PDA
View Full Version : Fit DIY: Repair & Maintenance
Pages : 1 2 3 [4] 5 6
  1. fanbelt,,,time to change or not,,,
  2. 15400 PLM-A01PE Oil filter
  3. A pillar plastic trim coming loose
  4. Speaker Buzz When Pressing Accelerator
  5. 30k "major service"
  6. Fuel leak?
  7. Where to get yellow foglight bulbs & backup bulbs?
  8. Front Stabilizer bar bushings
  9. My lights are going out! o.O
  10. Timing Chain question...
  11. Is this car cleaner good? Metallic Car Wax?
  12. help, day lights and back lights dont turn on when turned on by the switch
  13. Looking At A B1 Maintenance Interval
  14. anyone know where I can buy the upgrade accord horn using paypal ?
  15. Help! How to remove front sport lip.
  16. Help! How to remove front sport lip.
  17. Cleaning Inner Windshield/Windows
  18. Need help cleaning seats!
  19. Help, Gate hit my fit.
  20. Front lower strut bar... Help please
  21. Wiiper blade assembly problem
  22. Fuse short #8 Back Up
  23. absorbent inserts for cupholders?
  24. Noise ?
  25. Need help 2007 Fit CEL!!!
  26. Noise coming from rear brake drum (right side)
  27. Help~ A/C and fan only work when set to 4!
  28. Tip for restoring faded plastic trim!
  29. PCV hose noise
  30. What should I do first?
  31. DIY: Paint Your H...the right way
  32. Cleaning JDM Access Window Visors?
  33. Complete newbie to washing cars, lots of Q's!
  34. Painted Fog Housing...
  35. Honda Fit SRS light 8-1 8-5 after accident and SRS unit reset
  36. Where to buy replacement tailgate struts for GD3
  37. T1R Radiator Hose...
  38. fix it scratch remover review.
  39. DIY: Hydraulic Lifts for Hoods GD/GE
  40. Need Service Manual
  41. Seatbelt beep malfunction
  42. Vinyl tinting the stock tail lights
  43. Whats the best tar remover
  44. A/C Button doesn't engage
  45. Detail Shop in So Cal ???
  46. Help...SRS light on and dealer said..
  47. Remote key fob for BASE fit?
  48. Cilajet
  49. Aux port not working; not wired in head unit
  50. Black wheel scuff repair?
  51. 30k mile maintenance ?'s
  52. Quick question about Front Brake/Rotor Replacement
  53. How to install ARMREST onto Base FIT
  54. Detailed!
  55. Zymol Cleaner Wax
  56. 1 Year, 17,400 Mile Oil Change Lab Results
  57. Has anyone done a DIY on a MTF change?
  58. Residual gummy film on body from bad dealer prep
  59. How to remove o2 sensor?
  60. What is this stuff on my car called, and why so costly
  61. sealants/detailers and drying
  62. Anybody installed/replaced a front fender before?
  63. Electrical bits needed
  64. Installing rear view mirror back on...
  65. Need some input on this pls....
  66. PRM Intake Cleaning?
  67. benen tow hooks
  68. DIY: How to Lower Your A/C Temperature
  69. B12 Service Minder and Alignment
  70. How to fix stripped screwhole for cargo cover button?
  71. Difference between waxes?
  72. Official DIY: Changing Spark Plugs (L15A VTEC)
  73. Access to back of Fuse Box
  74. Recaro SRD seats + Bride RO-type seat rails: DIY seat removal and install
  75. request: DIY front seat removal
  76. Waxed Hood, Now Have Weird Spots??
  77. Filthy Fit Filter
  78. Time to Take It to the Next Level....
  79. Studdering in 1st gear.
  80. Removing Backseat
  81. 12V Socket in cargo area
  82. oil catch can
  83. ground wire kit???
