ef civic hb our new Honda @117k
Old Jun 14, 2012 | 10:17 PM
  #221
Perrenoud Fit's Avatar
Hey Glenn I changed the oil & filter this past weekend and put Castrol 20-50 in "ol smokey" and so far so good??! I will def use an engine cleaner if I don't just buy another drivetrain for it (JDMB16 Type R 185hp). She has her querks but i like her as much as the Fit for cruise'n.
Old Jun 14, 2012 | 10:31 PM
  #222
SilverBullet's Avatar
I didn't know it burned oil, I might of missed that. 20w50 will definitely slow that problem and the extra zinc will keep it from getting worse. Dont need engine cleaner unless your planing on rebuilding the head and pistons. That other motor would make that car into a track car and it would be in the low 13s with a different trans and axles. Then you be cruising down the track.
Too much zinc will cause galling so no more is needed with that oil.
Old Jun 14, 2012 | 10:50 PM
  #223
interior b4/after
Old Jun 14, 2012 | 10:55 PM
  #224
NICE... Like the tach location. Its easy to see with out taking your eyes off the road completely. That is where I have my Ultra gauge mounted.
Old Jun 15, 2012 | 08:26 PM
  #225
hey the smoke is just once in awhile a puff comes out when i down shift on an off ramp. it's not like a mosquito fogger lol.
Old Jun 15, 2012 | 08:55 PM
  #226
The thicker oil should help that. Did you do a vacuum test to see if its the valves? If that is OK then a compression or leak down test. I know you know but if your putting the B16 in then dont bother.
I miss that motor and the car it was in. I should of bought it.
Old Jun 21, 2012 | 07:27 PM
  #227
got the Skunk2 adjustable camber kit today will try to install soon to improve the controll in the twisties even more!
Old Jun 24, 2012 | 07:39 PM
  #228
low down-n-cold
Installed SSunk2 pro's and sway bar but the best thing was getting the A/C working again!!
Woot-Woot! R-12 is still the Coldest. Between the Fit (134a) and the Hatch (12), the Hatch is the coolest!
Old Jun 24, 2012 | 08:28 PM
  #229
R-12 was the best. It lasted longer too. My son has a MPI for that car if your interested.
Old Jun 25, 2012 | 05:51 PM
  #230
Smile Getting a little closer
Went to my Tuner shop in town and had Keyan and Vinny check out the 4 corners and the camber is .-56 degrees but the toe was 2" off!
1st time I could unleash the Beast WOT in the twisties hahahahahah
The difference is way better now than @ any time b4 w/ the suspension and steering.
The A/C was so cold this morning on the way to work it hurt, and that's good?
It's getting closer to where it needs to be. I'm think'n Barrett/Jackson what do yous guys think?..JK
Old Jun 25, 2012 | 07:48 PM
  #231
Thumbs up Camber and toe all 4 corners
Old Jun 25, 2012 | 07:52 PM
  #232
Thumbs up 10/11 to 6/12
Old Jun 25, 2012 | 09:11 PM
  #233
Subie's Avatar
Definitely Barrett Jackson classics auction or "What's my car worth?" Gull wings on the horizon? Tint job would look good. Good job man!
Old Jun 29, 2012 | 09:14 PM
  #234
Lightbulb Dry Ice on the fits dents
Yep the perivious owner must musta had a bad day and took it out on the roof! I went down to Harris Teeters (a grocery store chain here) and got a 6# block of dry ice. It sure helped but by far did not completly remove the dents. the biggest dent reflection was about the size of a basketball. The ice trick and about 20 minutes of working the ice shrunk it down to a baseball size dip, not nearly as bad but still noticable 2me. So the dryice helps, but bodyshop are not going to dissapear from the face of the earth.
It's kind cool with all the smoke coming off the DI kinda makes ya feel like the Mad Scientist
Old Jun 29, 2012 | 09:26 PM
  #235
It was 102 degrees in my shop this afternoon! But the results where worth it, lol.
Old Jun 29, 2012 | 09:53 PM
  #236
ya Soob I'm like'n a bronzish/brown metal tint all the way around
and some gullwing doors haha. does the hatch count?
Old Jun 29, 2012 | 10:16 PM
  #237
Subie's Avatar
Perfect self-portrait (jpg) there Big Mike! Sure man, the hatch counts... NOW to go with the mad scientist would be flames on the sides and smoke stack exhausts ala monster mag of the old days!
Old Jun 30, 2012 | 08:33 PM
  #238
Looking good Mike. My son has a Multi port fuel injection for that motor for free if your interested. Next time he is over I will have him take pictures of it to show you. You have to pay shipping. It was left overs of a engine he used for parts for the B16.
You might want to do a compression test but I think replacing the valve seals would fix the oil burning problem.
Old Jun 30, 2012 | 08:54 PM
  #239
Talking From 10-11 to 6-12
Old Jun 30, 2012 | 09:03 PM
  #240
Thanks Glenn I would like that.
