Log In
View Full Version : Fit DIY: Repair & Maintenance
Pages : 1 2 [3] 4 5 6
  1. Which Brand of Ignition Coils and Spark Plugs Should I Get?
  2. Need help with dent
  3. Won't shift into park sometimes
  4. how to disassemble head assembly
  5. 2008 Headlamps covers?
  6. a/c Light when out at night, repairable???
  7. Flashing D & Surge Idling
  8. Noob DIY for pads and rotors
  9. Crack in main housing of transmission
  10. How to remove stuck rotor screw (2009 Honda Fit Sport)
  11. Honda Fit service Manual
  12. Doing your own work on spark plugs?? You NEED this!
  13. Please Advise: GD3 Strut/Shock R/R
  14. PCM fuse #
  15. AC problem
  16. DIY - bleed brake fluid (my first time!) 2009 Sport Auto.
  17. looking fit:rear spoiler removal
  18. Fit modders and home owners
  19. Whirring sound after tire rotation?
  20. Replacing Main Oil Seal from Chain Case, DIY?
  21. Door Edge Film and 3M Protective tape application solution
  22. What to do if your axel falls out from the tranny
  23. How does a dummy replace the glove box lid?
  24. Strange overheating on 2007 fit
  25. ETX30L Deka / Big Crank Install
  26. Missing Dipstick and Cap
  27. Wobbly mirror = easy fix?
  28. Cat Converter Replacement: Magnaflow 51354 vs. 94854
  29. Ignition Coil Stuttering
  30. Weird sound after installing K&N Intake
  31. A/C problems, need advice
  32. Gen 1 wiperblades
  33. Interior door lock button no longer working
  34. Cvt gearbox
  35. Recharging Air Conditioning
  36. Just had 2 blow outs, new tires, new weird feeling! Help noob
  37. Easiest route wiring from front bumper to taillights
  38. Coil #s
  39. Fit Wiring Question
  40. Bad coil, Bad plug, or worse?
  41. Oh, the things I've learned!
  42. Are the headlamps for the Fit and the Jazz the same?
  43. 2007 Fit headlight problem?
  44. Ye olde P0420
  45. coil pack problem... my plan on the cheap
  46. DIY: Torque Solution Shifter Cable Bushings Install (With Pics)
  47. HELP!!!URGENT!! My remote lock, dome light, radio went out
  48. Led lights to parking lights
  49. Cleaning Fit black cloth interior
  50. What products are needed to prep for car show?
  51. DIY: Innovative MM install/review on MT Trans GD3
  52. I need advice!
  53. Need Advice
  54. Question for anyone who has done a GD DIY clutch replacement
  55. Maintenance Intervals
  56. Clutch going bad already?
  57. strange noise in my new fit
  58. Swirl and scratches on tail light..
  59. Getting her near perfect!
  60. Window Seal Broken
  61. DIY novice - where's 2010 Fit air filter?
  62. Engine movement
  63. Addressing rough idle and misfires ’07 Fit
  64. Windscreen washer pumps that are compatible? for 02 Fit
  65. need drivers side axel! asap! best place to get one?
  66. DIY - Torque Solutions shifter bushing install
  67. brake caliper torque on 09 fit sport....
  68. Valve lash check and adjustment results, '08 Fit 78k miles
  69. Thick versus Thin
  70. Headlamp maintenance help!!!
  71. Dim headlights; high beams fine
  72. ECT Sensor problem!
  73. Fuel injector cleaning
  74. Anything in particular @ 100k GD3?
  75. R&R steering column cover
  76. Replacing bumper cover on 2011 Sport
  77. Speedometer/Tachometer/MPG's Not Working
  78. Future Fit owner.
  79. Backplate for driver's side mirror?
  80. Engine Stutter and shut off
  81. Rock Chips-----what to do?
  82. Door lock LED
  83. Door lock LED
  84. request, how to remove door side moldings
  85. Replacing Third Brake Light
  86. Looking @ getting 2nd gen fit - how hard is maintenance?
  87. 2004 valve clearances
  88. Those G*ddamn Rotor Screws
  89. Honda fit front strut part
  90. 2007 Fit over heating HELP PLEASE!!!!!!!!
  91. Sea Foam
  92. Carbon Fiber Hood for the 2009 Honda Fit?
  93. xW-20 Oil in Very Hot Climates
  94. what torx needed for front brakes 2008?