  84. PCV valve question
  85. rewiring fog/driving lights
  86. Spark Plugs
  87. cloth on door pannels
  88. ATX filter!
  89. gerabox oil
  90. question about washing fit
  91. DIY Camera Mount
  92. Foglight problem! need help plzZ!
  93. Touching up chipped paint
  94. Rear passenger window motor very noisy after rain
  95. New Fit, Swirl marks, and washing advice?
  96. Anyone tried to add battery water?
  97. 51R battery installed
  98. MR clean at woot
  99. How does one "repair" Carbon Fiber?
  100. WTF? a/c not blowing hard on recycle
  101. Constant 12V source near headlights
  102. Modified Mishimoto CF Intake
  103. Removing tint
  104. Dealership for Clearbra and paint protection?
  105. Long Term Storage - Use a cover?
  106. Removing a pinstripe
  107. Quick Detailer/Wax Booster Spray Questions?
  108. Cleaning under the Hood? Any Tips?
  109. Water In back footwell of Fit (Jazz)
  110. buffed down to bare metal
  111. p1157 Engine code .. HELP PLEASE!!!1
  112. airfilters
  113. Help find fuel pump power line
  114. RPM @ idle? or neutral....
  115. Getting superglue off a car?
  116. check engine light on help please
  117. "CHECK GAS CAP"... what?
  118. Has anyone replaced a side mirror?
  119. Waxing the easy way.
  120. ????? Skunk2 universal coilovers ?????
  121. Replacing Mirror/Removing Door Panel?
  122. Xenon HID
  123. DIY: How to Stiffen a GD3 Drive-by-Wire Gas Pedal
  124. Does anyone know how to remove hondata or ecu in 07 fit?
  125. Newbie Car Cleaning Q's
  126. Skunk2 Honda Fit head porting DIY
  127. Tune up
  128. Electronics problem
  129. Why you should check your air filter before it's due
  130. Finally got a chance to clean the Fit up
  131. 2009 Fit Fog Light Protection
  132. DIY: Header removal / installation help + tips
  133. Dumb question regarding dilution ratios
  134. Anyone use a Porter Cable on a GE ?
  135. Hood rusting from rock chip...
  136. i want a new battery...but...
  137. modified stock intakes
  138. 2 Oil Analysis Results - Factory Break in Oil and Synthetic
  139. Did you know . . .
  140. DIY Brake Fluid Flush
  141. Oil Leak
  142. anybody help please?
  143. Recommendations of tire dessing that does not promote dry rot?
  144. 1999 Accord Shuts Off While Driving
  145. clicking sound at 1000 RPM
  146. 2008 Honda Fit front right turn signal light replacement
  147. oil filter, honda vs fram extended vs purone?
  148. Rust prevention
  149. Rear anti sway bar
  150. Poll Take 2: oil change interval @ 15%
  151. Removing glove compartment
  152. Need Ideas for in-car Bike Racks / 2008 Sport
  153. Finally Fixed Dash Vibrations
  154. Huge dent and scratch on fender.
  155. Huge dent and scratch on fender.
  156. !!HELP!! please....
  157. Where to Buy Side Mirror Mount Thingamabob?
  158. Poll: oil change interval @ 15%
  159. Headlight assembly
  160. My honda Fit's high fuel consumption
  161. Where to get Filters?
  162. What ramps work with Sport?
  163. Water in the trunk
  164. Cruise Control Won't Engage
  165. check out Walmart for oil
  166. Code appears after 10K miles..
  167. Third oil change, switching to ENEOS in my GD
  168. drain bolt removal direction
  169. Filter cut open (with Filter Mag)
  170. fumoto: opening the valve
  171. Car Wash Q?
  172. Q Horsepower full synthetic oil
  173. Automatic wing mirror turn in
  174. how much clear coat did I take off?
  175. Washed car while snowing
  176. Anyone using Menzerna?
  177. The New UBER Applicator Pads ready for pre order
  178. dr colorchip touch up??
  179. Inner window sill protection
  180. Detailers Doman Order Experience(positive)
  181. Need help!!!diy~fog light
  182. 0W 30 Mobil 1 Oil
  183. Oops...Help Please?
  184. DIY - Install a Gentex GENK41A Auto-Dimming Mirror with Homelink
  185. Detailer's Domain: Audi RS6 Spring Clean up
  186. Ultimate Electronics DIY (56k users BEWARE)
  187. Help with lights, please!!
  188. Meet our NEW SUPER PLUSH MF! Help us name it
  189. removing bug splatter???
  190. CEL p0405- fix?
  191. Detailer's Domain: White 911 Turbo with Lusso
  192. What wheel cleaner to use?
  193. Painting Carbon Fiber
  194. I hate rain
  195. I need a garage lift ....which one???
  196. Magnetic oil drains
  197. Was wondering if there would be interest for a Porter Cable kit Group Buy?
  198. key dismantle anyone know?
