TIRE questions,sizes, mounting,pressures ANY tire questions
Old Dec 1, 2008 | 08:05 PM
  #821
if the shoe FITs...'s Avatar
Originally Posted by Fittuner08
Im looking at some Ce28N replicas that are 15/6.5 with a 40mm offset. what would be the best tire size to get without rubbing.
205/55/15 id say thats the best
Old Dec 1, 2008 | 11:16 PM
  #822
Fittuner08's Avatar
tires
didn't you say thogh that you have that same size and that you are rubbing??
Old Dec 1, 2008 | 11:24 PM
  #823
whoops my bad...205/50/15...yeah...not 55. 50's is what im getting they should be fine my 55 only rubs when i take a VERY hard turn...but there is no uneven wear on my tires still...an not to mention remember mines a 2 inch drop so u should still be fine with 55 anyways unless urs is 2in also...
Old Dec 2, 2008 | 08:23 AM
  #824
jim@tirerack's Avatar
Former Vendor
The best size tire would be either a 195/55R15 or 205/50R15. If I can help with the tires let me know.
Old Jan 14, 2009 | 07:44 PM
  #825
FiT4Kim's Avatar
I have a 09 sport with stock suspension and was wanting to get new rims 16x7 +43offset, what tire size would be best?
Old Jan 14, 2009 | 07:47 PM
  #826
Former Vendor
You can run either a 185/55R16 or 205/50R16 no problem. If I can help with the tires let me know.
Old Jan 14, 2009 | 08:57 PM
  #827
FiT4Kim's Avatar
sent you an email
Old Feb 3, 2009 | 10:20 AM
  #828
Type 100's Avatar
Has anyone run "reinforced" tires? What pressures do you use?
I run Toyo Proxes 4s, 205/45ZR16 87W reinforced. As far as I can understand, the "reinforced" tires can take more weight (my old ones were load-/speed-rated 83V) but have to be inflated about 5 psi more than normal. So basing from the doorjamb reading 32 psi front/30 psi rear, and the +5 psi rule, I should be running 37 psi front/35 psi rear.
Anyone else on reinforced tires? Would like to see if we run similar pressures. Ride quality suffers a little due to the higher air pressure in my rubber.
Old Mar 10, 2009 | 12:32 AM
  #829
runbikerun's Avatar
I can't decide. My goals are better mileage and a quieter ride than my stock dunlop 16s. Any recomendations?
Old Mar 10, 2009 | 11:55 AM
  #830
Former Vendor
I am not sure that I can get you better ride quality. I can get you better handling and longer tread life. I would look at going with a 205/50R16 in the size. It is going to be a little wider and the same height.
If I can help let me know.
Old Mar 15, 2009 | 06:55 PM
  #831
qbmurderer13's Avatar
What tire can you recommend for me in 205/50R16? Looking for the perfect balance of price, performance and treadwear. Comfort isnt a deal breaker for me. Price will be though. Sorry I know its a pretty vague question.
Old Mar 16, 2009 | 01:48 AM
  #832
MINI-Fit's Avatar
Normally we look at 204/45-16 as the size for the FIT.
However 205/50-16 will be a little tall at 24.1" tire diameter but still work with the stock suspension. 50 series sidewall will allow for a little more comfort.
For good price, decent performance, and longer treadwear-
General Exclaim UHP $78 each, 380 treadwear
Fusion ZRi $82 each, 320 treadwear
Kumho Ecsta SPT $80 each, 320 treadwear
Yokohama S.Drive $91 each, 300 treadwear
Old Mar 16, 2009 | 02:05 AM
  #833
Well considering the stock tire diameter is 24.0" I think 24.1" will be better than the 23.3" diameter of the 205/45...
Old Mar 16, 2009 | 03:49 AM
  #834
MINI-Fit's Avatar
I think we have different year Fits-
I was referring to stock tire size on 2007-2008 Fit Sport
see
https://www.fitfreak.net/forums/fit-...-question.html
Post #9
Stock tire diameter 23.4". 195/55-15
For 2009 Fit Sport
16" wheels and 185/55-16 tires 24.2" tire diameter
Old Mar 16, 2009 | 03:55 AM
  #835
Yeah I have an 09, stock tire size is 185/55R16.
Old Mar 16, 2009 | 10:04 AM
  #836
Former Vendor
In the 205/50R16 if you are looking for longer tread life I would go with an all season tire. You will loose some performance to gain the tread life. I would take a look at the Goodyear GT at 89.00 each. If you stay with a longer wearing performance tire I would look at the General Exclaim UHP at 78.00 each.
Old Mar 16, 2009 | 11:08 AM
  #837
Those generals look like the winner, thanks!
Old Mar 16, 2009 | 12:24 PM
  #838
Former Vendor
If you order online just enter my name as a previous contact and I will get them on the way.
Thank you ,
Old Mar 16, 2009 | 12:40 PM
  #839
Thank you ,
Ill be ordering them in about 2 weeks but ill put your name down, thanks.
Old Mar 18, 2009 | 12:33 PM
  #840
runbikerun's Avatar
This is probably a really dumb question for all of you that know this stuff. Would there be an reason or advantage for me to go to a 15" wheel instead of my stock 16's? This is my daily commuter car. I will never hit a track. Is there a reason that one size 15, 16 or even 17 is better than another?
