KTuner ECU Reflash
Old Jan 11, 2015 | 05:11 PM
  #81
07fit916's Avatar
Originally Posted by Myxalplyx
Wow..this is epic. So you are the first to reflash using a Ktuner on a Fit? You reflashing with a base map? Who will be doing your tuning?
I'm all ears on your first impressions and final result. Good stuff! And congrats!
I think I am the first yes. And yes this was just using the stock basemap and checking the secondary o2 sensor disable. Probably going to be tuning with vit the same as you.
Old Jan 11, 2015 | 09:11 PM
  #82
555sexydrive's Avatar
You really shouldn't have to disable the secondary o2, well wait, you are using a replacement exhaust piece that eliminates your primary cat right?
Old Jan 11, 2015 | 09:16 PM
  #83
07fit916's Avatar
yeah using t1r header (deletes primary cat) and t1r racing converter (deletes secondary cat). the check engine light came on for code P0141. reflashed the ecu to disable the sensor and the check engine light was off.
Old Jan 12, 2015 | 12:03 AM
  #84
Secondary cat, not really an issue since it resides behind the secondary sensor. Curious to see what all you guys can pull (unhide) out of the L15 with this.
Old Jan 15, 2015 | 12:12 AM
  #85
FitRick's Avatar
When you say the 12-13 MT, I assume you're talking about the sport? If so... �� But if you're talking about the 12-13 MT base... ��
Old Jan 15, 2015 | 12:15 AM
  #86
07fit916's Avatar
The ECU part numbers are the same for 12-13 MT base and sport so it should be compatible. I'll let Ktuner confirm though.
UPDATE: I began the tuning process with VitViper today. He sent the first calibration and I sent back the first datalog.
Old Jan 15, 2015 | 12:27 AM
  #87
FitRick's Avatar
Awesome! Thanks for the info!
Old Jan 15, 2015 | 10:22 AM
  #88
KTuner's Avatar
I have support in for 12-13
RP3-A16 and A17 for MT
RP3-A76 and A77 for AT
It's possible 2011 will run on the 12-13 codebase, but someone will have to be bold and try at their own risk.
I'm looking into 09-10 as well. 07-08 will be last since there's something available already.
Old Jan 15, 2015 | 12:55 PM
  #89
jibberjabbs's Avatar
I was curious about the differences in the years, so I poked around in the catalog.
Old Jan 15, 2015 | 02:38 PM
  #90
Myxalplyx's Avatar
Where the hell were you poking around at? This is good info. Is this info accessible to anyone?
I updated the first page with this info.
Old Jan 15, 2015 | 02:45 PM
  #91
1SickVeilsideZ's Avatar
I'm wondering if it will be the same for all years? The sprintex supercharger piggyback works for all years manual and auto. I was under the impression the only difference was the VSA?
In any case I'm down for some testing on my 2010 with sprintex supercharger.
Old Jan 15, 2015 | 03:04 PM
  #92
[QUOTE=Myxalplyx;1287362]Where the hell were you poking around at? This is good info. Is this info accessible to anyone?
Well I had to dig around a bit, But this is where I got the data:
Honda Automotive Parts
There are enough similarities for me. I would try the 2012 firmware on my 2011, but Ktuner in not interested in testing on a non-local car. The 2010 has different part numbers for the wire harness, air flow sensor, and O2 sensor. So I would not try the 2012 firmware on a 2010 unless I confirmed the sensor outputs and such.
Old Jan 15, 2015 | 03:19 PM
  #93
BMW ALPINA's Avatar
A lot of sales opportunity will come from Sprintex Supercharger owner,
especially if K-Tuner had all the function that available with AEM F/IC-6.
Old Jan 15, 2015 | 06:22 PM
  #94
lakia5524's Avatar
Sprintex is for 4thgen fits I believe, I called sprintex and wasn't comparable for my gd3 so kraftwerks was my best bet aem I would say is the best ecu tuning for the fits more can be tunned but it is expensive
Old Jan 15, 2015 | 09:39 PM
  #95
4th gen Fits?! The Fit 3 was only just released.
Old Jan 16, 2015 | 12:51 AM
  #96
lakia5524's Avatar
Lol your right I ment to say the ge8
Old Jan 16, 2015 | 10:56 AM
  #97
KTuner's Avatar
If someone local tries it and it fails I give them a car to drive, get a new ECU, program it here. Total cost ~$100.
If someone in the field tries it and it fails I have to rent them a vehicle, get a new ECU, ship it to them, tow their car to Honda, and pay Honda to program it. I think you see my point.
Old Jan 16, 2015 | 01:34 PM
  #98
Yes, Dealing with a failure would be a PIA...... So we need a local with a 2011.
But this made me think about swapping an ECU. I have a HDS clone and might be able do a ECU swap if I could get a immobilizer key code.
Old Jan 16, 2015 | 01:47 PM
  #99
KTuner's Avatar
If you have a HIM clone you won't be able to get those codes more than likely.
Old Jan 16, 2015 | 02:20 PM
  #100
07fit916's Avatar
Lol and here all this time I thought I was gonna be SOL if something happened. But I wanted to try anyway lol