  95. Need help. Engine keep dying on me
  96. Beware market hype
  97. My hood won't close properly TT
  98. My hood won't close properly TT
  99. Destroyed front bumper cover
  100. online source for maintenance fluids
  101. The B maintenance service
  102. DIY: GD3 clutch hard line (to remove the in-line CDV)
  103. Another GD water thread
  104. Waxing my new (ish) Fit
  105. Dual Action Polisher: GG, PC, or Megs??
  106. Where is the Valet Switch on an 07 Fit?
  107. 2008 Fit rough idle when cold
  108. Help?! 2 Mechanics, 2 Opinions
  109. Post-repair, water sound, NOT gas tank???
  110. Driver Door Lock issue
  111. P0420 ...low catalyst system efficiency?
  112. Which car battery is for honda fit 2009
  113. Replaced Front Brake Pads, Rear Drums Now Squeak
  114. need help: Fuel pump color code description?
  115. Kozak Cleaning Cloth
  116. P0847 Transmission Fluid Preassure Sensor Switch B Circuit Low. Help?
  117. replacing 07 coil packs
  118. products for black paint
  119. Getting a dirty interior more presentable.
  120. driver's side door lock removal + window removal?
  121. P0135 Code
  122. P0135 Code
  123. Help!: Oil in Sparkplugs
  124. I need some torque specs please
  125. Dome and Headlight Flicker
  126. jerks lured raccoons to my car...
  127. Why NOT Turtle Wax?
  128. 2007 Honda Fit Driver Side Glass Trim Replacement
  129. Windshield scratches
  130. windshield washer fluid
  131. Ravenol Synthetic CVT Fluid is Magical!
  132. window haze
  133. 10 Most Common Car Repairs
  134. Mobile 1 5000.. it had air bubbles in it while i was pouring.
  135. Driver's Side Mirror for a 2006/7 Fit?
  136. Can anyone tell me what part this is?
  137. Drivers door wiring harness
  138. Can anyone tell me what caused this?
  139. Fit starts, idles and stalls: any help appreciated
  140. Full ATF DIY Flush
  141. An Alternative to the Honda dealership thread
  142. Honda Genuine Motor Oil- What it is and where to get it
  143. Engine light came on.help please!
  144. Oil change?
  145. Leaking engine oil or ATF? pics included!
  146. AC colored lines
  147. A-Spec Header "Rasping"
  148. My Fit is a Door Ding Magnet
  149. 151R Battery at AAP
  150. Honda Fit 2007 Tail Light Cover Replacement
  151. DIY- Be hardcore, replace your heater core
  152. Other Options For Horn Replacement?
  153. DIY: Adjusting the Valve Lash (clearance)
  154. '07 sport fit underpanel(?) damage
  155. Battery replaced now multiple systems have failed
  156. Maintenance free battery maintenance??
  157. Remove Scuff Marks from Door Panel
  158. repair stumped
  159. Rubbing Compound Problem
  160. Hey GUYS help me (FUEL EATING MONSTER)
  161. FYI: 5 Car Repair Myths
  162. Check engine light turns on mid driving and engine stalls
  163. Collinite 476s over Duragloss 105
  164. Paint is ruined.
  165. 2007-8 Automatic Transmission Filters
  166. question on rotors
  167. DIY- Replacing the Windshield Washer Motor on a Fit
  168. Repair estimate advice
  169. Hey guys just the detailed the FIT!
  170. Changing self-lock timing-can it be done?
  171. Question about intake cleaning chemical??
  172. Nascar fw1 wax
  173. multiple random misfires on 2007 fit
  174. DIY: Testing, Removing and Installing the Compressor Clutch Relay
  175. AMSOil oil change for extended intervals!
  176. Need help with tires & lowering springs
  177. Another Water Thread
  178. Lock and unlock remote and stock radio don't work
  179. New 2010 Milano Red owner here, questions...
  180. removing old layers of wax
  181. Mc'Donalds coke in my seat.
  182. headlight restoration
  183. EGR Valve Cutoff Plate, still Engine Light
  184. Couple Issues New Owner ABS Cruise SRS Horn
  185. Rubber under front of car torn!
  186. Parking Brake Problem
  187. What's the name of this light? 08 Fit
  188. How do I access the washer pump on 09 Fit Sport?
  189. Not the blower motor resistor..08 FIT SPORT
  190. detailing problem
  191. PPG Clear Coat
  192. 09 Fit Sport Brakes
  193. Tru Shine and Unique Mobile Detailing, Audi R8 Spyder Protection Detail
  194. Test Pipe Install... Big Mistake...
  195. Rattling Coke Can with BB's
  196. Cleaning the headliner
  197. DIY Program for 2010 Fit Remote?
  198. Boost loss
  199. Shift Rod Vibrating a Lot. Is this normal?
  200. How do you remove BUGS ??????
  201. Ferrari 458 Italia Paint Correction by Tru Shine Detailing
  202. "Slow" Stock GD3 - Have Data, Need Help
  203. new question, oil change percentage
  204. How do I reset the maintenance minder
  205. 09 base model cruise control
  206. DIY rear camber mod for gd!!
  207. Driver's wiper - going over top of windshield?
  208. How to change 1st-gen serpentine belt?
  209. Replacing shocks and struts?
  210. Question about keyless entry reprogramming
  211. 2008 Fit white smoke smells like fuel at idle.
