2RISMO2 - Commuter Life Chronicles
Old Apr 29, 2019 | 08:06 AM
  #201
2Rismo2's Avatar
I washed the Fit and Odyssey with a foam cannon I bought from Amazon:
MATCC Adjustable Foam Cannon MATCC Adjustable Foam Cannon
I just used whatever car soap I had and it seemed to work pretty well. I'm almost out of soap so I'll buy some of the dedicated foam soap to see how it does. This was my first time using it and it was pretty easy.
Old May 8, 2019 | 11:20 AM
  #202
2Rismo2's Avatar
Originally Posted by 2Rismo2
Got my PIAAs Xtreme White Plus replacements since my last set burned out before they made a year. I'm leaning on selling them and just going LED. Looks like some people have had good luck with this set: https://www.superbrightleds.com/more...ink/3929/8565/
Well I made the mistake of installing the PIAAs and one of them burnt out last week, so didn't make it a year again. I went ahead and ordered the LED bulbs above. I'm sure I'll have better luck...
Old May 12, 2019 | 11:18 AM
  #203
2Rismo2's Avatar
Installed the LED bulbs. I didn't have to rotate them for a good pattern but it wasn't super dark yet. They went in without much trouble. The rubber gasket was a little tight but nothing a little pressure couldn't fix. They are nice a white light.
Old May 12, 2019 | 11:26 AM
  #204
Action Jackson's Avatar
Hope those work out for you.
I remembered that you asked me about my vinyl trunk mat. I tried looking back in this thread. What did you end up getting?
Old May 12, 2019 | 04:40 PM
  #205
2Rismo2's Avatar
I bought the cheap Chinese knockoffs from eBay and they seem to work pretty well. I have a milk crate that I used to organize stuff so things aren't sliding around. It's bungeed down too.
Oh I still haven't got around to making that false trunk bottom to mount my subwoofer upside down on - lol
How is your sound damping project going?
Old May 12, 2019 | 07:24 PM
  #206
I have some MLV on order. I suppose that most would be happy with my current results. I have to tackle the road noise from the front wheels/fenders, floor and firewall.
Old May 13, 2019 | 07:42 AM
  #207
2Rismo2's Avatar
First day driving with the LEDs and they're definitely brighter/whiter than any halogens. Beam pattern looks decent and nobody flashed me so that's a good sign.
Old May 13, 2019 | 07:55 AM
  #208
bdcheung's Avatar
How's the high beam pattern? I got some faux-projector LEDs from Amazon and while the low-beam is awesome, the high-beam is very anemic.
Old May 13, 2019 | 09:43 AM
  #209
2Rismo2's Avatar
HB is decent, could only use in the neighborhood as too many cars on my daily commute. LB is way better than stock, so I may seldom need to use HB. With halogens, I would use HB every opportunity since LB was awful.
I really don't know why I waited so long to switch...
Old May 18, 2019 | 08:55 AM
  #210
2Rismo2's Avatar
My mpg has really improved as the weather warms.
Old May 18, 2019 | 09:04 AM
  #211
bdcheung's Avatar
That's solid. What does your commute look like?
Old May 18, 2019 | 09:42 AM
  #212
2Rismo2's Avatar
I've got a 45 mile commute to work and I make better time on the back roads since I'm coming from a rural area. Speeds don't exceed 65. I don't really hit traffic till I get about 5-10 miles from the city.
Another 45 miles on the way home and I take even more back roads to avoid having to make left turns at traffic lights.
Old May 20, 2019 | 07:25 AM
  #213
2Rismo2's Avatar
Current drive is drive from home to work. Previous drive was the drive from work to home on Friday.
Old Jun 14, 2019 | 11:43 AM
  #214
2Rismo2's Avatar
B1 maintenance reminder came on. I didn't have time to do it all, but just did the cabin air filter.
Installed this one for less than $5
cabin air filter cabin air filter
Old Jun 22, 2019 | 08:03 PM
  #215
2Rismo2's Avatar
I changed out the filter and oil at 78418 miles. Also cleaned the maf with crc maf cleaner. I was going to clean the k&n but the oil had spilled out.
While the splash guard was off, I replaced the panic horn on the passenger side behind the bumper. I still had the stock one when I changed out to the college hills Honda sport horns. Water must have got into it as there was still some trapped inside when I removed it. That area must not be as well protected as ActionJackson had the same issue.
Old Jun 22, 2019 | 08:55 PM
  #216
Yeah I don't understand why the low tone horn dies. The area just around it is very clean when I look.
Old Jun 24, 2019 | 09:34 AM
  #217
2Rismo2's Avatar
I do remember hitting some puddles on a flooded road, so that must have done it. Didn't really think about it at the time, but seeing how much water came out of the horns surprised me. I had them mounted with the opening facing downward as instructed. So the meep meep panic horn is back in place.
Just ordered the K&N filter recharge kit so I'll clean out my engine filter when that comes in. It's low priority as I'm still getting 44-46 MPG.
First drive after the oil change and MAF clean, the car does seem to perform better. MAF didn't look dirty/oily, but figured while I was waiting for the oil to drain I would do something.
Old Jun 26, 2019 | 07:57 PM
  #218
2Rismo2's Avatar
I cleaned out my k&n filter so while it's drying I put back the old paper filter. We'll see if I can tell any difference on the drive tomorrow.
Lots of bugs, probably from the Sumole air scoop
Old Jun 27, 2019 | 07:32 AM
  #219
2Rismo2's Avatar
On the the drive in this morning it did get about 1 mpg lower on the trip from home to work. Did feel like it was slightly less peppy than the dirty k&n. I'll do another run with the cleaned k&n.
Old Jun 27, 2019 | 09:45 AM
  #220
evilchargerfan's Avatar
my butt dyno feels the k&n is more peppy
