KraftWerks Supercharger Kit Info v4.0
Old May 8, 2009 | 02:06 PM
  #481
Texas Coyote's Avatar
I am going to need more beer, or smaller hands with much longer fingers.... I really don't drink very often. I do feel that is the proper thing to do right now though.
Old May 8, 2009 | 02:55 PM
  #482
MNfit's Avatar
Originally Posted by equiptcustoms
is it available for the fit 2009 ge a/t???? very interested in supercharging it hehehehhe
As far as I know there is no kit available for the 09 Fits
Old May 8, 2009 | 03:11 PM
  #483
Koi's Avatar
Koi
Originally Posted by revd34
i have that noise too. i think it is because of the restriction piece. its like it wants to suck more air in but it is restricted
Originally Posted by Wave
this would be my guess too.
Seems like a normal thing then. Thanks guys.
Old May 8, 2009 | 03:53 PM
  #484
revd34's Avatar
what exhaust size are you guys running? i'm running 50mm (metric conversion calculator says its about 2 inches) is that sufficient or should i get bigger piping (maybe 2 1/2 inches)?
Old May 8, 2009 | 04:34 PM
  #485
If you feel that it is running a little lean and you have gone to colder plugs, you might consider replacing the axle back pipe with the stock one and see if it helps.... If you are like everyone else you will probably upgrade to more boost and can go back to the axle back pipe that is now on it.... First thing is to check the plugs.
Old May 8, 2009 | 06:01 PM
  #486
DynamicFit's Avatar
Straight pipe with 50mm piping should be more than adequate, you could always go and dyno check with yours against the 60mm skunk 2 setup. I don't really think there are much choices in terms of other exhaust systems.
Old May 8, 2009 | 10:32 PM
  #487
explosivpotato's Avatar
I'd think the 50mm should do fine for what you guys are pushing.. the 60mm is really only going to buy you a little power when running a higher-powered turbo setup. It's mostly for spool time, which you won't need to worry about.
Old May 10, 2009 | 01:24 AM
  #488
Koi's Avatar
Koi
So right now, I'm trying to direct cold air from the cowl (by use of a scoop) towards the KWSC's filter on the opposite side. I'll probably fab something with fiberglass to work with the scoop I have now (or design a new one altogether) - but I was wondering if anyone knows if ABS piping will be okay to use in the space behind/above the engine (above the supercharger/header, across the length of the engine), or if I should use metal piping to direct the air? I ask because I have no idea if the ABS can handle the heat in that region. I'm thinking I'll also try connecting the air that used to be directed to the stock intake to the same piping to bring cold air from both the cowl scoop and the front lower grill/fender to the KWSC's filter.
If anyone has anything to say about what I'm planning I'd love to hear it.
Old May 10, 2009 | 04:33 AM
  #489
PVC is cheap stuff so you won'be out much if it doesn't. You could wrap it in some insulation material that has a fire proof backing. I have been thinking about heat extractor that fits over the intake pipe and holds water that is pumped through it and recirculated through an old heater core or small radiator that is used as a cooling system add on, and is available at J.C.Whitney along with a pump made for use in R.V. sink..... AS soon as I complete the installation of the KWC I am off to the plumbing supply section . What I am thinking about would be smaller, cheaper and more effective than an air to air heat extractor that just uses air alone to cool in coming air, and would cost about $120.00 using new parts.
Old May 10, 2009 | 07:29 AM
  #490
Midnightfit's Avatar
Good new I talked with Kraft Werks Yesterday and tell told me the hondata reflash and high boost kit are just about to be released. They said they made 175+ whp and 160 tq. All the way to the new redline- which they did not say what it was. I hope like 7200 rpm but i should have asked. The high boost kit use a small intercooler that goes under the hood and get air from a scoop that is like the ram air one made to go by the wind shield wipers. I do not know what other support mod that car had but thats pretty good. O and for the turbo guys If you made 175 whp on your first dyno pull and did not on the rest stop playing up your numbers.
Old May 10, 2009 | 07:36 AM
  #491
Wave's Avatar
and so it begins....
Can't wait(even though I have an A/T)!
Old May 10, 2009 | 08:13 AM
  #492
ap_fit's Avatar
I'm not sure if it's worth the trouble. Any cold air you push towards the filter is going to be a loss to the rest of the engine bay (might get a little warmer in there with less air flow). It'll probably negate any gains you might have seen. Getting colder air into the supercharger could help but it also means the supercharger will just warm it up faster. Which is why people usually aftercool FI setups.
If you look at the prototype kit on JDMChris's car they routed the charge piping around the back of the engine bay. The kit as it is now obviously is routed around the front. The only reason I can think to do that would be to allow the air moving into the engine bay to cool the charge piping. The output of the supercharger is 1.75" that is stepped up to 2.5" when it crosses over the front of the IM (fits on the TB) this change in diameter probably also helps with cooling.
I would really like to see an aftercooler. A little water-to-air could fit right in the location of the stock air box, just need to find a new location for the oil reservoir. Obviously they designed the kit not to need one so it's safe without it. The piping does get pretty warm after a good drive.
Consider that if you're running 12 psi on pump gas without an intercooler. Timing will most likely (I have no experience with this engine) be retarded a few degrees to prevent detonation. So let's say 5-6 degrees which will probably make you loose around 20-30 hp Making the final numbers more like 135 versus the 165 you'd have with an intercooler.
I guess what I'm trying to say is that the addition of an intercooler is logical with the release of the high boost kit so it's more competitive with the T1R kit.
Old May 10, 2009 | 08:16 AM
  #493
ap_fit's Avatar
Aren't they closed on saturday?
Old May 10, 2009 | 08:57 AM
  #494
DynamicFit's Avatar
You are in for a pleasant suprise then my friend. Lets just say what they have coming out is one of the cleanest setups for high boost FI, I've seen. Can't wait.
Old May 10, 2009 | 01:55 PM
  #495
I can't see how they can not use the air to water to air method for heat dissipation in such a small space.... 175 HP sounds reasonable to me. I was getting ready to start working on my own heat extractor, but I will wait to see what is coming out.
Old May 10, 2009 | 02:03 PM
  #496
JDMchris.com's Avatar
I run THIS
Ive been running the highboost kit with no IC for awhile with no ill affects. Piping heats up a bit, but anything under the hood heats up and its no where near the extent of a turbo. The new IC looks amazing!
Old May 10, 2009 | 02:22 PM
  #497
Koi's Avatar
Koi
Agreed, I got to see a peek when I was over there. Definitely a setup worth looking at once they officially announce/release it, I'd get it if there were a highboost for AT.
Old May 10, 2009 | 02:45 PM
  #498
Well, is it an air to air, or air to liquid to air design?.... I don't care if it is pretty, how effective is it, and how much money am I going to have to shell out?..... Now I have to return to the barn and complete the installation of the 5 Lb. boost unit. It is two hours till my next beer break.
Old May 10, 2009 | 02:59 PM
  #499
I run THIS
its air to air.... Oscar Sr wouldnt have designed it this way if it wasnt efficient. He told me that the difference in HP from a big FMIC to this small top mount was 2-3hp....
Old May 10, 2009 | 03:59 PM
  #500
ap_fit's Avatar
yes, I feel your pain. I installed mine outside in the sun in 90F heat. I felt like I had been put through the ringer when I was done. That engine bay is the bane of my existence.