  212. stripped strut
  213. Need Help Fit is hiccuping
  214. True Grit or The Bucket List...
  215. Gah! Price of ATF fluid....
  216. Honda Fit side mirror-right side
  217. Destroyed Engine mounts...
  218. B 1 3
  219. Urgent Help: Shock bolt stripped cant drive
  220. Interior sun visor
  221. Remove Wiper Blade (Not just Insert)
  222. 07 base wheel bearing replacement help
  223. Replacement of fuel filter on Honda Jazz(Fit) intank
  224. Help me Please :( Major problem with my fit
  225. 68K Mile GD3 Maintenance Project
  226. An Easy Way to Beautiful Glossy Paint
  227. Code P2138
  228. Cooler problem
  229. Zaino totall protection car kit.
  230. Control Panel Going Berserk! HELP!!
  231. FD RX7 gets De-Faded and De-Swirled
  232. Sinister yet Sexy 98 Dodge Viper GTS gets Tru Shine Lovin
  233. Back to Black...
  234. Coil Stuttering/Misfiring Issue Possibly Fixed @ reduced price? $$ Responses Wanted..
  235. Rear seat latch broken
  236. Fast-N-Easy Way to Fix Paint Chips!
  237. This Armor All video
  238. oil/filter preferences?
  239. differential ratio (Standard vs Sport)
  240. chain or belt?
  241. Water inside my 2008 GD3 sport!
  242. Cleaning radio display and clear plastic over gauges?
  243. Repair a worn hole in floor covering?
  244. Wax on cowl
  245. Need New Brake Pads
  246. 2007 fit brake caliper bolt sizes?
  247. Chevron Techron Fuel System Cleaner
  248. diy tilt stock spoiler
  249. problem with RADIO ""enter Code""
  250. 07 Drum Brake DIY
  251. Back number plate light
  252. My heater not heating enough..
  253. To Apply Wax After Sealant Or Not??
  254. 303 Aerospace Protectant
  255. old daddy
  256. Detailer-Bellingham Washington
  257. Door Power Locks Gone Weired
  258. Light switch problem.. Hard to fix???
  259. Engine making grinding sound and part wobbling
  260. How to clean water marks on windshield?
  261. Oxygen Sensor Problems / P2A00 and P1172
  262. Help with cleaning nonsticky residue off dash
  263. Cabin Fan Assembly removal?
  264. Hella Supertones in a GE8...Please help!
  265. 3/8" OD barb for 5/16" ID hose
  266. hood dent, bumper off, and possibly radiator pushed back
  267. car wont start...no spark
  268. Preventative Measures
  269. First Ding!
  270. Awesome Car, Awesome Shop, Awesome Detail! 08 Jaguar XKR Portfolio
  271. oil change adding slick50?
  272. Single Stage Lancer Evolution paint restoration by Tru Shine
  273. Rockauto Discount Codes
  274. ~General Question
  275. Location/Maintenance of FUEL FILTER
  276. Aftermarket Bulbs Not Recommended
  277. Jazz '06 Headlight help
  278. DIY: Mini D2S Projector Retrofit
  279. Help! I am worried about fit!
  280. 2006 bulb replacement - parking light?
  281. Squeal
  282. What can a competent detailer do for your paint
  283. rear tires cup on inside ?
  284. diy thread for replacing rotors 07?
  285. Window Visor pin?
  286. accessory installs in cold weather?
  287. DIY VIDEO: Replacing Beam Blade Wiper Inserts
  288. getting a sweaty smell out
  289. How to clean micro-fuzz on door
  290. led daylights
  291. Scissor jack replacement
  292. Any DIY on how to replace the parking light?
  293. 07 fit blower motor questions
  294. CEL code help
  295. speedometer not working
  296. Rear Axle replacement
  297. From Pink to Cherry! 1964 Nova SS Exterior Paint Correction
  298. Honda Fit Sport GD3 Battery Replacement size.....What I did.
  299. OK - can someone tell me what I should be asking for here?
  300. Stutter, rough idle, stalling
  301. Replacing a portion of the dash/instrument panel...
  302. Electrical problem
  303. Help me with DIY Heatshield for GE SRI.
  304. Grinding noise at idle and driving.
  305. GD3 Analogy
  306. Check engine light...after having 1 coil pack replaced
  307. Problem, check engine light blinking between 2000 and 3000rpms.
  308. Dead Battery
  309. Brake pad wear indicator?
  310. Air Conditioner keeps works intermitently
  311. Per Honda: Only use Honda fluids....should I take heed?
  312. how often do i wash my car?
