Independent Fog Light (First Post has answer!)
Old Jul 16, 2006 | 10:37 AM
  #81
HotIron's Avatar
You know, if a Ford Windstar and a Ford Fusion can run with just fogs and parking lights, there IS no good reason why our Hondas can't.
Old Jul 16, 2006 | 06:28 PM
  #82
sillypuddy's Avatar
Someone that Posts too much
just because people can do it, doesn't mean they should...
-joe
Old Jul 17, 2006 | 12:36 PM
  #83
4dr4life!'s Avatar
Originally Posted by b17gsr
If you guys are relying on the schematic posted on page two, good luck. That's for the JDM model. The USDM and CDM models will have a different setup.
Its actually from the USDM Base Fit Fog Light installations...
Old Jul 27, 2006 | 07:45 PM
  #84
dougiepants's Avatar
Avid FitFreak Poster
So did we ever get a final copy of directions for the official how-to???
Old Aug 6, 2006 | 10:44 AM
  #85
Still curious???
Old Aug 6, 2006 | 10:57 AM
  #86
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
id like some walkthru stuff too
Old Aug 6, 2006 | 11:36 AM
  #87
Illusive's Avatar
I would love to do this too, since I took out my DRLs due to my HIDs. I'd rather be running the fog lights as my "DRLs" so the fuzz will stay off my back...I'm just using my indicators right now as my DRLs until I figure out this fog light trick. The place that installed my alarm said they would do it for me but want to charge me $100 to do it!!
Old Aug 6, 2006 | 10:59 PM
  #88
Well I hope the guys that did all of the work would be up for a propper write up
Old Aug 6, 2006 | 11:35 PM
  #89
leonine's Avatar
Did anyone get the issue with the high beam indicator light being on resolved?
Old Aug 11, 2006 | 04:04 PM
  #90
brdss's Avatar
I guess not!!
Old Aug 11, 2006 | 04:16 PM
  #91
Illusive's Avatar
nuuu cmon guys! I need to do this soon!
Old Aug 15, 2006 | 01:02 AM
  #92
alarmgui's Avatar
Disclaimer: The following is provided as a GUIDE ONLY, and neither myself, nor Fitfreak.net take any responsibility for the outcome of someone else doing the following. You follow these steps at your own risk!
Head light switch is low current on the park lamps and HL relay triggers but is full current on the dimmer side. (-) trig on the HL wire turns on the relay under the hood feeding 2 20A fuses then it feeds the common on the bulbs. Then the low and high beam wires go back to the switch to get a ground signal so they will light up. I cut the Red/White and grounded the car side so the Lo beams ALWAYs have a ground and stay on when using Hi beams. This comes out to around 120watts or 10-12 amps. No prob for the 20A fuses.
The fog lights where more troublesome and in retrospect I would just use a relay or DRL module. The Blu/Yel is in a large 3 pin heavy guage harness left of fuse box about even with door harness. Prob have to cut it and 5wire it since when the Fog light indicator was on, the stupid cluster interpretted that as the parking lights ALSO being on and dimmed... no other dash lamps or radio dimmed..just cluster..go figure.
If you wanna do it, cut the red/yel at the HL switch, cap of car side and ground switch side. Then on right side of fuse box are 3 relays on a pod(pops off with a pick tool). One with blu/yel on back is the fog light relay. Cut the red blue off (cap off the car side) and jump the relay side(lo current so no overloading issues) to the Blk/Org on the relay next to it(rear Defroster). It only has power when the key is in the RUN position and drops during crank. THEN...pop the cluster bezel loose and find the 3 plugs on the top of the cluster - right one has the Blu/yel in it close to center..just cut it and tape the ends. You loose the light but the switch is pretty obvious anyway. The fog light switch then also doubles as the DRL override switch.
Like I said...use a DRL module
Scott
Old Aug 21, 2006 | 05:52 PM
  #93
Thanks fot this
Old Sep 10, 2006 | 01:59 AM
  #94
b17gsr's Avatar
Got my service manual today. If you wire the red/yel wire to a ignition swiched source like 4dr4life! did in this post and ground the red/white wire on the fog light relay, you will have complete control over the fog lights.
I'll be doing the modification on mine in the next few days to work with the parking lights instead of the low beams.
Old Sep 13, 2006 | 09:42 PM
  #95
FrogDaddy's Avatar
b17gsr...you have steering mounted radio controls?
Old Sep 13, 2006 | 09:47 PM
  #96
sillypuddy's Avatar
didn't notice that... hook us up :-)
-joe
Old Sep 14, 2006 | 12:21 AM
  #97
b17gsr's Avatar
Old Sep 14, 2006 | 01:41 PM
  #98
4dr4life!'s Avatar
Thanks for the update! I put back my wiring so now I have to have the headlights on But its okay I'm glad I was able to help fellow members.
BTW when grounding red/white wire does that turn off the highbeam indicator or keep the fogs on while the highbeams are in use?
Old Sep 14, 2006 | 02:26 PM
  #99
b17gsr's Avatar
You only ground the portion going to the relay, not the rest of it (so cut it). The other portion is switched by a source, breaking the ground path. I don't have the manual in front of me to state exactly what.
Old Sep 14, 2006 | 04:33 PM
  #100
4dr4life!'s Avatar
Good deal! Having the manual must make a big difference while doing this kind of stuff
