Independent Fog Light (First Post has answer!)
Old Jan 20, 2007 | 06:34 PM
  #181
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Did this just now. Foglights come on with key on (via switch of course) running lights AND with headlights.
All I did was the mod leonine mentioned. Dont have high beams since I have an HID kit though. Finally!! Love it!
Old Jan 20, 2007 | 06:44 PM
  #182
arsonall's Avatar
thank you leonine and j5ive for figuring this out. been watching and waiting for a definitive answer to this without having any problems like the high beam. great job!
Old Jan 20, 2007 | 08:25 PM
  #183
TomiGunz's Avatar
Frequent FitFreak Poster
First things first.. Thanks a bunch for the write up!
Just a tad confused here..
When you cut the wire, the connector side goes to the 10amp fuse and fuse box.
The other wire goes to GND???
Also, how come you have 2 10amp fuses??
Old Jan 21, 2007 | 12:23 AM
  #184
Posts in the NUUDE
The other half of the red/yellow wire I capped off.
I used the same connector as leonine. The mod only works with both fuses installed.
Old Jan 21, 2007 | 12:41 AM
  #185
TomiGunz's Avatar
Sweet thanks.. I'm going to go find that fuse tomorrow and wire things up..
Old Jan 21, 2007 | 05:26 PM
  #186
LiL Wee FIT's Avatar
For those of you that are in Canada...
The "add-a-circuit" costs 14.99 at crappy tire...
Hoping to find another place that sells it for cheaper
Old Jan 21, 2007 | 10:45 PM
  #187
TomiGunz's Avatar
Does it buzz when you have the key out of the ignition with the fogs on??
Old Jan 22, 2007 | 08:09 PM
  #188
TomiGunz's Avatar
Okay I got it all wired up and everything and tested. It works. But when I hit the high beams, the fogs still turn off..
and it would be nice if it turns off when the key is on "off" position. I want them to turn on when I give it a click. Wonder if I can put the fuse where the radio fuse is.
-Tomi
Old Jan 23, 2007 | 09:49 AM
  #189
4dr4life!'s Avatar
Thumbs up
-Tomi
Yes all you have to do is find a 12v source that turns on when you turn the key to the first position. I used the radio fuse
Great job on figuring out the fog light solution j5ive & leonine
Old Jan 23, 2007 | 02:09 PM
  #190
Posts in the NUUDE
Did you mean on? Mine turns off in the off position, but I cant turn them on.
Old Jan 23, 2007 | 04:15 PM
  #191
TomiGunz's Avatar
nope,, I meant for it to be OFF on OFF position so I won't have to switch the fog lights off everytime I leave the car.. Just one more thing to do when you have a kid and diaper bags.. =)
Old Jan 25, 2007 | 09:04 AM
  #192
Hmm TomiGunz was saying that his fogs won't turn on when his high beams are on?
Also, is there anyway to make it so that the lights inside don't dim when I turn my fogs on?
Old Jan 25, 2007 | 04:33 PM
  #193
j5ive's Avatar
-Tomi
Yup, just find a fuse location that is ignition switched and you're good. The fogs will turn off with the ignition.
As for the high beams, did you ground the red/white wire at the fog light relay? If you didn't and ONLY followed Leonine's pictured instructions, the relay is still grounded via the low beam in the fog switch. This step is included in my instructions.
hope this helps.
Old Jan 25, 2007 | 08:14 PM
  #194
TomiGunz's Avatar
hope this helps.
That's what I thought I didn't do. I will have to reread up on that since I don't have any idea where the relay is.
Thanks!
Old Feb 7, 2007 | 05:34 AM
  #195
j5ive's Avatar
Just added this how-to to my blog. I hope you don't mind Leonine, but I borrowed one of your result pictures. Thanks again man for testing out my suggestion.
Old Feb 10, 2007 | 11:57 AM
  #196
fits_all's Avatar
this sh*t seems to be hard dunno why, im a stupid when it comes to electrical things. if any of you guys who pull it apart nicely by coincidence take a vacation to Puerto Rico, let me know...ill reward you with some Medallas
Old Feb 26, 2007 | 10:12 PM
  #197
leonine's Avatar
Glad i could help. Wouldn't have even though about attempting it without the help of other members here. Again my mod was done to allow the fogs to come on by themselves, with parking lights, or headlights. If you want them to come on with highbeams j5ive posted a how-to a few posts back. I did that also but sorry i didn't post pics just followed j5ive's post and it was very easy other than trying to cram myself under the steering wheel.
Old Feb 27, 2007 | 06:00 PM
  #198
fitoromocto's Avatar
Did the mod last weekend 20 minute from start to finish my only worried was the note you posted: "***NOTE*** .the gauge console dimms when you turn them on." I was worried that the radio display would dim also when I turn on the fog but no problem the display only dim when the light are on. cool
Thank you again
Old Mar 28, 2007 | 04:13 PM
  #199
J.P.'s Avatar
just did this mod myself, took 20 minutes at most. Great job Leonine!!
Old Mar 28, 2007 | 04:42 PM
  #200
leonine's Avatar
No problem! Thanks to j5ive as well!
