for when you want it to engage or not engage.
Check the owner's manual for lanewatch, and then Settings Menu on Screen while Lanewatch is engaged and see if that helps.
If not, consult the service adviser at Honda.
Old May 20, 2015 | 06:15 PM
  #583
sonicfox's Avatar
I just bought my new Fit Saturday, so no quality problems...yet. Hopefully, never!
We are quick to blame the new Mexico plant, but after two years, my Prius C, built in Japan, ended up with a tail light filled with water and ac/heater buttons that intermittently wouldn't work. Before that, I had a Nissan Versa built in Mexico that had no quality issues. Are we blaming them because it's a NEW plant or because it's in Mexico?
Old May 21, 2015 | 01:22 AM
  #584
hans471's Avatar
After all these years with our '07 Fit we sprung for a '15 model (built in March of this year) this week. The fit and finish on the car were absolutely first class. The doors were precisely aligned, the gaps so even it was hard to believe. The door profile and the adjoining panels were precise. The paint is beautiful. I am very happy with it.
We skipped the second generation and waited for the third. Glad we did as I really like this car. Now my '12 CR-V seems so "old tech" and my '07 Fit seems ancient.
Old May 21, 2015 | 11:03 PM
  #585
festiboi's Avatar
The clutch pedal on my Fit was yet again squeaking. Took it back to the dealer this week and got it back on Tuesday. So far, it seems to be better. Instead of just oiling it with WD-40, they adjusted the spring's tightness. Seems to have resolved it.
Hope that helps the few of you who have this issue
Old May 22, 2015 | 01:45 AM
  #586
FITEsq's Avatar
2015 FIT Windshield Stress Fractures (Cracks)
This may be just my car, but it is very unusual to experience this.
My FIT is 2015 production, just 2 months old.
Detailing the car this week for the first time, noticed cracks in the Black section lower passenger side corner. They are not visible from the inside as they all sit below the dash line. They are also partially covered by the short wiper. Even looking at them directly, they are not easy to see, and require direct sunlight. They are easy to miss, hidden in the black, and could have been there since the car was delivered 2 months ago.
There is spidering off of the main crack line and it ends at the edge of the window. There is no damage at all to the windshield on the outside--perfectly smooth.
Took it to an auto glass repair place for an opinion. Was told that they are stress fractures of the glass possibly caused by improper installation of the windshield unless the windshield was damaged before installation.
Took it to the Dealer. Service manager inspected. He pulled away the molding from the passenger side to see that crack originates at edge of the window and travels irregularly approx. a foot horizontally. He said it was a stress fracture, and they will replace it, and ordered a new windshield.
He shared that newer windshields are lighter, thinner, and subject to more fracturing than the windshields of old in order to reduce weight and increase fuel economy.
I have never had stress fractures of any windows in any other cars that I have owned including another Honda.
Follow-up:
-New Windshield was installed today under the warranty ($678.00).
-Multiple fractures up to 12 inches were found on the inside running to the side of the glass in the black area.
-They will send the fractured Windshield to Honda for inspection per their request.
-Service adviser did not believe that it was systemic, and thinks this was an isolated incident on my car only.
-Honda's glass installer said the original Windshield was not aligned properly--was not centered and off to one side too much. He said that could have been the cause, but not sure. He said misalignment can happen on the assembly line when the robots lay the glass down or the glass was dropped too hard causing a slight fracture that expanded in the heat.
-He took care to align and center the new windshield properly.
Last edited by FITEsq; May 27, 2015 at 07:52 PM. Reason: Follow-up on Windshield Today
Old May 27, 2015 | 09:35 PM
  #587
trevolio's Avatar
So we had hail here in slc utah today so after I of course carefully inspected my car, looking at the rear bumper, it looks to be painted( and not well done) looking at the rear hatch the gap left to right is almost double on the left side than the right, and looking at the hood its not aligned ether and by the looks of things the left fender actually sticks farther forward almost half an inch, just contacted my dealer we'll see what they have to say about the issues
Old May 27, 2015 | 09:49 PM
  #588
FITEsq's Avatar
Originally Posted by trevolio
So we had hail here in slc utah today so after I of course carefully inspected my car, looking at the rear bumper, it looks to be painted( and not well done) looking at the rear hatch the gap left to right is almost double on the left side than the right, and looking at the hood its not aligned ether and by the looks of things the left fender actually stickes farther forward almost half an inch, just contacted my dealer we'll see what they have to say about the issues
I have noticed that on my FIT that the hood is not aligned as exact as it could be, nor are the bumper covers, and some other parts. I would not say any are off more than 1/8 of an inch +/-. I am going to give them the benefit of the doubt right now, and chock it up to normal production variance.
