TIRE questions,sizes, mounting,pressures ANY tire questions
Old Oct 19, 2006 | 11:30 PM
  #321
SSM0423's Avatar
Originally Posted by kyeguy82
I have used the Falken ZIEX ZE512 205/40/16 for a recent customer and he came back with a consistant pull on his car. We checked alignment, camber, toe, EVERYTHING, nothing seems to be out of the norm. I am getting the tires refunded and I already went ahead and sent the customer off with a set of new Toyo tires to keep him happy. I'm just wondering if anyone else has experienced anything like this.
Another question:
What tire are you guys all running on 16's? Brand? Specs? I've built about three Fit's at the dealership already, and this is the first with the problem. (I've used both 205/40/16 and a 205/45/16). It could also just be a tire defect. But also, I heard that some vehicles react differently to uni-directional tires.
Any comments are appreciated.
Thanks,
Mike
Whenever you run directional tires, you run the risk of a tire-directional pull. The part that suxs is you can't rotate it side-to-side without dismounting/remounting to rim.
I'm running P205/55r15 Dunlop Direzza's and they're the BEST performance tire I've felt yet!
I've seen non-directional tires have radial-pulls too so there's really no way to TOTALLY elliminate it... 99% of the time, Goodyear's don't have these issues. I've seen more issues with other brands.
Old Oct 19, 2006 | 11:43 PM
  #322
JonasM's Avatar
When I purchased my 16" HFP upgrade, the dealer looked up the recommend tire - Bridgestone RE750's I believe (don't have the car yet). I was happy with this choice, since it looks like a close cousin of the RE50's that the current S2000 comes with, which perform very well with decent tire life.
JonasM
Old Oct 20, 2006 | 01:38 AM
  #323
JDMish's Avatar
kumho 711's and 712's is what i've been throwing on our Fit's at work. havent seen any come back with any driving issues.
195/50r16's
maybe the 205's are large enough to cuase road pull in the lanes. you know the divets that occur on high traffic roads?
Old Oct 20, 2006 | 02:21 AM
  #324
MINI-Fit's Avatar
In 205/45-16 at Tirerack.com
(Max Performance Summer tire) Only one listed
Goodyear Eagle F1 GS-D3 $128 each
280 treadwear AA traction 21 pounds W speed rated
Excellent Performance minded tire for dry or wet. Can be used for street, light rain, at autocross and at the track.
(Ultra High Perf. Summer tire) many listed
General Exclaim UHP $59 each (excellent price/highly rated)
380 treadwear AA traction 17 pounds W speed rated
Avon Tech M500 $81 each
BF Goodrich g-Force Sport $70 each (great value/highly rated)
340 treadwear AA traction 20 pounds Z speed rated
BF Goodrich g-Force T/A KDW2 (unusual tread design) $122 each
300 treadwear AA traction 20 pounds W speed rated
Kumho Ecsta SPT $64 each
320 treadwear AA traction 20 pounds W speed rated
Bridgestone Potenza RE-750 $121 each
340 treadwear AA traction 21 pounds W speed rated
(Ultra High Performance All season tires) Good for wet/ light snow
Pirelli PZero Nero M&S $86 each (excellent tire/ good value)
400 treadwear AA traction 19 pounds W speed rated
Kumho Ecsta ASX $67 each
420 treadwear AA traction 19 pounds W speed rated
Need more info?- Contact Jim@tirerack.com
Old Oct 29, 2006 | 10:02 PM
  #325
iismileyll's Avatar
Nitrogen in the Tires?
So whats all this about nitrogen in tires? Pro/cons? Google isn't helping.
Old Oct 29, 2006 | 11:30 PM
  #326
Jetydosa's Avatar
AFAIK, nitrogen just isnt as effected by fluctuations in ambient temp as "regular air' is.
Old Oct 29, 2006 | 11:31 PM
  #327
crimsona's Avatar
Regular air consists of 75% nitrogen anyway...
Old Oct 29, 2006 | 11:37 PM
  #328
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
I suggest it. Only downside of putting it in is its not cheap. My job charges $25 but once its put in refills are free.
I got it free since I work there.
I noticed a 2 mpg difference in my Mx6 and I didnt even go through my whole tank.
Old Oct 30, 2006 | 12:19 AM
  #329
martymcfly's Avatar
I read in the costco FAQ that it will reduce the rate of loosing air pressure as compared with air. But then it all goes out the door once I start putting regular air a few months later.
Old Oct 30, 2006 | 01:08 AM
  #330
quangalang's Avatar
yeah the atoms are larger and they dont leak as much as regular air does, so your tire pressure stays constant
Old Oct 30, 2006 | 03:56 AM
  #331
vividjazz's Avatar
Someone that Posts too much
Running nitrogen. Holds the pressure for longer. Only have to check the pressure annually but once you fill with nitrogen you have to top up with nitrogen otherwise it defeats the purpose. Checkups and refills are free. Pressure also doesn't fluctuate as much between when the tyres are hot and cold.
They claim that it gives better milage but I've found it much of a muchness. I suppose if the pressure isn't going down then your not suffering from decreased milage from incorrect pressure between checks. Likewise the claims about better braking and steering are just that the pressure is correct I think.
Old Oct 30, 2006 | 10:34 AM
  #332
MINI-Fit's Avatar
Nitrogen is used at Costco for all their tires-
I can get tires rotated and air added every 5000 miles at costco.
Does it make that much difference for me? Not really. Nothing that I can tell.
It's not that widely available in my area yet.
Old Oct 30, 2006 | 10:46 AM
  #333
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
so is it true that nitrogen is lighter than air? so in theory the wheel aired with regular air would be heavier than a nitrogen filled tire?
Old Oct 30, 2006 | 01:33 PM
  #334
Fray Adjacent's Avatar
Senior Member
Nitrogen is used in tires SOLELY for reducing fluctuations in tire pressure due to temperature.
It's not used because it smells good, looks pretty, or makes the tire lighter (Sliver, the difference in weight would be negligible!)
Of course, you SHOULD check your tire pressure every couple weeks, regardless.
I've never checked on having my tires nitrogen filled, but given I have a tire gauge and a compressor at home, it's not a major inconvenience to me to check my tires and air them up myself.
Old Oct 30, 2006 | 07:27 PM
  #335
Spule 4's Avatar
Well, ever so slightly.....no Argon or Oxygen
Old Oct 31, 2006 | 11:44 AM
  #336
Crab's Avatar
Actually air consists of 78.05% Nitrogen, 20.95% Oxygen, and about 1% trace gases, mostly Argon.
Old Oct 31, 2006 | 11:55 AM
  #337
Stevens24's Avatar
It is in mine from day one. You also have less moisture build up inside the tire which can in crease life of the tire. We put it in all of our new 07s.
Old Nov 11, 2006 | 05:45 PM
  #338
MarkB's Avatar
Honda Fit Tires (SEMA)
Not sure if this is a repost but I thought it was kinda neat.
Old Nov 11, 2006 | 06:46 PM
  #339
firstshadow's Avatar
Senior Member
nice
Old Nov 11, 2006 | 06:56 PM
  #340
whiz's Avatar
i take it you are looking at joes pictures too mark haha
I have no idea how i missed this at SEMA