  313. ATF change
  314. How to jack up the fit for maintenance?
  315. SimplySpray Fabric mod
  316. Trying to put new rotors on
  317. Built LT1 Hybrid Impala SS (It burns Rubber and Gas)
  318. Oil Filter Magnet
  319. AC Button Light Replacement?
  320. tpms light disable
  321. I just hit a curb with my brand new 2010 Fit
  322. Wheel Lug Post
  323. Electrical Problems!
  324. $8 plastidip mod
  325. RIM Curb Rash
  326. how to remove city sticker without destroying
  327. Installing a 51-4 Battery in the GD3
  328. ethanol mix, engine life, new gas engines ?
  329. *Warning! No diving!* paint appears very deep! *No life guard on Duty*
  330. oil sensor part number?
  331. Scraped my paint. Help? Need Advice.
  332. DIY: Foglamp Lens Replacement
  333. request DIY - Upgrade the big 3
  334. Two A/C and Heater Issues
  335. Fit Rant!
  336. Taillights not working need help!!!
  337. brake wear
  338. How to tighten GD3 driver's seat back?
  339. Help - Engine misfires when accelerating past 2,000 rpm
  340. Drove over a boulder - Specific damage to look for?
  341. engine filter/air filter gd change
  342. DIY: What Maintenance Minder Means
  343. 2007 honda fit sport leaks!
  344. Blower Fan Stops Working on Long Trips
  345. car won't start, has power
  346. 40k miles maintenance
  347. Oil change intervals for Canadians its colder here
  348. Detailer Recommendations in NYC?
  349. Blowing Fuse when checking Data Link Connector
  350. Who wants to meet Jewel? Twin Turbo Viper Detail
  351. what do I need to do new fit owner
  352. 51R battery does not fit after all...
  353. NAPA oil filter
  354. 2007 Fit Sport Valve Adjustment
  355. Let me introduce Candy, she's real sweet! 97 GTS Dodge Viper
  356. My Fit has 67,500 miles - what maintenance should I be getting ready for?
  357. 3000 mile oil change a thing of the past
  358. Squeak when releasing brakes (pedal brakes AND emergency brake)
  359. Oil in air filter?
  360. Air Filters
  361. cleaning interior windows
  362. Rear emblem question?
  363. DIY: Fog Light Lens Fix/Replacement
  364. I want to know
  365. Water marks on Seats how to get rid of them.
  366. Handbrake and ABS warning lights are on after wheel bearing kit replacement
  367. Speedometer not working
  368. DIY a/c switch light and installation problem
  369. Potential Rust Issue - Under Sport Spoiler
  370. Has anyone tried Mobile 1 synthetic A/T Fluid
  371. Need help with CEL & Engine issue
  372. How to turn off maintenance lights??
  373. Fit code error nobody can help!
  374. 2008 Fit horn problem
  375. Not you Everyday Lamborghini Gallardo.......
  376. Is there a DIY for my front brakes as well as rear brakes????
  377. Reconnected Battery, strange noise?
  378. Removing window crank rear door
  379. How to remove guage hood
  380. Brake light comes on during hard cornering
  381. The dreaded dash rattle...
  382. Driver's side window problem?
  383. Question for the pros
  384. Fit Sport 07 Passenger Airbag Light Under Cd Player
  385. fit sport 07 Three Circle Knobs Under The Cd Player
  386. Fit Sport 07 Staring Wheel Peeling
  387. Fit sport 07 Battery
  388. Nothern VA Detailing
  389. Fit "pops" out of 1st when shifting into 2nd
  390. OBDII Scanner help
  391. Rear headrest GD.
  392. "Swirl City" Black 2008 Club Racer (CR) S2000
  393. Intermittent corner lights
  394. "Faded Glory" Grand Prix White Honda S2000
  395. My 3M Clearbra experience...
  396. socal detailing
  397. spark plug can only be screwed in once?
