KraftWerks Supercharger Kits
Old Feb 29, 2008 | 02:10 PM
  #461
OJRKraftWerks's Avatar
Former Vendor
Whoa guys! Whoa!
I am just trying to give you the most information possible, as often as we can.
Siphon vs Ours:
That dyno is NOT a re-post of the Siphon Mag. It is a fresh graph from testing. So we are showing our consistency.
Auto:
Automatic kit information will release shortly. Like I have said before, we must test to ensure that the kits work for both MT and AT flawlessly. We do things right the first time.
Header with Cat:
IIRC, the header is what produces the majority of the gains. The stock header has a HORRIBLE collector, and gains are greater once you start adding boost. I will see if I can find that graph in the files, upon files of dyno runs.
Dyno Numbers:
Like previously stated, Chris had mis-information, and had been running the Siphon setup (Base Kit with Injector Package and Header-Back exhaust)the entire time.
We are working long hours to get this product ready and out to you guys. Its a process, and I know it is time consuming. Trust me, I wish I could send them out, so I could stop getting beat up you gents.
-OJR
Old Feb 29, 2008 | 02:20 PM
  #462
Former Vendor
Originally Posted by 07_g_fit
How much does the injector upgrade cost on top of the base kit?
How much will the shipping kit weigh, and where is it being shipped from (so I can calculate shipping to Canada)
Will you give heads up like you did for the miata letting us know the last day for pre-order to get the discount?
Can I pay for the full kit instead of just the pre-order?
Thanks for all the info thus far, hope I'll be one of the first to support your further R&D
1: Injector Upgrade Pack pricing will be announced in the next week or two.
2: We don't know what the final shipping weight will be yet. If I knew, I would be sending you guys kits.
3: We will give FitFreak and the Interest List a heads-up for the last week of pre-orders. We have not released the Miata product... I think you meant S2000. But yes, they have been well informed of the last pre-order day.
4: For pre-orders, we only accept the standard deposit at this time. The remaining balance of the kit will be charged before the kit ships.
And we appreciate the support!
-OJR
Old Feb 29, 2008 | 03:01 PM
  #463
Former Vendor
Originally Posted by ToyotaLover
What is an estimated ETA date of the release of the kit, and what is the hold up (MT and AT)?
How many wires does this Supercard/piggy back require to tap into on our ECU or is there a plug-n-play harnes similar to the HKS setup? Is it recommended to soilder all wires if it requires tapping into our wiring?
Is there any electrical mods that will conflict with this SUpercard, per say the ignition boosters, and stuff?
So the Supercard has the maps with and without upgraded injectors? or is it a different Supercard map we need to upload, or exchange?
When will the intercooler kit be released? Will it be along side the 10psi kit?
I'm interested, but i hate sitting on my hands.
Good questions!
1: Estimated Ship Date is Late March for MT. We will announce if AT will be included in the Late March release, or carry its own release shortly after the MT release. By the way, we offer local pick-up.
2: The SuperCard is plug-n-play directly to the injectors. The ECU will never see the SuperCard unit, which allows the ECU to operate as normal. The SuperCard has a full injector harness, so you don't have to solder or wire anything.
3: The SuperCard should be connected to switched power according to the instructions.
4: The Injector Upgrade Package will include Injectors, Plug-n-Play Injector Clips, and revised SuperCard chip.
5: No time line has been established for the intercooler package. We have not had high intake air temperatures, even at 10 PSI! We will announce the High-Boost kit and Intercooler status in Late March/Early April. We will offer Base Kit owners the option to upgrade to the High-Boost Kit.
-OJR
Old Feb 29, 2008 | 03:10 PM
  #464
Former Vendor
Originally Posted by REXXXXXXXXX
Since the engine management cannot be tuned, does that restrict our options for other upgrades, such as that WR intake mani coming out? should we be worried about A/F? I would think a/f numbers would vary greatly from one setup to the next depending on what ppl already have on their cars...
Edit: One more question - Does the kit require the bypass valve it comes with, or can i switch it out for another one or a BOV? I don't think it makes a diference, does it?
1:Our kit has been tested with the stock intake manifold. We have not tested it with any after-market manifolds.