  199. AC & rear defogger button broken
  200. Detailer's Domain: 2007 997 Turbo
  201. Detailer's Domain: 2006 Porsche C4/Swissvax
  202. Claying the Can Do Tool (info article)
  203. Choosing the Correct Buffing Pad
  204. Buffer Splatter Prevent this Messy Time Waster
  205. Refinishes: How to Spot them and Why You Should . By Kevin Farrell
  206. Swirl Marks A Detailer's /Customer's Nightmare
  207. A new Swissvax specific to white paints
  208. Ask Detailer's Domain
  209. Let's kick off the new season with 20% off at Detailer's Domain
  210. Hello from Detailer's Domain (discount code inside)
  211. D.I.Y^o^ Vertically @ rear wiper for GD ( Fit & Jazz )
  212. D.I.Y^o^ Vertically @ rear wiper for GE ( Fit & Jazz )
  213. Coolant change
  214. Password JDM DIY
  215. Skunk 2 Springs DIY gone wrong
  216. Oil Filter Thread
  217. Installing JDM Center Console on GD3
  218. in cabin air filter
  219. recommend a torque wrench for tire rotations
  220. Just washed:)
  221. Valve Clearence
  222. Maintenance letters = what mileage?
  223. Removing 05 Fit stereo unit?
  224. Interior Light Problem!!
  225. power surge/short? 08 sport
  226. Oil Change????
  227. reset oil life monitor
  228. My airbag light is on??
  229. USB adapter
  230. Replacement Wiper Blades for Fit Sport
  231. Detailing guides for every process
  232. How do you black out your headlights
  233. Why not to hand polish your car
  234. no tailights now!!
  235. Fit Sport Auxiliary Socket
  236. What is the best way to clean my exhaust?
  237. Oil Filter Removal
  238. oil life is on -numbers LOL!!
  239. How to Remove A Scratch On Your Car
  240. How to Change Automatic Transmission Fluid?
  241. Need help removing windsheild wiper plastic.
  242. Washer fluid problem
  243. Someone with a Helm manual please!
  244. Detailed a swirled civic
  245. Water spots
  246. How to bleed the brakes on an 08 Fit
  247. rear strut bar diy?
  248. oil life --> how does it measure ??
  249. Brakes noisy after downhill braking, help?
  250. Karcher Alloy Wheel Brush
  251. Quixx scratch remover review
  252. Why NOT to go to drive through washes
  253. DIY: Honda Accessories Installations
  254. The last wheel brush youll ever buy!
  255. DIY: Bolt on Projector Lens
  256. Disconnecting alarm horn.
  257. Opinions on Meguiar's NXT Generation Tech Wax
  258. My new switchblade key fob
  259. Aussie Fit DIY, have a look through..tons of DIY for us
  260. Marks on wheels from snow chains!!
  261. water filter?
  262. XM Radio install......need info
  263. cheapest air filter?
  264. Tip: Cleaning the upholstery
  265. 08 Fit Dome/Interior Lights Help!
  266. DIY: Changing Headlight Bulbs
  267. DIY Brake pads?
  268. Turbo timer install questions
  269. HELP with fan, a/c, heater console
  270. Help for skunk2 shortshifter
  271. removing/white front reflectors
  272. ANyone DIY on the fuel filter?
  273. Lost Rays Engineering wheel lock key... Help.
  274. BRAKE & ABS light on after tire cable install!!
  275. Tire Rotation and Wheel Bearing Noise
  276. I Fail...
  277. Short sifter install help!!!!!!
  278. It broke!!
  279. MTF magnet?
  280. After 100,000 miles...
  281. Tire Pressure
  282. DIY Seafoam
  283. What running 104 octane race gas on a daily drive will do to your spark plugs
  284. Best way to smoke taillights???
  285. What is the cold cranking amps for 07 stock battery?
  286. Hydrolock? any info guys?
  287. Air tools for working on suspension parts
  288. Engine Coolent level?
  289. May I have your advice please?
  290. Anyone wired Aftermarket CC with OEM controls?
  291. Time Lapse of my Honda Fit Wash - Fun video
  292. Washing car in winter?
  293. Automatic Door lock/light turn off
  294. Turn-Signal switch... wearing out?
  295. repair rith or left broken mirror
  296. Which is the best Meguiar Kit?
  297. Water leak into the boot
  298. Dash Rattle... Easy fix
  299. Changing Wheels with Power tools
  300. exhaust manifold for L15a2 ?
