ef civic hb our new Honda @117k
Old Jan 31, 2012 | 11:01 PM
  #121
Perrenoud Fit's Avatar
Thumbs up Just a little list to myself
Replaced:
head gasket,timing belt, water-pump, headlights w/5000k bulbs, carpet, struts w/tein springs, front suspension, plugs, wires, cap, rotor button,
3 angle valve job, oil/filter, flush radiator and block, antifreeze, M/T oil, cat-back S.S. exhaust, window cranks, fuel filter, front brake pads and rotors, 175/70/13 tires, battery, seats, main engine relay,rear hatch strut openers, 16 lug nuts, OEM pedal set, front brakes & rotors, 4 shocks and Tein springs, A arms, lower ball joints, tie-rod ends,60 amp. NP alternator, PS inter fender and splash gaurd, carpet, brakes rear rebuilt w/ wheel cylinders and hardware kit, Skunk2 camber pro ser.,
Repaired:
door panels, tail lights, stereo, bumpers and side molding w/red stripe, driver's air vent, starter, buffed out paint, front door speakers, 5 spoke rims, seized lug nut & stud, D.S. front fender/door gap, glove box door, door light switches, seam sealer under hood where fire wall, inter fender meet,
Added:
P.S mirror, OEM rear light @ hatch, Si gauge cluster w/tach, Si badging, rear bumper applique
OEM foot rest aka dead pedal, center console, OEM clock, P.S. inter fender cover (missing?), cargo cover, 24 LED light under hood w/switch, digital volt meter, front mask, LED dome light, tow hook, JDM window vent deflectors, '91 Acura armrest, CRX front lip,
Old Jan 31, 2012 | 11:08 PM
  #122
SilverBullet's Avatar
You got a almost new car. Good Job Mike. Hope you can post mpg when you gather the info when you find time? I am thinking it will get around 35 mpg, that seems like the old Honda's norm.
Old Jan 31, 2012 | 11:13 PM
  #123
Subie's Avatar
Next
My '80 RX7 next Big Mike?
Old Feb 1, 2012 | 06:34 AM
  #124
It takes awhile to need a fillup, second tank was 36.4 mpg
Old Feb 1, 2012 | 06:36 AM
  #125
Bring it on!
just time & $
Old Feb 1, 2012 | 09:48 PM
  #126
WOW, That is better than I thought and its still winter. 40 plus is in your future. I guess Honda should go back to the old technology.
Old Feb 1, 2012 | 11:02 PM
  #127
a easy way to get around the suspension mess in the 88 is to just get some 89+ civic or crx rear Lower control arms. I miss my EF. Also if your going to be swapping seats the 88-89 are different than the 90-91. If you can get a hold of some 88-89 SiR seats they are WAAAAAAAAAAAAAAAAAAAAY better than the Si seats. The Si seats are made from horrible material. The SiR seats are tweed.
Thanks Chris
good info, she's coming along well here's a pic in our garage
Old Feb 2, 2012 | 07:40 PM
  #128
Cool
Have the sub box almost done & it's getting a 12" Clarion SRW 1285 4 ohm dual voice coil sub, man that's a mouth full, haha. The box is 3/4" w/1"x"1 corner stiffners glued & screwed, finished plywood stained in red oak w/ 6 coats on semi gloss clear, it looks like a piece of furniture, w/ a Rockford Fosgate amp. Hence the cargo cover
Reset the valve lash & re-torqued the head, quieter.
Replaced the main relay for the engine. Def. starts quicker it started to act up today so after 24+ years it had done it's job, I read where when this relay acts up it won't let the coil fire and the check engine light will not go out. Funday
Old Feb 3, 2012 | 11:36 PM
  #129
Reinstalled the rest of the clips and timing belt cover under the hood. There is a big problem with No storage or Any cup holders! wow what a difference between the FiT and the H.B.
Cut & installed a rear bumper applique.Turned out nice
Do not use Napa bumper paint this stuff is junk .
Old Feb 4, 2012 | 01:47 AM
  #130
Subie's Avatar
Hey Big Mike, just wondering if you've consulted with the "primary (intended) driver" with all the work and stuff you're slapping on... Or did that change also... Looking good!
Old Feb 4, 2012 | 03:02 AM
  #131
Virrdog's Avatar
Excellent work so far!
Old Feb 4, 2012 | 11:38 PM
  #132
Psst Soob my Rach is scared to drive any car, shhhh (look'n side to side) don't tell anybody (wink wink).
But being the good daddy that I am.... well I'm revisiting my teenage years and have'n Big Fun HaHa rebuilding this HotWheels car
Thanks! you know how we (us guys) get a building bug and just keep on building on 'em.
Old Feb 4, 2012 | 11:45 PM
  #133
Thanks Virrdog
Old Feb 4, 2012 | 11:56 PM
  #134
Well today was work on Courtney's Neon all day to pay for the Hatchback Attack! A detail inside and out under the hood too! replaced belts, needs brakes> for another day . So the HB stayed out in the rain all evening and after bringing her back into the shop I checked and all the spots where it leaked b4 where dry! yeah. Last coat of semi-gloss on the sub box and finish that up tomorrow. A good place to test it will be in the MzFiT, see which sounds better the Rockford Punch or the Clarion Pro Series?
Old Feb 5, 2012 | 08:59 PM
  #135
Our first meeting.....
Old Feb 5, 2012 | 09:24 PM
  #136
Btrthnezr3's Avatar
I'll be ready to take that off your hands soon. Lol your daughter doesn't want it too bad, eh? I keed, I keed
Old Feb 6, 2012 | 08:45 PM
  #137
Mike, That car has come a long way and I am jealous. I need to start a project but finding a good donor car is hard around here for that money. Its a piece of art and you did a great job..
Old Feb 7, 2012 | 01:42 AM
  #138
Subie's Avatar
(Dark glasses, black brim and black trench coat in a dark alley) Pssst... your secret's safe with me...
Old Feb 7, 2012 | 05:15 AM
  #139
Wait.
Subie you have a 1980 rx7!?!?!?!?!??!?!?!?!!
Old Feb 7, 2012 | 06:50 AM
  #140
555sexydrive's Avatar
My first Honda back in '93 down on Okinawa was an '87 EF3 Si with the ZC DOHC motor. Had some HKS cams, 5Zigen Border exhaust, Tanabe exmani and some other things done to the sussy. What motor is that, crazy to see it badged as an Si being SOHC for me. I was spoiled by being in Japan. Even the EA had the brown top DOHC carb'd ZC over here.
Mike, nice little project for yourself, ummm I mean daughter you've got going on there. Just brings back good memories for me, so thank you.
