ef civic hb our new Honda @117k
Old Jan 13, 2012 | 09:25 PM
  #101
SilverBullet's Avatar
She now wearing a state inspection, have never work so hard on getting one of those on a car! Pulled the radio & behind where the wiring clips in is a 10a fuse and it was bad now I have Mozart! Have another amp & 12 wuoolffer to add in there some day? Rinsed out the cleaner in the rad.( It did a great job, had it in there for 6 hours) and added the anti-freeze. changed oil and filter the other day, I added Sea Foam and the oil was still good but ddirty! The new exhaust sounds fart cannish but that fits the car, Big Al's came through @ $95.00 which for today's dollar value was good, 205.00 installed s.s. cat back.Cut the 2 bolt OEM flange @ the cat. and added a 3 bolt flange. Clean the shop and set up for uphostery! driver's door panel and seat pan change over. It's a fun project and I know why, prayer! He has really been there though out this whole project.
Subbie and Glenn thanks for your support also have a great day!
Big Mike
Glad it fixed and running. Keep us updated on the mpg. More pics too would be nice...
Old Jan 13, 2012 | 11:17 PM
  #102
Perrenoud Fit's Avatar
Order up!
coming soon, working the interior tomorrow Dr's seat and door panel. The pix here are too limited @ only 100 total, shoot I've taken down and re-posted 500! . I'll do a video and post on utube.
Then nxt add the 4 Tein lowering springs and front struts.
Old Jan 14, 2012 | 10:31 PM
  #103
Thumbs up Driver's seat is comfy
10-20-11
1-14-12
Old Jan 14, 2012 | 10:32 PM
  #104
I like the pin strips with the red trim in the bumper. It makes the car....
Nice interior..
Old Jan 15, 2012 | 02:46 AM
  #105
Subie's Avatar
10-20-11
1-14-12
Miss those good 'ole straight up no-nonsense consoles... sometimes Back when they didn't talk back to you... But with your touch Big Mike, I know it won't be the same ever again... Lookin' good!
Old Jan 15, 2012 | 09:38 PM
  #106
We finished the driver's door panel today and it turned out nice. Used the cargo light from the Fit and it snapped right in the civic, wiring was already there. I got an Acura on/off cargo light for MzFiT way back when. Well back to work tomorrow!
Old Jan 19, 2012 | 09:12 PM
  #107
Painted the door, fender guards black and under coated the the lip that runs under the door from one wheel opening to the other. Detailing
Installed a new PCV this week and that eliminated the oil smoke.
Old Jan 19, 2012 | 09:21 PM
  #108
Left to do:
1.) Rotors and pads
2.) new shocks and tein springs
3.) Front suspension: ball joints, tie rods, sway bar links all this for 43.00 shipped - trip to the front end shop "All Aspects"
4.) Detail under car and by then it'll be May and she'll be ready for ECHS in Richmond.
Old Jan 21, 2012 | 01:22 AM
  #109
Smile Getnr'dun
Got the hood mask tonight and installed- no more dented hood! Added the 3/8" red stripe to the ext. moldings. Repaired the antenna where it had been wire nutted together???
Installed the windage trays under the radiator and engine.
5000K 9005, 9006 are ready to be installed into the new headlights, ran a ground to the radiator support, firewall and engine, made a difference in the headlights went from kinda yellowish to white .
Cleaned the Sony Explode 6.5" tri-axiles up and replaced missing hadeware. Plywood is cut for the sub and a brown cargo cover has been located.
Got the 2nd fillup tonight and she's getting 36.4mpg around town. That's 4mpg more than MzFiT !
Have a truck to clean up and maybe after that we will be able to install the Si gauge cluster.
Old Jan 21, 2012 | 10:56 PM
  #110
Headlights changed out
5000k bulbs
Old Jan 22, 2012 | 12:22 AM
  #111
Subie's Avatar
Lookin' pretty slick there Bubba!
Old Jan 22, 2012 | 12:25 AM
  #112
Your going to want to keep this car as your daily driver after all the work your putting into it. Looking Good....
Old Jan 22, 2012 | 07:15 PM
  #113
Thanks guys!
I'm using this thread as a glorified notebook to keep track of the work on the little bugger and what's going on in the background to pay for this adventure in car resurrections. I finished the p/u truck today and used Zymol cleaner/wax and was really happy with what it did on the p/u truck that I went over the civic with it. the pic @ the bottom of the page is a zymol advertizment, impresive just the same.
Dri Fit and painted the p.s. mirror today.Install tomorrow night?
Old Jan 24, 2012 | 09:58 PM
  #114
Talking Installed PS mirror, and let the hondas out to play
Old Jan 24, 2012 | 10:20 PM
  #115
Looks good and I will have to try that wax too. But it probably will attract the birds for target practice.
Old Jan 29, 2012 | 10:21 PM
  #116
Lightbulb Voltage and LEDs
Well had the first no-start w/ the civic Friday after work. it turned out to be just the wire from the relay to the solenoid came off. Easy fix crazy to trouble shoot. haha. So had fun w/ it as far as mods it now has a under the hood 24 LED light that does a nice job. and a Rising Sun gas door.... installed a digital voltmeter under dash. Built up 2 of the 4 struts up KYB G2 w/ tein springs. Have a front suspension kit coming in this week ball joints, tie rods, upper cont. arms and sway bar bushings. Then a trip to All Aspects for a four wheel alignment. n' Kidz Kollege has a few jobs to do to pay for all of this. GIG ATT!
Because the Battery is soo tiny and the car is an antique car I like to know what's going on with the charging system.
Just the LED on in the pitch dark no flash here, lol...
Old Jan 29, 2012 | 10:25 PM
  #117
So there is a few bugs to get shaken out. So how does it drive and what is the mpg?
Old Jan 29, 2012 | 11:11 PM
  #118
Thumbs up 36.4 mpg and that's running it up hard to see if anything would break & it did :D
Hey Glen,
Honda uses spade clips instead of studs and nuts to attach the small solenoid wires and over time and 10K heat cycles they get loose. Drives Great and will be even more fun after the suspension is freshened up. The steering isn't bad but there is a lot of room for improvement there, and the shocks are ...well in a word mush. The 1.5" drop will improve the stance too! It is a fun car to commute in
Old Jan 30, 2012 | 09:30 PM
  #119
Hey Glen,
You're learning why Honda is so popular, easy to work on and a good product with great reliability. Now that car is a savings account and worth some good money.
Old Jan 31, 2012 | 09:10 PM
  #120
Wink b4 lowering