  301. Show your scratches!!! dents!!! etc...!!!
  302. Weird Rub/Grind Sound
  303. Buzz Bomb
  304. need help with foglight?
  305. Emissions light on
  306. slotted? drilled? oem? Rotors.
  307. DIY: Oil Change on 2007 Fit
  308. 2007 Fit Transmission Selector Light
  309. Running water sound when stopping/moving
  310. [HOW TO] Detail your Engine - Make it look like the day you bought it.
  311. [HOW TO] Remove Water Spots from your Trim/Molding
  312. intake filter
  313. switchblade key - cheap alternative
  314. Fit Car Cover?
  315. Strange OBDII Code - Definition?
  316. Ran out of gas and now the fit wont start HELP!
  317. mother-[bleep] paint -.- help me?
  318. Broke my HVAC
  319. Tar spots and those annoying orange spots
  320. Steering wheel and defroster
  321. h conversion
  322. I need a new front lower arm!!!
  323. High Pitch whine emanating from dash at high speed.
  324. Wiring Diagram "want to add some mods"
  325. Car duster
  326. Broken Mirror
  327. Fit care in the winter
  328. has anyone tried the rear brake conversion
  329. DIY: Installation of hard mount shifter bushings in an 07-08 GD3
  330. DIY: Installation of lowering springs on 07-08 GD3
  331. Maintenance Minder B1
  332. The "I should have done it myself" Thread
  333. No Highbeams!
  334. ETCS Learn Procedure
  335. FYI -need oil for squeaks or lube
  336. rattle about the vents
  337. Can I use a razor blade on my roof?
  338. New fit owner
  339. Please help. About Fit's battery.
  340. Keeping engine bay clean??
  341. How often should I claybar my car?
  342. how to fix drv side door lock
  343. question about Amsoil
  344. Two Ways To Prevent A/C Damage from Rocks DIY/Photos
  345. How long did your clutch last?
  346. Bay Area NorCal car washers?
  347. Mugen Short Shifter vs. T1R Quick Shift vs. Stock
  348. changing the head light bulb!!
  349. wiring help for sidemarkers
  350. Rusted disc brakes on 3,000mi Fit?!?!
  351. Keeping pets off Fits
  352. Paint stains on white car
  353. Question for detailers
  354. electrical manual, looking for 1-3 pg scan
  355. S2000 fit?
  356. Tools of the Trade!
  357. T1R tow hook
  358. Weapon R Engine Torque Damper
  359. Need a front & rear lip DIY. Please Help!
  360. CVT getting sluggish....should i change oil ?
  361. Another what is it? question
  362. what is this?
  363. Cleaning for new car
  364. Homemade techniques to popping small dent?
  365. Pine Cones!
  366. Recommended DIY alarms
  367. Pump Motor Water Windscreen Washer Problem
  368. hate trucks
  369. oil change
  370. Brake Pad Change
  371. poor gas millage :(
  372. Gutted cat now have indicater light :(
  373. Dull Spot in Clearcoat ?
  374. Door sill paint
  375. Stereo Install
  376. How do I add accessory wiring
  377. How do you remove front lip?
  378. scratch on door still
  379. How do i take off the rear viper
  380. Programming OEM Fit Sport Key?
  381. Can you make windshield wipers faster??
  382. Worst Luck Ever..
  383. Slow power windows
  384. UR Alternator pulley replacement
  385. Steering wheel not straight?
  386. Prestone Flush kit Where is the heater inlet hose on the Fit
  387. Engine accessibility on the '08 vs.'09
  388. Online Factory Parts stores that don't kill you on shipping charges
  389. Constant speed "stutter"
  390. Looking to replace stock spark plugs with aftermarket plugs...
  391. New oil change analysis
  392. Dome Light Access
  393. Removing Fit Sport rear hood spoiler?
  394. Waxed with TurtleWax Liquid Paste Wax
  395. 2008 Milano Red Honda Fit S BRA
  396. Fuel Gauge reading FULL!!
  397. n00b mistake...need help
  398. K&N Drop-in Air Filter
  399. ArmorAll Gift Pack Deal
  400. DIY - 06+ Civic Si/Type R Shift boot into Fit
  401. 07 Honda Fit Sport spoiler
  402. DIY paint manifold cover
  403. Quick Wiring Question
  404. Service Manual
  405. Floor Illumination Lights
  406. RejeX
  407. Door sill lights!!
  408. DIY: T1R Sway-Bar
  409. **** ME SIDEWAYS....4 day old fit.****ed side mirror.PICS and please help =-(
  410. :( parking spot tore off my front end...
  411. Help with Engine Sputtering..
  412. Fixed Noise From Sway Bar
  413. Jack stands and jacking spots
  414. where is the horn located 2007 honda fit
  415. DIY water/oil temp guage install?
  416. clean throttle & intake
  417. Few engine mod questions. One is really dumb.
  418. DIY Side view mirror?
  419. help: AT tranny fluid
  420. malfunction indicator(mil)...thinkin the maf
  421. fogglights
  422. Fit to be tied! Rattle by right back window. Grrrr.
  423. DIY Password JDM CF Intake Manifold Cover
  424. oem rear bumper protection tape
  425. Claybar Liquid Applicator?
  426. Honda Access JDM Slim Visors
  427. Cleaning Tinted Windows
  428. Interior Windows (with tint)
  429. oil level indicator check
  430. DIY: JDM Honda Access Slim Visors Install
  431. Interior scratch fix?
  432. Faulty A/C
  433. Scratched/Gashed Dashboard Plastic: Repair Ideas?
  434. help!!!! check engine light is ON after...
  435. mt fluids
  436. paintinf foglight housing???
  437. T1R rear disc conversion package!
  438. power steering noise
  439. Detail wax
  440. debadge
  441. OEM replacement parts online
  442. Who makes suspension bushings?
  443. Concrete curb - 2, Fit paint - 0 :(
  444. Installing Fogs on a Base model
  445. Do i have a dead battery?
  446. WTF CEL! no recent mods either. any ideas?
  447. foglight question...
  448. DIY Switchblade FOB with Trunk Delete, Completed with Pics!
  449. Q:Clunk sound Jazz CVT
  450. Sunscreen REMOVAL Pls Help!
  451. Is there an inexpensive why to repair wheels
  452. estimated time for clutch install
  453. I LOVE the fit, but I HATE it right now...
  454. bad clutch...safe for 4 hour drive?
  455. Q: Brake system
  456. Honda Jazz Tail Lights
  457. skunk2 short shifter?
  458. how to adjust headlight aim...
  459. Jack stands or ramp for oil change?
  460. Mugen Visor Care
  461. independent fog light question?
  462. windshield spots won't come off!
  463. 07 stereo help!
  464. detail products questions
  465. Axels are taking a S**T
  466. Dealer's protective coat and waxing
  467. DIY: Independent Fog w/ Original Switch.
  468. English Instructions
  469. Inside Paneling of the Hatch
  470. DIY: T1R Crankshaft Pulley
  471. Touch Up Paint, You know you need it...
  472. Ask the dealer not to "prep" wash the car?
  473. Installing Rear Spoiler
  474. best way to get rid of sap?
  475. How to: Remove vinyl or sticker pinstripes.
  476. Seems only option is to force flush Transmission
  477. Ice Car Wash fluid
  478. Sticky fom the Dealer . . .help me de-sticky!
  479. Oil Change/Filter Change Question
  480. Has anyone installed a window module with a aftermarket alarm/starter?
  481. anyone's fit have rough paint from the factory?
  482. slick feel
  483. Replaced A/C Condensor
  484. DIY: Independent Fogs
  485. Darn garage!
  486. Another quick question about pnp Hid
  487. Part # of the oil drain plug gasket?
  488. Anybody done a tyre rotation?
  489. air ratchet question?
  490. Water sloshing around somewhere
  491. Removing Fit Center AC Vents
  492. 1st oil change lab test
  493. car repairman mechanic
  494. 2008 OBD interface for MacBook
  495. Anyone with an 08 Helms manual?
  496. So dirty!
  497. what mileages should do the oil change???
  498. Missing post -- oil test comparison
  499. best price on Honda Oil Filters
  500. Honda dealer oil
