Received Letter Safety Recall Drive Shaft ('09)
Old Apr 13, 2021 | 03:29 PM
  #101
Odie's Avatar
I think the passenger side loses a bit over 6 ounces ( considering it's a 32 ounce bottle ) when removed and I'm not sure of amount it loses for driver side ( left ) . May want to check A.T.F. level on occasion and look for leaks . Here's the instructions , https://static.nhtsa.gov/odi/rcl/202...0V770-0754.pdf and RECALL , https://static.nhtsa.gov/odi/rcl/202...0V770-5597.pdf .
Old Apr 13, 2021 | 04:00 PM
  #102
Odie's Avatar
Here are the instructions to replace axle for the manual transmission , https://static.nhtsa.gov/odi/tsbs/20...29346-9999.pdf .
Old Apr 13, 2021 | 04:03 PM
  #103
Ultrawolf's Avatar
Thanks Odie and Angst. It didn't occur to me that the axle shafts would engage in beyond the seals but it makes sense. I park on a slope, but will check as soon as I drive to some level ground.
Old Apr 13, 2021 | 05:51 PM
  #104
Ultrawolf's Avatar
It just occurred to me, are there shiny new CV joints inside those shiny new rubber boots I got?
Old Apr 13, 2021 | 08:18 PM
  #105
Troymcclure's Avatar
you betcha.
Old Apr 15, 2021 | 08:10 AM
  #106
Ultrawolf's Avatar
Thanks again to those who brought up checking ATF level. I had actually checked it the day before the axle shaft replacement. I checked again yesterday and it was at exactly the same level, in the middle of the "good" zone on the stick. So it looks like the service tech probably knew how much would drain, and refilled that amount. My service order shows 1/5 bottle of ATF as one of the shop materials,
Interestingly, the reason I had checked the ATF before the service was because I had gone over the service items that the dealer might try to upsell me with (air filter, brakes, ATF flush, etc.). The only service the dealer suggested was that my wiper blades were starting to look a little worn.
Old Apr 15, 2021 | 09:04 AM
  #107
The other freebie with the recall is potentially an alignment as the last step in the procedure is to align the car.
Old Apr 15, 2021 | 09:22 AM
  #108
ANGST's Avatar
Yeah they covered my alignment on my reimbursement
Old Apr 15, 2021 | 12:29 PM
  #109
steve37's Avatar
Called the local dealer yesterday about the recall. They had my vin on file and said they had an opening at 9am today for the fix.
20 minutes after dropping it off..I get a text saying I can pick it up.
I figured that I would get there and they would tell me that mine didn't need replacing after inspecting them.
I get there and the lady service tech tells me that they need to re-schedule my car because they didn't have the correct parts in today.
I was kinda upset, and told her that was my reason for calling and asking if they were ready.
She answered...."We assumed your car was an auto/tranny...we don't hardly ever see a m/t in here for service"
GRRRR!
Old Apr 15, 2021 | 12:57 PM
  #110
Odie's Avatar
Ultrawolf , did you check the level when Cold ( engine not ran ) or Hot ( as desribed in owners manual ) ?
Old Apr 15, 2021 | 03:48 PM
  #111
Ultrawolf's Avatar
Originally Posted by Odie
Ultrawolf , is that 1/5th of the 32 ounce bottle ? Also , did you check the level when cold ( engine not ran ) or hot ( as stated in manual ) ?
1/5th of a 1 liter bottle, essentially 32 ounces. And I checked with the engine hot as specified, shut it off, waited 60 seconds, pulled the stick, wiped, reinserted and then checked level. The check occurred at about 75 seconds after shutoff - right in the middle of the 60 to 90 seconds specified in the manual.
Old Apr 17, 2021 | 01:37 PM
  #112
Odie's Avatar
Had both axles replaced . Seems fine . I think they overfilled the tranny and plan to check it .
Old Apr 17, 2021 | 11:43 PM
  #113
Odie's Avatar
Checked transmission fluid and looks fine. Plan to recheck . Also, the DW-1 came from a drum , so the part number indicates .
Old Apr 21, 2021 | 07:56 AM
  #114
Rick_a's Avatar
My 2010 MT with broken axle. If the shaft is rusted, it's going to break at some point. It's unacceptable. The joints will wear out, eventually. The shafts should never break.
Old Apr 21, 2021 | 01:06 PM
  #115
Odie's Avatar
Ouch ! Never should occur .
Old Apr 21, 2021 | 07:15 PM
  #116
SleepyNyte's Avatar
Anyone else told that you need to bring the car in twice, once to be inspected, then parts are ordered, then bring the car in for repair? Kind of upset that I need to take two days off for this. As my car was purchased in 2006 I think the chances of the driveshaft being rust free are near zero.
Old Apr 21, 2021 | 07:29 PM
  #117
steve37's Avatar
post #109
Old Apr 23, 2021 | 11:30 AM
  #118
Got mine done yesterday. Took 1.5 hours, they took air out of my tires. 34 psi is for chumps, give me my 40 back.
Old Apr 23, 2021 | 03:11 PM
  #119
Ultrawolf's Avatar
Several years ago the service writer at the dealer made a special point of telling me that they had filled my tires to the proper level. On checking, two were at 33 PSI and two were at 39 PSI. And opposite corners at that which I'm sure will really improve handling.
Old Apr 24, 2021 | 02:48 PM
  #120
Mister Coffee's Avatar
That's another reason I don't go to dealers. One time, I specifically told them not to touch my tires, and they did it anyway. I don't appreciate people doing whatever they please with my car.