  398. passenger side electric mirror not working
  399. Black Mercedes E320 Paint correction
  400. mom left window down now smells like mold help
  401. Rear Bumper Removal . . . ?
  402. Another GPW NSX Refreshed by Tru_Shine *One Step Polish*
  403. Main o2 sensor out on exhaust
  404. ABS Question (Non fit)
  405. Main DIY thread (sticky content)
  406. replacing the rack & pinion
  407. paddle shifters not working
  408. Oil Filters all Hondas the same??
  409. Weird CLUTCH sensation w. 2010 W/ 200 miles
  410. Compare Your Engine To Mine
  411. Rotor screws?
  412. Black Chevy Tahoe paint correction by Tru_Shine
  413. ECU problem
  414. Got a CEL, car has about 170k
  415. Anyone else here a Klasse user
  416. What to do about tiny high rock chips on hood
  417. DIY: GD Clutch Hardline
  418. To XZILON or Not to XZILON
  419. side mirror sub assembly replacement
  420. JDM Wiper Mod.
  421. Fog light lens repair DIY?
  422. **fan is acting weird**
  423. How to remove road tar from paint and wheels?
  424. g/f spilled dairy based soup, carpets reek!
  425. i need AC Compressor
  426. Has coil replacement fixed anyone's misfire/stutter?
  427. Moving Your Turn Signals to the outside Lens
  428. Whinning noise under acceleration
  429. Should I bother trying to clean this engine bay
  430. Clutch Fluid
  431. Help help help!
  432. Grand Prix White NSX Detailed by Tru_Shine
  433. Sigh.... car was broke into. PLEASE HELP
  434. Microfiber a Big Fibber?
  435. Amsoil Engine flush
  436. What brake pads are you guys using?
  437. Help from those who have adjusted their valves?
  438. Location of o2 bank 1 sensor?
  439. Changing MT Fluid: An Observation
  440. 09 Fit Sport Detail
  441. O2 sensor help!!!
  442. 2004 Red Z06 Corvette Detailed by Tru_Shine
  443. Pressure Testing (Long Post)
  444. GE8 instrument cluster scratches
  445. Removing the rear bumper cover? Safely?
  446. CVT gearbox oil level check
  447. Buy Unlocked Apple iPhone 3G S 32GB/ Blackberry Bold 9700
  448. DIY, replacing all the lower fenders, covers and shields, (maybe flaps also)
  449. Easiest exterior maintencance for Fit? Q about paint...
  450. Unstable idle
  451. *Warning! Rated OMG!* 2004 Black 350z Full detail + touch up
  452. Tru Shine took a trip to Bham Alabama for a detail
  453. Variable Wiper Stalk
  454. help on 02 sensors...
  455. Anybody replaced the stock shocks???
  456. Tail Lights. HELP PLEASE
  457. Wagner Replacement Rotor Screw Holes
  458. T1R rear springs higher?
  459. need help removing steering wheel air bag
  460. 2007 Black Z06 Vette goes under the Tru Shine knife!
  461. A/T to M/T swap
  462. headlight restorer
  463. how do I make it shine
  464. Power Steering Fluid?
  465. 97 NHBP Acura Integra Full Paint Correction by Tru_Shine
  466. Removing the gauge cluster?
  467. Tire pressure gauge?
  468. PCM/ECM computer code list
  469. Suggestion For Tires
  470. 07 Fit Sport Transmission Issues
  471. a/c button not lighting up
  472. Help. Installed PIAA fog lights, now keyless entry doesn't work.
  473. FIT out of 'shape'
  474. Oil fill breathing
  475. cleaning under bonnet and headlight protectors
  476. Part Number
  477. Rail Rust???
  478. How to replace the gearstick light bulb
  479. Installing battery?
  480. Re installing the OEM rear emblem on GD
  481. Re installing the OEM rear emblem on GD
  482. Cracked fog light lense :(
  483. Doors Keep Locking
  484. PLEASE HELP!! I messed up
  485. 2003 Honda CBR 600RR First time detailed since 2003
  486. Fixing a small dent, any good body shops in so cal?
  487. Windshield Wiper Replacments - Long Rubbery 07 type
  488. what maintenace do i need
  489. My finish is damaged with small brown spots all over
  490. Engine vibration at idle.
  491. U0107 code... the fit wont start! help!!!
  492. coolant question
  493. My Fit keeps shutting itself off.
  494. My car turn off when running and wont start now... help please!
  495. 08 honda fit - How to start?
  496. Not a fuse ? So what is it ? (HELP PLEASE)
  497. Coil pack discoloration
  498. Side Mirror Replacement trouble
  499. Loud noises & burning at cold start
  500. How to remove the welded nut?
