GE8 Intake Questions & Answers Mega-Thread
Old Jun 10, 2010 | 07:55 PM
  #101
thefit09's Avatar
Would a scoop or inlet in the left side fender be beneficial for a SRI?
I've been thinking about this for a while. My idea is to buy a junk driver's side fender and either a) fashion a small scoop and cutout or b) make a cut out and inlet.
I would think the b option would be more beneficial because of drag and maybe less of a bend. The scoop could possibly help induct the air, though.
Would this be beneficial to those of us with a SRI that sits just behind the battery? (In my case the PRM intake) This in combination with a raked hood might be even more beneficial. I would think it might by bringing in cooler air directly to the intake, but I am by no means sure. Maybe those with a more advanced understanding could lend some advice.
Old Jun 16, 2010 | 06:41 AM
  #102
mike2100's Avatar
Probably not. Google "Bernoulli's Principle"
If the inlet is in an area with high lateral wind velocity you might actually start sucking air out of the engine bay.
If you use a scoop you might get the effect you're seeking but at what cost to your car's overall coefficient of drag? You would only get the benefit of increased cool air at higher speeds, which is where you'll also get the greatest negative impact to aerodynamics.
In my opinion, you might even out the positive/negative effects if you completely seal the intake tract after the inlet, making a ramjet style system with nowhere for the incoming air to go but to the engine.
Of course all of this is theory and you'd have to do scientific testing to see if it works. Testing horsepower gains from engine modifications is hard enough as it is. Throw in potential negative consequences from changing aerodynamics and you've got quite a project on your hands. I'm not even sure how you could do such a thing except maybe with a dyno located inside a wind tunnel.
Old Jun 16, 2010 | 08:02 AM
  #103
crash001's Avatar
Wow + rep for u mr and my friend were talking about Bernoulli's Principle yesterday. Yay nerds
Old Jun 17, 2010 | 07:12 PM
  #104
Klasse Act's Avatar
It seems to me the factory ducting should work fine if you see where it dumps down, right
Old Jun 18, 2010 | 03:41 AM
  #105
thefit09's Avatar
I see what you're saying. I new *of* that principle, but I read up more on it. Pretty interesting stuff. Wish I took engineering in school so I really understood more.
I think an inlet funneled into the intake would be the best bet as you mentioned. The PRM NA probe has something like this if I remember correctly, and they claim that it is the fastest NA probe on the planet. It's also where I got this idea from. If there were to just be an inlet, and the intake tract were to be sealed off, would there be a problem pulling in air that is moving front to back along the skin of the car?
It should work *fine*, but I want to see if I can make it better.
Old Jun 18, 2010 | 06:21 AM
  #106
mike2100's Avatar
If you mean air that is moving in a direction such as it would were it passing over fenders, doors, or roof (for example) then yes. You would still have Bernoulli working against you.
You would want to install the duct in a surface that is as close to a 90 degree angle with the direction of travel as possible. ----> |
The arrow is the direction of travel of the air. The pipe is close to the ideal surface for mounting a ramjet type of intake.
Old Jun 18, 2010 | 06:53 AM
  #107
thefit09's Avatar
Excuse the child-like illustration, but this is what you mean right? Without something stopping the air (like a scoop), the air will just fly right by?
Would the intake (if properly sealed off) act like a vacuum disturbing the air enough to bring all that cold air goodness in, thus eliminating the need for a scoop?
Old Jun 18, 2010 | 05:57 PM
  #108
mike2100's Avatar
I'm not sure I understand what that drawing is :P
Can you use a picture of a Fit and paint an arrow pointing to the part you're talking about?
Old Jun 18, 2010 | 06:14 PM
  #109
apexanimal's Avatar
fwiw... here's some stuff i took a look at on the gd:
Pressure Testing - Long Post
Old Jul 2, 2010 | 05:42 AM
  #110
Goobers's Avatar
Um... I'm just gonna take a few stabs at this (since I know nothing about ramjetting a car, sri, etc.)
If you have the stock upper grille... drill extra holes into that honeycomb, especially on the driver's side. then, add a piece of really stiff plastic or metal to force the air to turn upwards into those openings in the grille cover (or glue a duct into it!). Better yet, widen those covers a bit too... at least to the size of the opening of the underhood duct.
The way I see it now, the air that goes into that duct is only "left over" air that turned 90 degrees after hitting the A/C condenser.
meh... just a guess.
Old Jul 2, 2010 | 09:04 AM
  #111
Selden's Avatar
While I have doubts that an external duct would make any difference, if you go this route, you want a NACA duct
Old Aug 4, 2010 | 11:53 AM
  #112
shane's Avatar
ok need a break down on CAI's
what are the choices out there? ive seen the k&n rpm and injen
wanting to see whats all out there and prices any helps would be awesome!
Old Aug 4, 2010 | 02:27 PM
  #113
fitted08's Avatar
i did a custom one from autozone, theres a DIY cost me all of $65, if i ran another 90' degree elbow it would pretty much be a cold air, noticed the difference right off the bat
Old Aug 4, 2010 | 02:35 PM
  #114
shane's Avatar
Well i ended up ordering the PRM....
Old Aug 4, 2010 | 02:52 PM
  #115
bmxman's Avatar
lol...so why even start the post if you already had your mind made up 2.5hrs later...lol
Old Aug 4, 2010 | 03:05 PM
  #116
shane's Avatar
forum was too slow for me
Old Aug 4, 2010 | 03:34 PM
  #117
bmxman's Avatar
oh 1 quick note Tekeda also makes an intake for the GE.
Old Aug 4, 2010 | 04:51 PM
  #118
Black3sr's Avatar
What difference other than being louder? Nice DIY by the way.
Old Aug 4, 2010 | 05:13 PM
  #119
JDMxGE8's Avatar
*Takeda.
Old Aug 4, 2010 | 05:33 PM
  #120
Selden's Avatar
If the goal is really to produce a CAI, why not just insulate the duct that runs from the front of the hood to the air box? Space blanket comes to mind.
I've always been concerned about hydro-locking with most of the CAI designs.
Hydro-lock = ruined engine in many cases.
