View Poll Results: Is this useful?
Yes
114
92.68%
No
0.81%
Maybe once there's more info.
6.50%
Voters: 123. You may not vote on this poll
2015 Honda Fit KA - K.I.S.S and Lazy Reference Guide
Old Oct 29, 2018 | 06:36 PM
  #41
evilchargerfan's Avatar
Intake Manifold Removal and Installation
Old Oct 29, 2018 | 06:39 PM
  #42
Ignition Coil and Spark Plug Removal and Installation
Old Oct 29, 2018 | 06:43 PM
  #43
High Pressure Fuel Pump Removal and Installation
Old Nov 14, 2018 | 03:39 PM
  #44
Speaker Removal, Installation, and Test
Old Nov 21, 2018 | 03:21 PM
  #45
Front Stabilizer Bar Removal and Installation
Old Nov 27, 2018 | 02:21 PM
  #46
TSB A16-088
SERVICE BULLETIN - AT COLD START UP, THE ENGINE RATTLES LOUDLY FOR ABOUT 2 SECONDS. THIS MAY BE INTERMITTENT AND OCCURS ON COLD STARTS WHERE THE ENGINE TYPICALLY HAS NOT BEEN STARTED FOR 6�8 HOURS. THE VARIABLE VALVE TIMING CONTROL (VTC) AC
https://testing-public.carmd.com/Tsb...118695/A16-088
File Type: pdf
Old Dec 4, 2018 | 02:58 PM
  #47
SilentStray's Avatar
Originally Posted by Bassguitarist1985
Hey Everyone, this is an amazing thread. Nice quick references. May I ask what is the main goal? Are we posting basic maintenance, specs, and procedures for the accessories like how to install the moon-roof visor, cargo cover, under-dash illumination kit, etc?
Alternatively, are we okay to post more advanced mods like upgrading the stereo system, adding heated seats to non equipped models, air suspension mods, towing equipment, LED light install, winker/heated mirror mod, and a slew of other things. Want to ask permission before dumping my repository of mod stuff for others to view while shamelessly showcasing what I have done. :-)
Super late replay (adjusting to new job) It started off as basic Stock maintenance, but I feel that's too basic for this forum so I'm going to expand this to add modifications and non-stock upgrades, along with the stock upgrades of course. I've already added a Drop-box link that has all the official guides I've been able to find for such upgrades.
Since you guys are so awesome at posting the stuff in this thread, I'll just be linking to post numbers in the main post.
Old Dec 4, 2018 | 03:01 PM
  #48
welcome back SilentStray, I've missed you dearly
Old Dec 4, 2018 | 03:05 PM
  #49
TSB A16-088
Dang! I've been wondering about this since I purchased! The dealer said It was normal.
Old Dec 4, 2018 | 03:08 PM
  #50
Feels good to be back, sorry for the unexcused absence, getting accustomed to hospital work/life was a bit more of a challenge than expected.
As for this thread, I'm going to have to download all these PDF files and organize the Dropbox into folders for all this info.
You've been keeping this up for me, I thank you for that.
Old Dec 4, 2018 | 04:21 PM
  #51
Old Dec 5, 2018 | 03:50 PM
  #52
Quoting ThadCastle on proper shift points:
Originally Posted by ThadCastle
For manual trans, the owners manual recommends shifting into 2nd @ 16mph, 3rd @ 26mph, 4th @ 35mph, 5th @ 41mph, and 6th @ 43mph. Pretty much no difference between 5th and 6th
Old Dec 6, 2018 | 01:19 PM
  #53
I think we're missing a how to, for parking brake adjustment?
"10-minute Parking Brake Adjustment Procedure"
https://www.fitfreak.net/forums/3rd-...-ex-cvt-2.html
Old Jan 16, 2019 | 01:49 PM
  #54
this is a MUST add ...
Splash shield screws and retainer clips
https://www.fitfreak.net/forums/3rd-...ner-clips.html
Old Jan 16, 2019 | 02:34 PM
  #55
Bassguitarist1985's Avatar
Sweet!!!! This is a great link!
Old Jan 25, 2019 | 09:29 AM
  #56
Added - Thanks
Old Jan 28, 2019 | 06:34 PM
  #57
https://www.hondapartsonline.net/blo...r-honda-remote
"How to Program Your Honda Remote in 9 Easy Steps"
If you’ve recently bought a keyless remote entry fob for your Honda or the battery died in your existing remote, programming it is quick and easy. There’s no need to take the remote to a dealership for programming, simply follow these 9 simple steps.
A Step by Step Guide for Programming Your Honda Remotes
Step 1: Gather all the remotes. You only need one remote to access program mode, but all remotes must be programmed during the same session. Your Honda will “forget” any remote previously programmed.
Step 2: Sit in the vehicle with all the doors closed and unlocked.
Step 3: Turn the key to the ON position, one click before starting the ignition. The lights on the accessories should come on and the dash will light up.
Step 4: Within 5 second of turning the key to the ON position, press the LOCK button on your remote control transmitter for one second.
Step 5: Turn the key to the OFF position.
Step 6: Repeat Steps 4 & 5 two more times for a total of three ON/OFF cycles. Each step must be done within 5 seconds of the previous step.
Step 7: Turn the key back to the ON position (this will be your fourth turn of the key), press the “LOCK” button on your remote. The locks on your Honda will make a clunk noise exactly as they do when locking. You doors have not locked. This noise indicates your Honda is now in Remote Programming Mode. Do not turn the key off.
Step 8: If you would like to program more than one remote, press the LOCK button on each additional remote for 1 second. As with all other steps, you have 5 seconds to complete this step. Programming Mode will be activate for a total of 10 seconds. Only 3 remotes can be programmed to each Honda.
Your locks will make the clunking noise (as though the doors have locked) after each remote is programmed to indicate they have been successfully stored in the system’s memory.
Step 9: Turn the key to the OFF position and remove it from the ignition. Test all of your remotes to ensure they have been successfully programmed.
Remember that your remote will not work if the key is in the ignition. If you’ve lost your keyless entry remote, it’s a good idea to reprogram your Honda remote to protect your vehicle from theft.
Old Feb 7, 2019 | 02:40 PM
  #58
Injector Removal and Installation
Old Feb 7, 2019 | 03:20 PM
  #59
Z062FIT's Avatar
Possibly the hardest injector install I have ever seen in my automotive life. WTH, Honda, WTH...
Old Mar 27, 2019 | 02:55 PM
  #60
Steering Wheel has been covered, but I'd like to add the manual for more detailed .... details
Steering Wheel Removal and Installation:
Steering Angle Sensor Removal and Installation:
