DIY: Independent Fog w/ Original Switch.
Old Feb 25, 2013 | 03:46 AM
  #161
Logans07Fitty's Avatar
Anyone have any more info on the highbeams along with the Foglights. I was trying to follow the pictures that someone posted but can't seem to figure it out.
Old Feb 25, 2013 | 08:25 PM
  #162
Vindicatedfit's Avatar
Any one do the got a diy for a ge8 yet?
Old Feb 26, 2013 | 08:10 PM
  #163
pearl's Avatar
Great tutorial, very easy to follow and a simple project.
The wire you need to cut is on the top of the clip, the second one in from the left. The photo has a little of questioning to follow, but makes sense if you read carefully!
just make sure you grab the right 10 amp fuses! I grabbed ones that were a little bigger. same price, just an extra trip to auto zone.
Thank you!
Old Dec 16, 2014 | 04:50 PM
  #164
uloco's Avatar
sorry to bump old thread, but just got myself a preowned fit and would like this mod on my car. anyone in socal can do this? i can buy the parts. hahah
Old Jul 19, 2017 | 10:30 AM
  #165
PaceP's Avatar
I will definitely be doing this!
Old Apr 8, 2020 | 01:54 PM
  #166
CnK827's Avatar
So glad these photos are still around. Will tackle this soon. One question: I read j5ive's DIY on this and he mentioned grounding the white/red wire coming from the fog relay in the fuse box. Does anyone know this does?
Old Aug 2, 2020 | 07:09 PM
  #167
NEGD3's Avatar
I completed this mod today, it was very easy and took maybe 30minutes.
it cost me just eleven dollars. 7 bucks for the fuse-tap and 4 for a few 10a fuses.
I had a 12” length of wire which was more than enough, and I used solder-seal but connectors I also had on hand.
based on an earlier post in this thread I used the empty fuse slot #2 instead of removing the 10a fuse and tapping into #3.
#2 is still ignition switched. I like that much better than sharing #3.
Old Nov 15, 2021 | 12:20 PM
  #168
nik danger's Avatar
Why use foglights?
Originally Posted by leeman
hey guys sorry to ask such a noob question but when do you use just the fog lights? seems like the only time you'd use fog lights would be in conjunction with the regular headlights. I'm asking because I'm considering doing this because it seems cool, but seeing as to how I've never done anything like this before I don't want to run the risk of damaging my car
A driver uses the foglights when driving through fog - the position of the light and the color of the light make all the difference. Mounting lights as low as possible helps prevent the fog from reflecting back to the driver. Using the lemon yellow color, not white or amber, actually "cuts" through the fog more increasing visibility. Just look at the French, France gets so much fog that lemon yellow fog lights are required on all french made cars AND they are operated and turned on/off independently from all other headlights.
Old Jul 14, 2024 | 09:36 AM
  #169
jbbuilt's Avatar
Any luck on canadian gd3 sport. This tutorial didn't work. Fogs not working now.
AnlDyxp_GD3
Apr 2, 2010 01:38 AM
hare
Apr 27, 2009 04:43 AM
Mugen_Dom
Apr 28, 2008 05:20 PM
michaelpotter
Apr 11, 2008 10:05 PM
Oofie
Jan 4, 2007 09:44 PM
