K20 Fit How To Discussion
Old Jun 24, 2007 | 08:23 PM
  #101
quangalang's Avatar
so what you're saying is that you'll be using 2 ecu the fit ecu to run the everything and the rsx ecu to run the engine? ooohh that's going to be so messy. you'd better know your wiring schematics for both cars. but this way you can create a jumper harness for us.
Old Jun 25, 2007 | 09:26 AM
  #102
gettinafit's Avatar
Yes using two computers! And yes both Helms electrical troubleshooting OEM books are necessary!
Old Jun 27, 2007 | 10:41 PM
  #103
gettinafit's Avatar
THE Clutch Finally Arrived!!!
So the clutch is Finally HERE!! SO today after work I decided to put in my clutch and lightweight fywheel! I also got the two slim-line pusher type fans, but didn't get the cahnce to install them yet, probably wait until the end.
Here's today's update!
CLUTCH!!! Finally!!
New Slim fans! I have two because plan on running A/C!
Out with the old heavy flywheel, in with the new lightweight flywheel!!
Engine block flywheel-less
On goes the flywheel:
On goes the clutch!
On goes the Transmission back onto the engine!!
THat's all for today, STAY TUNED for more!
Old Jun 28, 2007 | 01:42 AM
  #104
SPON FIT's Avatar
sweetness.keep up the good work
Old Jun 28, 2007 | 09:33 AM
  #105
gettinafit's Avatar
Yeah this past weekend was a WASH when it comes to working on the FIT, The damn clutch was being hand made by the guys at Unorthodox Racing.... They ran out of rivets and had to order them and it was finally done monday!
Anywayz, this weekend I will put it back in and check the A/C lines and get them made, possibly put on custom length belt, and Fans. Maybe manifolds, we'll see if it is going to get in my way later.
Old Jun 30, 2007 | 02:13 PM
  #106
rei's Avatar
rei
So much work.. geez.. in the end I suppose it will all be worth it..
Old Jun 30, 2007 | 07:03 PM
  #107
jman245's Avatar
how much $ are you in so far?
Old Jul 5, 2007 | 09:40 AM
  #108
gettinafit's Avatar
**update**
Wiring is comming along. Sorry no pictures if you saw the mind working and the mess, you would not to take any second of brain power off of the harness and divert your attention to taking a picture! That plus it is hard to describe in a picture anyway.
Just know that the wiring is comming along, two harnesses are being mated together using Both helms troubleshooting books, one fo the Fit's and one of the RSX. lots of extra wiring and soldering and heat shrinking going on! Maybe this weekend I might touch the engine again and mount it. We'll see!
Old Jul 6, 2007 | 03:44 AM
  #109
quangalang's Avatar
Originally Posted by gettinafit
**update**
NOOOOO!! no documentation!?! I'm about to drive to Canada and kick your car!! anyways are you going to have some sensors sending signals to 2 ecus? if you do, are you worried about split signals?... ie. temp sensor, one ecu gets half of the voltage and the other getting the other half, so neither ecu's will have the correct voltage. am i making a valid point here or am i just bringing something up that is nonexistent? anyways good job!
Old Jul 6, 2007 | 09:03 AM
  #110
jtallen123's Avatar
Unless you got a resistor somewhere in the circuit a straight wire splice is not a problem. You only have to worry about current draw and the current output of the sensor, but usually you don't have to worry about that. You more have to worry about the type of output the sensor has a (varying voltage, digital, analog etc). But short answer is no, voltage doesn't just "split".
While I'm not an expert mechanic I am an electrical engineer who designs electrical systems for offroad machinary for a living, skid steers at the moment. (think those small bobcats)
Old Jul 6, 2007 | 09:43 AM
  #111
Wave's Avatar
Originally Posted by claymore
Be a wasted trip to canada .......he lives in NYC
which would result in a wasted trip to NYC......he lives on Long Island!
Old Jul 6, 2007 | 10:31 AM
  #112
gettinafit's Avatar
I like all of the speculation on my location but as FitFreak says on my location people should have at least guessed "New York!!" Certainly not Canada!
