What you DONT like about your Fit
Old Oct 6, 2014 | 08:24 AM
  #2501
Bama3Dr's Avatar
Originally Posted by Dave_in_Delaware
I don't keep my high beams on when other motorists are approaching. But I would like to be able to see ahead of me in total darkness in farm country better than my Fit allows (compared to my previous car). There are a lot of critters that run across the road around here, and I'd prefer to see them before they get in line with my tires.
If your Fit is a GE model (I'm not sure if this applies to the older GD models) and it's just a matter of them being adjusted too low there is an adjustment. There is a spot behind each of the headlights that you can stick a phillips head screwdriver into from the top and twist it to adjust the headlights up or down. I did this a little while back on my 2012 and it made a big difference in the low beams as they were adjusted way too low from the factory.
-Dustin
Old Oct 6, 2014 | 11:09 AM
  #2502
Wanderer.'s Avatar
Yep, changing to better bulbs and raising the beam was one of the easiest and most useful things I did with the car.
I just parked about 20 feet behind a average height car and raised the beams up until the cutoff was on the bumper. I lost a little illumination directly in front of the car, but who cares, you should be looking way down the road, not 5 feet in front of the car. High beams are like daylight in wooded areas lol
Old Oct 6, 2014 | 09:46 PM
  #2503
Dave_in_Delaware's Avatar
Originally Posted by 13fit
your highbeams are probably dull and worn out since the automatic daytime lights use the highbeam circuit at a lower voltage, causing excessive wear and tear.
I would hope they're not dull and worn out already. I've only had the car for 8700 total miles (brand new 2013, bought back in April). Do the bulbs wear out that quickly?
Old Oct 7, 2014 | 12:08 AM
  #2504
Wanderer.'s Avatar
No. The stock bulbs suck and the factory headlight aim sucks too. Change both and you'll be golden.
This was my personal experience, take from it what you will.
Old Oct 7, 2014 | 08:32 AM
  #2505
Fit Charlie's Avatar
Whoah, no need to bring personal experience into the middle of rumor and speculation. Calm down a bit.
Old Oct 7, 2014 | 10:14 AM
  #2506
Black3sr's Avatar
Bulbs do not wear out. That is they do not get dimmer over time. THey either work or they burn out all of a sudden.
I have cheap H4 bulbs from China. Much whiter and brighter at about $8 a pair. About two+ years n this set. I also put them in my van. Excellent bulbs.
Old Oct 7, 2014 | 10:16 AM
  #2507
Black3sr's Avatar
Bulbs do not wear out. That is they do not get dimmer over time. They either work or they burn out all of a sudden. Using the high beam at reduced volage for DRLs does not affect longivity that much.
Old Oct 7, 2014 | 10:43 AM
  #2508
Wanderer.'s Avatar
Sorry about that, thanks for pointing out the err of my ways
Old Oct 7, 2014 | 11:12 AM
  #2509
morgantruce's Avatar
Originally Posted by demouser
I have cheap H4 bulbs from China....... Excellent bulbs.
When recommending something, it's even better if you insert a link to it. Just copy the URL of the page and paste it.
I doubt if ALL cheap H4 bulbs from China are excellent----probably just the particular ones that you have experience with.
So, which ones?
Old Oct 9, 2014 | 10:05 AM
  #2510
wdb's Avatar
wdb
100% agree. I used to do a great deal of driving on lightly used roads after dark as part of my commute to/from work.
I did aim my headlights upwards somewhat, as has been suggested here; they definitely were aimed low from the factory. This adjustment does not cause you to blind oncoming drivers -- unless you go too far of course!
I also tried other bulbs in the headlights. In spite of manufacturers's claims they really didn't make enough difference to be worthwhile. The only real improvement comes from adding watts, and there are no higher wattage bulbs that fit the stock headlights.
I wound up mounting a pair of H9 high beams in the lower grille and wiring them to come on with the high beams. Mounting them that low was not ideal but it looked good and was relatively easy to do.
Old Oct 9, 2014 | 01:35 PM
  #2511
Wanderer.'s Avatar
It's not always about the wattage, beam pattern is important. Nightbreakers have a much tighter pattern than standard bulbs for example and a pretty long range, but are dimmer to the sides than the other bulbs I've used. Having used 3 different types of bulbs other than stock I can verify the differences.
If you are looking for higher wattage, you can use the H4 Nokyas with the harnesses to get you 90W. I will be trying these next, shortly... I just had to get ExtremeVision out of desperation since one of my bulbs went out at an bad moment but i'm not going to wait for them to fail to replace them.
Old Oct 10, 2014 | 06:09 PM
  #2512
EddyTrickz's Avatar
It's too loud for me.
Old Oct 10, 2014 | 07:59 PM
  #2513
13fit's Avatar
engine-wise or exhaust-wise?
if engine, get a valve adjustment. Makes a significant noise reduction IF your car needed it.
exhaust-wise, this car is too quiet. It needed a good muffler to make it sound good and bump up the volume a tad bit
Old Oct 10, 2014 | 08:21 PM
  #2514
It needed a good muffler to make it sound good and bump up the volume a tad bit...
...so you can hear what your car is doing---over the increasingly loud siren on the car that's quickly closing in behind you. Hmmm... his red, blue, and white lights are flashing VERY brightly. I wonder if they're Nightbreakers? I'll have to ask him here in a moment.
Old Oct 12, 2014 | 01:56 AM
  #2515
Linds's Avatar
I've got to agree with the fact that the front hangs low enough to scrape on things at stock height, and also blind spots are pretty terrible. I find it absolutely RIDICULOUS that even the base model doesn't have even the cheap folding armrests as well. >:[
Old Oct 20, 2014 | 10:51 AM
  #2516
chickentickler's Avatar
What I don't like about the Fit
Originally Posted by Wave
The dead pedal issue is easily fixed by going to zetaproducts.net
My only gripe? Every damn kid in a Honda civic with a fart can mistakes me for a Civic SI at night and wants to race!
Wow! I've noticed that! Sometimes I smoke them and they get PO'd because a 46 year old mom beat their a**. Most times I wish I had a turbo installed.
Old Oct 23, 2014 | 12:11 PM
  #2517
joncee11's Avatar
Door windows drip inside
The door window design directs rain water into the car and directly onto the arm rest window and lock switches. I'm in the southwest where it really helps to leave a window or two "cracked" to let out some of the heat. Any leads on reasonably priced external window visors ?
Old Oct 23, 2014 | 12:46 PM
  #2518
DaveFL's Avatar
I like to do the same, problem here is rain can happen even when not in forecast. First time I opened the back windows about an inch didn't notice the gap it produces on the the side, if the sheild was designed to cover the side back edge it would be an air scoop
Old Oct 23, 2014 | 01:08 PM
  #2519
2fit2kwit's Avatar
I love my WeatherTech window visors. A little pricy, but it's worth it compared to the cheap ones. Weathertech visors go inside the window channel so they're more secure.
Old Oct 23, 2014 | 02:54 PM
  #2520
2poler's Avatar
After having my GD3 for a little over a year here is what still irks me.
1. Doors not locking/unlocking with ignition (this is a pretty basic function that will be fixed when I get an alarm)
2. I have to find the exact location of the roof leak. It is driving me nuts!
3. The fuel gauge is nowhere near accurate.
