H-Fit Supa Sucka Intake Now Available!
Old Aug 21, 2007 | 01:57 AM
  #141
ezduzit's Avatar
Originally Posted by H-FIT-James
Hi All,
Been a little busy lately so sorry for not replying any sooner.
As for the air temperature readings and how we achieved the lower temperature than the stock intake,
We used 3 methods. I will not go too in depth because some of the research and data is proprietary.
Thank you for your detailed and helpful response James. I installed the HFP muffler today and I think your Supa Sucka intake will probably be my next mod.
Regards,
ed
Old Aug 21, 2007 | 10:33 AM
  #142
LastDance's Avatar
Originally Posted by LastDance
Will this fit JDMs?
Old Aug 21, 2007 | 01:48 PM
  #143
MadtownFit's Avatar
Hi All,
Anyways.
1. We cleared the shrouding that surrrounded the intake air temperature
sensor. This allows the sensor to react faster to temperature changes
and thus allows the ECU to recalibrate to changing conditions faster.
This really isn't a change that physically makes the air cooler, but it
has some connection.
2. We increased the overall air velocity / movement through the
chamber / intake. The stock intake has many chambers and baffles
built in to reduce noise. These allow for a physically larger internal
volume within the stock intake, but also reduces the movement of air
within. Also, internal to the stock intake there are many areas where
air can get "trapped" and end up swirling around in the intake allowing
the air charge more time to absorb heat from the surrounding
enviroment.
3. We employed thermodynamics and gas principals. We used the fact
that when gasses expand they cool (endothermic). We designed the
SSI so that when air flowed into the chamber it had an area which
promoted the expansion of the incoming charge prior to going into the
throttle body. This was a little difficult because we had to take into
account the airspeed within the intake so we would not absorb more
heat than the expansion would remove. If this happened it would be
no better than the stock intake in this regard.
Hope this info is helpful,
H-FIT Team
H-Fit.com....Products now available. Performance for track and street...
J Squared Advanced Development - Performance Automotive Engineering
Would adding some type of heat shield around the filter help reduce the air temp even further? Looking at the pics that were posted it looks there might be enough clearance for a heat shield. Just a thought.
Old Aug 21, 2007 | 01:59 PM
  #144
docjim2's Avatar
...my that is a tight Fit... Yup, I have ordered one and will let you know how I like it etc.
Old Aug 21, 2007 | 03:12 PM
  #145
H-FIT-James's Avatar
Hi All,
We are currently looking into the fitment for non USDM FIT /JAZZ for our SSI. We have been able to look over some engine bay pictures from interested individuals from Malaysia and Philippines and there does not appear to be any fitment issues we can see. But, we are not currently comfortable with saying "YES it will fit" until we complete further research.
A heat shield between the chamber and filter will promote a cooler intake charge.
We had a few shapes made of ABS and aluminum that sealed up against the hood as a barrier between the filter and chamber. But, as some of the local SoCal Fit owners have heard, we were planning on making a special type of heat shield that would incorporate an actual intake port to feed outside air to the filter of the SSI, so we decided to leave the basic heat shield out on the production units.
Thanks again!
H-FIT team
Old Aug 21, 2007 | 03:19 PM
  #146
Wave's Avatar
Thanks again!
H-FIT team
Oh really now? I'm interested in purchasing one ASAP! Just say when.
Old Aug 21, 2007 | 04:17 PM
  #147
boyetssilverfit's Avatar
my wallet is ready for that heat shield,
Old Aug 21, 2007 | 04:19 PM
  #148
MadtownFit's Avatar
Thanks again!
H-FIT team
Very nice!!
Old Aug 22, 2007 | 11:08 PM
  #149
Asym's Avatar
I installed my SSI before a trip I took to Chicago. My MPG dropped because of the way I was driving, speed limits are faster on average through Indiana and Illinois. I also got stuck in some parking lot like traffic, also I've been running at higher revs because the sound cracks me up.
I have the stock exhaust and was averaging around 35-37MPG before the SSI, but the AC has been on more due to the heat. I don't have an average but 1 tank was around 32 and the last one was 34.5. It would be better but lately I'm reving higher before I shift on my MT.
Old Aug 23, 2007 | 11:59 PM
  #150
Mud_Bone's Avatar
any #'s from the H-FIT crew on fuel economy? increase? decrease? same?
Old Aug 27, 2007 | 10:02 PM
  #151
ezduzit's Avatar
Received my SSI intake a couple of days ago. Shipping was extremely fast, maybe because I'm in California where they are manufactured, but it was very quick nevertheless.
