Scan gauge schooling
Old May 9, 2008 | 08:03 AM
  #121
Hondasforlife's Avatar
Hey Great News I Started Using My Paddle Shifters And Shifted Before 3000rpm And Guess What....dun Dun Dun 32.9mpg...i Have Found And I Can Still Drive A Litt Aggressive :d.....wooohoo!!!! Go Scanguage
Old May 10, 2008 | 12:37 AM
  #122
RichXKU's Avatar
Originally Posted by pcs0snq
I also have some preliminary data that suggested that a steady 30mph in 5th is close to 60mpg.
That would be great. I should just lock the cruise at 30, screw everyone on 422 and the turnpike.
Old May 10, 2008 | 02:33 AM
  #123
MINI-Fit's Avatar
Scan Gauge II allows adjustments for small things.
Set gas type, gas tank size, engine size, adjust up or down for speed accuracy vs speedometer.
It's nice to be able to move the SG from car to car.
You can find one easily on Amazon.com, mine came in 4-5 days.
Old May 10, 2008 | 03:58 AM
  #124
suketoborudo00's Avatar
joining the class
just bought and received my scangauge from Amazon.com yesterday and the insta-mpg is so cool!! I still have to configure xgauge. And the connection
didn't realize how bad the mpg is when accelerating, from stop to about 30mph, mpg is from 5-17mpg!! accelerating mpg with a feather foot (literally) gives about 10-18 mpg.
i've noticed if I lightly pump the gas instead of constantly pressing the gas, the mpg fluctuates from 25-35mpg when my foot is pressing to 40+ when my foot is not pressing the pedal. And when my foot is constantly pressing the gas (normal mode), i would achieve 28-36mpg. I suppose this is one of those factors that might get me past my previous best; 36mpg.
also, (i think someone posted this note already) I noticed when at a stop light, the gallons per hour is around 0.30gph when in drive (automatic car), and around 0.25gph when in neutral. Is it okay to put it in neutral like this? I read in another thread about coasting in neutral might/is bad for an automatic car. Anyone wanna clarify this for me?
Old May 10, 2008 | 01:14 PM
  #125
pcs0snq's Avatar
No issue at all. Keep your foot on the brake and don't forget to pull it back in drive before starting back up.
Old May 11, 2008 | 01:21 AM
  #126
ricohman's Avatar
I need one of these. I would also like to try it in my V10 F250.
What model do I need?
The scangauge II? Are there different models?
Old May 11, 2008 | 01:33 AM
  #127
MINI-Fit's Avatar
Only one SG II. Fits in the OBDII port then you adjust for your vehicle.
see
Amazon.com: ScanGauge II 3-in-1 Compact Multifunction Vehicle Computer with Customizable Display: Automotive
Old May 11, 2008 | 01:45 AM
  #128
ricohman's Avatar
Thanks for the info.
This would be a great tool for the guys who think their intakes are adding 10mpg.
You could simply test with and without it.
I want it because......I'm a techy nerd.
And I want to know exactly how much gas I'm using!
Old May 11, 2008 | 01:53 AM
  #129
solbrothers's Avatar
i have turned my stock gauges to the dimmest setting. i ONLY use the scangauge. LOL. i have my 4 gauges set to; RPM, MPH, MPG, IAT(intake air temp)
Old May 11, 2008 | 03:16 AM
  #130
MINI-Fit's Avatar
You can try different things.
Here's one.
You are idling not in gear. You are using 0.30 Gallons per hour.
Turn the AC on and now it's 0.40 Gallons per hour. I have AT not MT
Does that mean there will be lower mpg if the AC is on?
My answer would be yes when the car is sitting in heavy traffic and not going anywhere fast.
Some studies (and Mythbusters) have shown that windows up and AC on isn't so bad on the mpg when the car is moving along.
Old May 11, 2008 | 07:12 AM
  #131
pcs0snq's Avatar
Not true on a Fit and I'd bet any other 100hp subcompact.
MPG takes a huge hit when you run the AC and it's not even notable with windows down at speeds 65 and under.
That's from my own SG data and testing........not generic testing.
Old May 11, 2008 | 10:04 AM
  #132
davela72's Avatar
Here's one I've been thinking about lately. I always notice that the actual mileage for the tank reads less on the SG than the actual odometer. I'm presuming there's a way to compensate for this in the SG?
Old May 11, 2008 | 01:34 PM
  #133
Fray Adjacent's Avatar
Senior Member
I finally got around to ordering a ScanGauge today. Several fuel economy related discussions on another forum brought me looking over here.
Hopefully I'll have it by the end of the week, and hopefully it will come in handy, seeing as I now commute 1000 miles a month (if I don't do any days from home).
Still no pictures on how you guys mounted it? Did you all just place it under the gauge cluster? What kind of mounting apparatus does it come with? I guess I'll find out soon!
BTW, my Fit is an Auto Sport. I frequently paddle down to 4th when coming up on a light, and will occasionally shift it to N when stopped at a light. I'll report on whether or not I see fuel cut when decelerating, and what consumption does in D and N, as well as what I see with AC on/off. It's starting to get HOT here, so I'll be using AC a lot, however, I do work until 10pm now, so if it's cooler at night, I'll be able to drive home without the AC on.
Old May 11, 2008 | 07:48 PM
  #134
davela72's Avatar
Fray, it comes with velcro for the mounting. I mounted mine on the steering column so I could look directly at it while driving.
Old May 11, 2008 | 09:35 PM
  #135
Senior Member
Ahh... That's probably the best place for it. Easy to see. I hope I'll have it by Wednesday. We'll see!
Old May 11, 2008 | 10:11 PM
  #136
pcs0snq's Avatar
Rich Would you mind telling me how you did the new change or is that automatic after you have 6 months of fills?
Old May 12, 2008 | 09:10 PM
  #137
RichXKU's Avatar
just put 'his' in front of the filename
Old May 13, 2008 | 10:53 AM
  #138
Senior Member
Crap. Amazon emailed... my unit won't be here until after the 20th. Fock.
Oh well, I can wait.
Old May 13, 2008 | 06:37 PM
  #139
pcs0snq's Avatar
Thanks Rich,
Was thinking mine would look a little better... at least it's pretty consistent lol
+ rep for you
Old May 14, 2008 | 11:29 AM
  #140
Senior Member
Sweet... Amazon DID get my ScanGauge shipped! I'll have it tomorrow! w00t!
