Old Sep 8, 2012 | 11:37 PM
  #6241
Goobers's Avatar
Originally Posted by jsumislaski30
No scratch just a fade line I guess it's what you call it
basically like tan lines?
Yeah, one of the reasons I no longer want to use a nose mask/bra on a car.
Old Sep 8, 2012 | 11:45 PM
  #6242
Subie's Avatar
Washed it took the bra off trying to get line off of hood need to get the buffer out! Any ideas?
Just some thoughts on bras/hood masks/protectors. Taking them off every now and then would be good, specially when they get wet. Keeping them on wet just does a job on your car surface.
Old Sep 8, 2012 | 11:54 PM
  #6243
if it's on the top clearcoat surface it will come off with polish. if it's clouding that etched into the clear, it might be a permanent mark..
this is why i dont use leather bra's. haven't used one since the 90's.
clearbra is the way to go. or if temporary, use painter's tape.
Old Sep 9, 2012 | 06:31 AM
  #6244
singhonwheels's Avatar
Smile
Originally Posted by swflej1
Yea front tires have some poke I think they stick out like 1/4" or more. I don't really know I'll check it out later, the rear tires about flush
any idea what offset in 15 inches would make the front wheels flushed in ?
i got 195 55 r15 on stock height and stock rims..
i measured ,and the tyre is only half an inch inside the front fender line.
no worries for the rear one... its got more than 1 inch space.
(P.S. - not planning to drop or pull my fenders )
Old Sep 9, 2012 | 04:10 PM
  #6245
JC Hillbilly's Avatar
Originally Posted by Rampo
Today I finally installed a mesh grill to protect the AC condenser on my 2010. Simple installation steps
1. Purchase gutter guard & about 2 dozen black 8" tywraps. Optional: vinyl door edge strips and a 6 pack.
2. Remove plastic cover from top of radiator well. Careful removing the push clips that fasten the cover. Pry up the center pin before pulling on the fastener.
3. Using tin snips, cut 6" off the end of the gutter guard, so you now have 30" long X 6" wide strip. Also remove and discard the two little metal clips that are attached to the gutter guard. They're not necessary. I had some black door edge channel left over from another vehicle, so I cut it into 4 strips to cover the edges of the gutter guard. Absolutely not necessary, but it does protect your hands from getting cut on the edges during installation.
4. Place guard in opening with concave side towards the engine. The material is pliable, so you can gently form it to fit any contours.
5. Use the black tywraps to secure the screen. There are plenty of vertical sections on the vehicle's grille where you can discreetly make your attachments. Be sure to start the tywraps from the inside of the well opening. Run the tywrap through from the inside, around the vertical support, and back through into the well opening. Tighten the wraps securely and be sure to snip off the ends so no one thinks you're a dork if they should happen to look down into the well and see all the ends sticking out.
6. Put everything back together, have your optional adult beverage, and voila!
Thanks Rampo
Today, I followed your DIY, bought the same material from Home Depot, and installed my A/C condenser protection on my 2012 Sport! I added some flat black spray paint to the mesh grill. All in all, it took me just over 3 hours, including 2 coats of paint and drying time. For me the most difficult part of this installation was removing the push clips from the plastic cover. Good practice though...will need to remove it again when I do a horn upgrade.
Pictures will follow in my photo album...
Old Sep 9, 2012 | 05:34 PM
  #6246
washed the GE's yesterday and pressured up the tires
today i pressured up the spare tire. wife's taking the 09 GE out for errands. no Fit action for me today. i will be taking it to work tomorrow as it's another round of landscape pansies.
Old Sep 9, 2012 | 06:46 PM
  #6247
jsumislaski30's Avatar
Old Sep 9, 2012 | 06:48 PM
  #6248
also buffed out that tan line lol
no longer have the bra on it
going to strip the interior and dynamate the whole thing to get rid of the road noise
Old Sep 9, 2012 | 07:16 PM
  #6249
NightScreams's Avatar
picked mine up yesterday. washed n waxed it today
Old Sep 9, 2012 | 07:42 PM
  #6250
SportGirl11's Avatar
Washed - and de-stickered. My last evening with her
Old Sep 9, 2012 | 07:45 PM
  #6251
prhkgh's Avatar
[QUOTE=JC Hillbilly;1130189]Thanks Rampo
[\QUOTE]
I made my lower grill a few weeks ago, out of some flexible black plastic fencing I found in Orchard Supply Hardware...and am pretty pleased with the outcome. It was within a day that I first saw posts about using gutter guard. But mine was pretty much just as good...certainly good enough...no reason to redo it, even though the gutter guard probably affords some more protection...probably.
Then yesterday I was in Home Depot and they have gutter guard on sale for $1 a section...in WHITE! Did I mention my '12 base Fit is a gleaming TW paint? Now I'm thinking it would be worth the expenditure of $1 and some of my existing extra white zip ties to have a lower grill paint matched to the bodywork. BUT...how long before I would find myself either painting or plastic coating the stock upper grill to also match the TW paintjob? Or even (persish the thought) making that out of another $1 of white gutter guard?
No, it would probably start to look like a Beverly Hills hillbilly car. Best to leave well enough alone. But I think I will buy a piece of white gutter guard on sale while I can, in case I change my mind about the whole thing.
Paul H
Old Sep 9, 2012 | 10:58 PM
  #6252
swflej1's Avatar
I order some goodridge brake lines.
I not sure, I would go check the wheels section.
Old Sep 10, 2012 | 01:03 AM
  #6253
MEATBABY's Avatar
You just have to research. As far as the "flush" you're talking about, wheel diameter doesn't have to be considered. Don't measure from the tire. You need to measure from the WHEEL to the fender, since the wheel is what will have the offset, not the tire. Use a wheel offset calculator like this one - Custom rims, wheel tire packages for your ride - RIMSnTIRES.com - and enter your current rim and tire dimensions and then mess around with the other one to find what you need. If the distance from the rim to the fender is 1/2" (12.7 mm) for example, then you would want a wheel with with a ~12 or 13 mm LOWER offset than your current wheel. From there you can experiment with tire sizes for the look you're going for. If you're not dropping the car then you have a wide range of tire sizes to choose from. As far as rolling the fenders, you may still want to do that even at stock height. If took a really hard turn or even a big pot hole, that fender lip could still rub the tire. That's what happens with a flush fitment.
Old Sep 10, 2012 | 12:10 PM
  #6254
swflej1's Avatar
Installed Mugen short shifter
Old Sep 10, 2012 | 12:37 PM
  #6255
xxryu139xx's Avatar
carbon fibered my ezpass and the spoiler screw covers to better match the CF JDP duckbill. the cf i bought was a a bigger weave/pattern, but at least its all black now. ill probably redo it when i get a better weave/pattern.
Old Sep 10, 2012 | 01:05 PM
  #6256
ThEvil0nE's Avatar
spot the change...
Old Sep 10, 2012 | 01:24 PM
  #6257
MEATBABY's Avatar
spot the change...
No wing?
10char
Old Sep 10, 2012 | 01:49 PM
  #6258
ThEvil0nE's Avatar
Originally Posted by MEATBABY
No wing?
10char
clean shavin
  #6259
ninja edit: oh no wing!
Old Sep 10, 2012 | 01:50 PM
  #6260
evil- where did you source that tail lamp?