2: Our kit uses a standard Bosch-type bypass valve. This valve is perfect for everything the Fit will be doing. We use this same valve on our 360+WHP S2000 kit.
If you would like to change valves, continue to use a bypass/diverter type valve. These valves do two things: Bypass at cruise speed for increased fuel efficiency, and blow-off excess pressure in the tubes when you chop the throttle. Blow-offs simply blow-off.
-OJR
  #465
gloryhound's Avatar
will you guys offer supercard upgrades/updates if something unforseen pops up fuel mapping wise?
*cause a few hundred kw supercharged cars on the road vs your smaller number of test cars, some random road/weather/area problem might pop up.
Old Feb 29, 2008 | 03:17 PM
  #466
Former Vendor
Of course! If there are any unforeseen issues with mapping, we will re-map and take care of our existing KraftWerks customers. No worries.
-OJR
Old Feb 29, 2008 | 03:20 PM
  #467
JDMchris.com's Avatar
I run THIS
-OJR
Old Feb 29, 2008 | 03:32 PM
  #468
Zangoose GD3 Blue's Avatar
hey chris are you going for a K20 swap for your project fit...
Old Feb 29, 2008 | 03:44 PM
  #469
I run THIS
no way! SOHC for life!
Old Feb 29, 2008 | 03:57 PM
  #470
SickFit's Avatar
NO HOMIE! Chill! lol. I want to see the high boost!
Old Feb 29, 2008 | 05:16 PM
  #471
ToyotaLover's Avatar
Good questions!
-OJR
If the Supercard is connected directly to the injector harness, how does the Supercard read the fuel ratio from the ECU/O2/Intake temp? Does it also tap into one of these as well? I’m guessing it’s a plug and play to these harnesses as well.
Old Feb 29, 2008 | 05:53 PM
  #472
eldaino's Avatar
-OJR
awesome!
ojr, thanks for all the thoughful posts, and sorry if you feel like we have been beating you up, we love you guys and all the hard work you have done!
and i didn't mean to presume about the dyno being from siphon...but it is the EXACT same numbers...and like you said, that is some major consistency!!!
Old Feb 29, 2008 | 05:59 PM
  #473
Former Vendor
As stated before, the SuperCard connects directly to the injector leads, and then plugs into the injectors. The SuperCard then stretches the injector pulse-width to what is required at the current boost level. No need to tie to the ECU. We are seeing what the ECU outputs to the injectors, and adding fuel accordingly.
How does the SuperCard see boost?
With an on-board pressure transducer.
So the SuperCard sees injector duty cycle output and manifold pressure. The SuperCard contains proprietary software that is able to determine proper management for all different types of conditions.
Hope this answers your question.
-OJR
Old Feb 29, 2008 | 06:02 PM
  #474
Former Vendor
Originally Posted by eldaino
awesome!
No problem, I could see how it was confusing...
-OJR
Old Feb 29, 2008 | 06:17 PM
  #475
Former Vendor
Originally Posted by xorbe
Are either of these not "CARB legal"?
header change.
exhaust change.
Obviously, cat-delete won't pass smog.
Upgraded injectors may or may not pass visual inspection, right?
Cat-Back exhaust usually do not affect emissions, because the last emissions component is the catalytic converter.
Headers do require CARB-certification in CA, because they can affect the catalytic converter performance.
If you have a stock header and catalytic converter, with after-market exhaust, the standard Base kit will be fine. No need to upgrade the injectors.
-OJR
Old Feb 29, 2008 | 06:19 PM
  #476
I run THIS
They most likely wont realize the injectors have been changed.
Old Feb 29, 2008 | 08:16 PM
  #477
xorbe's Avatar
What are the odds on a changed header sticking out like a sore thumb?...
Old Feb 29, 2008 | 09:25 PM
  #478
leonine's Avatar
all of the aftermarket headers i have seen do not incorporate the oem heat shield so anyone who knows what they are looking at will notice them right away.
Old Feb 29, 2008 | 10:00 PM
  #479
lol now im interesting in to that project... keep us posted
Old Mar 1, 2008 | 09:33 AM
  #480
REXXXXXXXXX's Avatar
Frequent FitFreak Poster
with all the questions answered, i'm suprised nobody has "krafted" their own SC kit already . Thanks for all the great info. Just a couple more weeks and then