The unit I was sent has been redesigned with a threaded insert molded into the chamber, so there is no hassle at all with trying to get your hand in there to thread a nut. The bolt just threads directly into the threaded insert and it couldn't be easier.
The installation went very quickly and it was easy. I decided to not remove the battery or disconnect it because I didn't want to hassle with having to reenter the radio code.
I did loosen one of the battery hold-downs and moved the battery as much as I could to facilitate the installation. This was a mistake.
When I fired up my Fit after installing the SSI, it just wasn't running right. It actually felt as if it had lost performance. I then disconnected my negative battery cable (as the SSI instructions advise) and after the ECU reset, things were much improved. In retrospect, I should have just followed the instructions.
The metal mouting bracket that secures the chamber to the engine had some tooling marks, so I buffed and polished it with some wheels on my bench grinder. I then painted it with a Krylon paint that looks like an anodiezed finish. It turned out looking really nice.
I notice an improvement in power at all rpm levels. I think my ECU is still learning the new parameters, so it may take a bit of driving for everything to sort itself out, but I am extremely happy with the improvement in drivability.
Soundwise, the SSI really does not make it's presence felt until about between 3500 and 4000 rpm. Then it begins to sound good.
Kudos to H-fit for their quick response to customer feedback and for an excellent product.
ed
Old Aug 27, 2007 | 11:57 PM
  #152
Smile
Hi again everyone,
We wanted to address some questions about gas mileage and our intake. In total honesty, we did not do any real long term testing on this aspect. We basically started working on prototypes of the SSI a couple of weeks after we attained our vehicle. I would have to say that we put a total of 500 miles at most on the stock vehicle. So needless to say we collected no data of the stock mileage for comparison.
However, we made it a point to keep all sensors in their factory location with respect to the throttle body. Therefore, we would believe that there would be little change in gas mileage from using our intake.
What we have found out through driving our FIT around with our SSI installed is that we just want to mash the gas and keep the rpms in the sweet zone between 3000-5000 all the time. We like the sound it makes
One great thing about not being a giant aftermarket company is that we can react exceptionally fast to customer feedback and improve upon our product in realtime. We thought that there would not be an issue with people fitting their hands into the intake hole to mount the bracket, but being that we saw that customers were having problems with this, we made a mid production change and implemented the rivet nut insert to address customer concerns. We believe that this improvement will simplify installation immensely.
Thanks again from the H-FIT team
Old Aug 28, 2007 | 01:48 AM
  #153
SPON FIT's Avatar
man,now thats customer service
Old Aug 28, 2007 | 05:03 AM
  #154
Mud_Bone's Avatar
H-FIT-James
thanks for getting back
now if I could find a way to free up the Moooo laaaa i'd be golden
this looks to be a good product. thanks again H-FIT
Old Aug 28, 2007 | 10:48 AM
  #155
dave brown's Avatar
I'm still waiting for the short shifter to be released -- it includes the hard mount bushings! ;-)
Old Aug 29, 2007 | 09:10 PM
  #156
Asym's Avatar
ditto, also the axleback.
Mine also came with the new rivet. I did the same initial install as ezduzit where I just moved the battery over and didn't disconnect it, I don't take direction well. Mine ran fine after the install so I never did the reset of the ECU by disconnectiong the battery.
As for MPG, I'm averaging around 34.5 from around 37MPG. This is my own fault though since the noticable boost from the SSI starts around 2500-3000 RPM. I used to stay under 2500RPM unless on the highway now I'm always around 3000RPM for the extra power. If I stayed under 2500RPM I'm sure the MPG difference would be minimal but my driving habits have changed which will affect the MPG.
Old Sep 6, 2007 | 02:23 PM
  #157
docjim2's Avatar
what about colour coded to the car; carbon fiber?! is it really necessary to disconnect the battery to 'reset' the car computer? Doesn't the computer 'learn' anyway?
Old Sep 8, 2007 | 04:47 AM
  #158
ezduzit's Avatar
Any updates on the availability of the heat shield/duct and the axle-back?
ed
Old Sep 8, 2007 | 08:23 AM
  #159
Jimmy101's Avatar
Thumbs up
Please make the heat shield, then your intake would be perfect!
Old Sep 12, 2007 | 11:14 PM
  #160
zer0sk8ordie's Avatar
i ordered my SSI yesterday!! cant wait for it to come in!
