Log In
View Full Version : Fit DIY: Repair & Maintenance
Pages : 1 2 3 4 5 [6]
  1. Honda brand brake fluid
  2. help with stain removal!!!
  3. Rotors Rusting?!?
  4. rubber insert on the shocks?
  5. To be or not to be..missing?
  6. Rubber insert not inserted
  7. Help with the Battery Wires!
  8. Air Freshener
  9. JDM LED Taillight
  10. Tire Rotation ???
  11. Rear emblem loose
  12. how to take the battery out
  13. Disconnecting battery...
  14. ECM/PCM Idle Learn Procedure
  15. WANTED A DIY for aftermarket springs
  16. how to clean the black rubber around the window outside??
  17. Rear of Fit stays dirty!!??!!
  18. Charcoal canister??
  19. sticker residue removal
  20. Gas Tank Fits more than 10.8 or 41 L's
  21. Sunscreen????
  22. how to get rid of the scratches on your car?
  23. What size is are the rotors?
  24. help with OEM rear spoiler install:
  25. 12V power all the time?
  26. Oil smell at Idle
  27. Ticking noise when changing speeds
  28. FIT Repair Manuel
  29. HID Installation
  30. My 12volt accessory outlet doesn't work.
  31. Paint protection
  32. fan switch location
  33. If I only had a backer
  34. Filter question
  35. Banged up my alloy rim....
  36. DC2 ITR and DC5 S 5 lugs for the FIT?? discuss
  37. Oil Filter
  38. Dirty Rearend
  39. Mobil 1 Extended Performance Filters
  40. Another filter study
  41. Different oil filter study
  42. Need guide on Honda Emblem switch
  43. JDM wiper blade
  44. For those of you who like to use Honda Oil Filter, read on.
  45. I tried Mobil One 5w-30, and....
  46. question about Defi-Link BF water temp. gauge
  47. Removing goo-ey tree sap?
  48. Rear Bumper Dirt
  49. Tar and Bug remover
  50. Retro-Fit Progress
  51. Locking gas cap installation instruction
  52. Does DIY Mods void warranty on NA Fit?
  53. HELP air bag light
  54. Spark Plug Spacing?
  55. Who has changed their oil?? How many miles did you have?
  56. resetting ecu??
  57. Knocking sound from the engine
  58. Fit's comfort
  59. Front License Plate Attachment
  60. anyone installed Mugen Visor
  61. Stant 180F thermostat
  62. DIY Keyless Entry?
  63. Need help replacing a tiny broken part...
  64. Valve Clearence And Timbelt Breakage
  65. God made the Claybar
  66. First Oil Change
  67. Cleaning the engine, the easy way?
  68. Painted Intake Manifold Cover
  69. Rain x on winsheild or mirror. What do you think
  70. what you guys use to clean Windshild?
  71. Help! I'm frying with the A/C on, in Vegas.
  72. exhaust finisher on Sport?
  73. $20 DIY Performance chip for Fit?
  74. Stock Air Filter
  75. L15A - A/C Compressor Drive Belt Part Number
  76. Request - DIY for JDM Side Markers
  77. Cruise Control for base model
  78. Door guard in Canada/US?
  79. Install the Fujita M/T CAI in a A/T (not recommended)
  80. Paint easy to scratch/swirl, cheap paint from the factory?
  81. To Help You People Out On Oil and Filters
  82. A/C DEFROST Mode questions,answers, solutions
  83. Windshield Whining-Noise Problem Solved!
  84. DIY - Door Sill install
  85. DIY - Door Sill install
  86. Rear Bumper Protector/Applique
  87. Valve Cover Thingy removal...
  88. Where should I jack my Fit from?
  89. how to get tree sap off black paint easily?
  90. Honda Fit 2007 Service Manual
  91. Request: DIY Spring Installation Guide
  92. which is better
  93. Any tips for preventing dings/dents?
  94. I found 2007 Honda Fit Owner Manual to Download
  95. 5 Star Shine
  96. undercoating?
  97. Nipples
  98. A/C pump question.
  99. Autobytel review--too harsh?
  100. Door Panel Shoe Scuffs
  101. Online Honda Fit parts listing!!!
  102. How to clean the interior? With questions, answers and suggestions
  103. engine replaced need help!
  104. Gas pedal adjustment
  105. Waxing Your New FIT, questions,techniques,products
  106. Honda repair manual for Pilot?
  107. Oil Filter
  108. Horn Replacement
  109. Fumoto valve available for Fit?
  110. Downloadable Fit/Jazz service manual
  111. Washing your FIT, products, techniques, answers
  112. Jack points for the Fit?
  113. Intermittent wipers ...
  114. Help Me Need To Change Stock Speedometer!
  115. First Up .. Brake
  116. Windshield Washer
  117. Tailgate rubber seal
  118. Jazz it up
  119. High revs (1.5 to 2K) on start up
  120. Timing Chain on N.A. Fit?
  121. Clutch Height Adjustment????
  122. 3m paint protection film, xpel, clearbra, etc?
  123. I'm going to tune up my 1.3 CVT Jazz - Help :)
  124. please help me out please
  125. Hey any of you Jazz / fit owners...
  126. Fuel Filter
  127. Door power lock diagram?
  128. Fuse Question?
  129. Magic seat stucked at flat position
  130. Where to get the service manual?
  131. Fit 2002 climate control - no auto AC?
  132. Fuel Filter
  133. CVT vibration - help?
  134. OIL, filter, maintance minder questions
  135. sticky gearbox