A computer hacker geek tunner friend of mine is ripping apart the ECU and soldering new connections and de-soldering connections, basically turning stuff on and turning stuff off that is not necessary for the Fit computer. RSX computer will be untouched.
As for more fine documentation on the wiring, the connectors are similar in "pin outs" justa couple need to be switched for the RSX Ecu, and you will need to run two sets of clips. There is a Connector labled "c101" in the chasis that sends stuff to the dash and the multiplex circuits, that has to be patched in from the RSX computer to the Fit computer then let the Fit computer talk on the "Can" bus. If I took pictures it will not help you, just get th two manuals, pictures look like wires and more wires and more wires.....hehehe
Old Jul 6, 2007 | 08:44 PM
  #113
SPON FIT's Avatar
sounds really complicated.you'll just have to do mine
Old Jul 6, 2007 | 10:07 PM
  #114
quangalang's Avatar
oh snap! i wish i had 3 hands so i can give myself 3 thumbs down. why did i even say Canada?...
Old Jul 6, 2007 | 10:08 PM
  #115
quangalang's Avatar
alrighty then i was just wondering because people have had problems like this running piggyback ecu's.
Old Jul 7, 2007 | 05:07 PM
  #116
03DSM-RSX's Avatar
Frequent FitFreak Poster
actually, it in fact DOES split. i have found that the MAP, ECT, and IAT sensors are affected by splicing the wire and splitting it to 2 ecus. I am currently finding ways to get a clean, fresh signal straight from the sensor instead of splicing it. I will certainly let you know when i find out.
I am running a dual ecu setup and currently working on a new R&D project for Hondata. I assume you already have Hondata Kpro on the RSX ecu? Once you have the electrical things able to turn on, you can check the KManager software and see what sensors are needed.
so at this point, your FIt ecu is controlling: multiplex, a/c...and what else?
RSX Kpro ecu should be controlling everything else, including OBD2. Although you can leave the "K-Line" from the Fit ecu tapped with the RSX's K-line to be able to diagnose both ecus. but when u go in for inspection sometime in the future, cut the K-Line from the Fit ecu. (K-line is the OBD2 comm line)
Old Jul 7, 2007 | 09:05 PM
  #117
jtallen123's Avatar
I don't doubt there will be issues getting to work, I only meant a voltage "split" is a bad way to describe the problem. Sometimes things are only designed to communicate to one device and yeah it can make things interesting. I've got no direct car experience so I'm not gona hazzard a guess as to why without seeing any sensor specs and signal details. I definately wish you the best of luck though and let us know when you figure it out.
Old Jul 7, 2007 | 10:45 PM
  #118
03DSM-RSX's Avatar
i can provide pics of me testing it and showing you the before/after "splitting" the signal and its signal values. I can get them up monday when i start testing various methods. (if it doesnt rain) And yes, there ARE resistors that stem directly to the IAT/ECT sensors.
For safest measure, you dont need to give the Fit ecu the ECT reading. If the signals are not accurate, your ECT will be reading a lot lower than it is actually, and the engine will constantly be working itself to get to warmed up temp of ~180. Resulting an overheating condition that you wont know about. (this is wat i DONT want to see happen) You can simulate ECT/IAT values with the use of different resistor values for the Fit ecu to make it think its "ready".
Again, this information was stated in my reports from the last project i worked on and is confirmed by Hondata. Although Hondata is experimenting by removing those certain resistors and/or changing resistor values on the ECU itself to amplify the signal enough to provide accurate readings between 2 ecus.
Old Jul 7, 2007 | 11:07 PM
  #119
03DSM-RSX's Avatar
ECT and IAT sensor voltage values: 0.5-0.8V
MAP: 0.7-1.3V
-Acura service manual, pgs. 11-13 to 11-14.
Old Jul 8, 2007 | 01:45 AM
  #120
quangalang's Avatar
yeah i guess im not such an idiot after all