Today at the Honda dealer I was waiting for my car to be done and was inspecting the New Honda HRV in the showroom that comes from the same factory as the FIT in Mexico. On the HRV, I also saw that the hood was aligned unevenly like on my FIT. One side was closer to the body than the other side--uneven gaps.
Please let us know what your dealer says.
That would be very helpful.
Old May 27, 2015 | 10:19 PM
  #589
trevolio's Avatar
Ive also had an issue with my dash the vent area on the drivers side sticks up about 1/2 inch took that one to the dealer and they removed the part and said because it had no broken tabs only way for replacment would be for me to buy one... for 91 dollars... then when I turned that down they offered to GLUE it down... we'll see what they say, but its not just the alignment on my hood, the fenders them selves are moved forward, not left to right, although the gap at the rear of the fenders are the same...
Old Jun 4, 2015 | 01:04 AM
  #590
FDFanboi's Avatar
I bought my GK Fit on the October of 2014. I have never really had a major problem with the early models after 7 months of ownership. The only thing I can really complain about is the 7 inch infotainment system on the EX being extremely slow and unresponsive at times. Also some of the gaps on the doors are very inconsistent.
Old Jun 4, 2015 | 06:40 PM
  #591
GotFitB13's Avatar
I noticed that my hood on the right side is "dipped" lower than the left side and slightly lower than the steel that houses the right headlight.
Old Jun 11, 2015 | 03:08 PM
  #592
Octopy's Avatar
Just wanted to let you guys know that my Honda dealership just let me know that there is a service bulletin on the drivers side A pillar. I went in to get the gap fixed on the drivers side and they ordered the plastic piece next to the small window, that did not fix anything. According to them, there are a bunch of A pillars that are deformed and can be ordered and replaced at your dealership.
I should be getting my new A pillar part in a week or two and will let you guys know if it fixes the problem!
Old Jun 11, 2015 | 03:30 PM
  #593
GotFitB13's Avatar
Thanks! I just reached 15% until maintenance is required this morning, and I'll be having them check that and a few other things.
Old Jun 16, 2015 | 05:53 PM
  #594
n213978745's Avatar
Hey guys, I have question:
The interior of front seat (Driver Side), does it have "Cover" on the area
around gas petal and foot brake?
My car doesn't have cover and it exposes the insulation and other car parts:
The White part of image is just a paper that I use to cover floor until I get mat :^)
Old Jun 16, 2015 | 09:33 PM
  #595
tbFit's Avatar
Image not showing up...
Old Jun 17, 2015 | 07:44 AM
  #596
GoBucky's Avatar
The interior of front seat (Driver Side), does it have "Cover" on the area around gas petal and foot brake? My car doesn't have cover and it exposes the insulation and other car parts.
That is normal, the carpet does not go all the way up.
TbFit, if you right click on the picture icon and select "Open Link" you should be able to view the picture.
Old Jun 17, 2015 | 04:12 PM
  #597
n213978745's Avatar
Ah okey, thanks.
For a moment, I was worried that they forgot to put back the cover after maintenance.
Old Jun 23, 2015 | 01:03 PM
  #598
Uncle Gary's Avatar
Too bad you didn't get the number of that service bulletin. My dealer probably won't want to look something up based on something I heard someone say on the internet.
Old Jun 23, 2015 | 01:05 PM
  #599
Octopy's Avatar
I am still waiting for them to get my part in, but when I go back in I can see if they will give me that info. My dealership treats me like I am an idiot because I am a woman I think > <
Old Jun 24, 2015 | 07:43 AM
  #600
Uncle Gary's Avatar
I asked my dealer yesterday regarding this, and their answer was that they've looked, and there's no such service bulletin and no fix for this issue. They've promised to call me when the factory rep. comes around, so he can see the problem. We'll see.
I'm beginning to regret buying this car (a bit). If this simple issue can't be resolved, what would they do if I had a real problem with the car? What angers me more is I can look at five other Fits on the lot, and none of them have this issue, so they can't say "they're all like that."
