KWSC Kit Release Ramblings
Old May 21, 2008 | 12:59 PM
  #281
eldaino's Avatar
Originally Posted by gotfitted
it does, but its also over 2800 lbs.
Yea, street racing's stupid. I was just kinda sad when Yeefit suggested the Fit wouldn't keep up with a RSX-S
i dont think they are terribly over 2800 lbs....the new si's even in sedan form are still only mid 2900's.
at any rate, don't be sad. you gotta remember that in a street race, people don't exactly announce what they have under the hood. even if the car was stock, rsx type s's run 0-60 in a little over six seconds.
the kwsc is great, but there is no way that its going to shave over 3 seconds off someones 0-60 time.
your suffering from a common misconception that if something as boost, it should be able to take anything. you know how many friends i have that are going to be like 'you are only making 130 to the wheels AFTER the supercharger?' telling someone you are boosted usually makes people anticiapte sick power, when it shouldn't. even then 130 the wheels is quite a feat compared to what we make stock.
don't worry man, the car will be fun enough for a DD.
come one guys i want some reviews!
Old May 21, 2008 | 01:03 PM
  #282
eldaino's Avatar
Originally Posted by Illusive
Car show this weekend and its raining all week Couple more tweaks and she will be running perfectly!
nice! keep us posted man!
Old May 21, 2008 | 01:06 PM
  #283
Illusive's Avatar
Will do! I have my "Powered By Kraftwerks" frame on mine
Old May 21, 2008 | 11:01 PM
  #284
eldaino's Avatar
ha ha! kudos to the mods for making this thread. I love how one of the tags is 'joy'.
Old May 22, 2008 | 12:34 AM
  #285
Masterdebater's Avatar
i want some vids when any of u guys are ready....
Old May 23, 2008 | 08:06 AM
  #286
kmdebit's Avatar
Will post some pics n vids in a few hrs...gotta go to work and get a safety brief and do some inspections first. Done around 12pm ET, I bet
Old May 23, 2008 | 08:10 AM
  #287
SickFit's Avatar
Awesome!
Old May 23, 2008 | 08:47 AM
  #288
GD3-Fit's Avatar
I <3 SPOON
vid vid vid vid vid vid vid vid vid vid vid vid vid vid vid
Old May 23, 2008 | 09:30 PM
  #289
i worked 11 hours today...i cant watch vids on our work computer anymore (lol) and i expected to come home, kick off my shoes and see a dam boost video...im very disappointed.
Old May 23, 2008 | 11:18 PM
  #290
eldaino's Avatar
it seems like some installs aren't going as smoothly as planned...hence why no vids!
but i'm sure everything will work out!
Old May 24, 2008 | 12:52 AM
  #291
Mr_ET's Avatar
vids will come guys just give it a few more days
Old May 24, 2008 | 01:34 AM
  #292
kmdebit's Avatar
kmdebit/2008-05-18 SC Install - Photobucket - Video and Image Hosting
I'm too darn lazy to actually post the vids up in hurr...they're uploading now, one at a time.
Did throw a few CEL's, but I think that's cuz my header isn't as high-flow as it ought to be. Only happened after the bigger injectors went in. I still have stock cat, and Oscar explained that I might not be getting enough flow. Props to him for calling so quickly after I emailed them (and even used the wrong email).
Will update and get more vids tomorrow after I work off the hangover.
Old May 24, 2008 | 12:47 PM
  #293
leonine's Avatar
Seems that the bigger injectors could be causing the problems. i also have the injector upgrade, header, and cat-delete. I was reading up on the p0172 code and it said one of the causes is leaking injectors. so i guess it is possible that putting in the injectors caused the problem.
If the code doesn't go away i am going to take it to my local performance shop and have them go over everything just to rule out the possibility that i did something wrong.
Old May 24, 2008 | 01:02 PM
  #294
xorbe's Avatar
So, if we change the header but not the cat pipe or cat back, should we not upgrade the injectors from 180cc to 205cc?
And how can I monitor the AF ratio myself? I didn't see anything like that in my ScanGauge manual.
Old May 24, 2008 | 01:09 PM
  #295
leonine's Avatar
Oscar says that if you put on a header or test pipe you must run the bigger injectors.
The A/F you will need a separate gauge. Get the AEM wideband UEGO. That is what i have. IMO i think it is imperative to monitor your A/F real time when boosting. Maybe not if you are going with the carb legal kit but once you start throwing bigger injectors to me it seems like a must.
Old May 24, 2008 | 01:34 PM
  #296
TOOL's Avatar
0-60 vid anyone? Or any vids?
Tyler
Old May 24, 2008 | 04:18 PM
  #297
kmdebit's Avatar
Couple more vids uploading as I type this...check it out.
Rolling acceleration vids shot from my friend's '08 Si.
0-60 vids and driveby vids later. Had a rough start today, unfortunately not because of alcohol. Will put more stuff up as I record it.
Requests anyone?
Old May 25, 2008 | 12:36 AM
  #298
eldaino's Avatar
nice! the passing vids from your friends si were the best.
Old May 25, 2008 | 06:27 PM
  #299
how bad did u woop ur buddies si :P lmao. it looks fun but i think ill wait altogether for the 10 pound kit. i also wanna see turbo kit vids!
Old May 25, 2008 | 06:59 PM
  #300
Mr_ET's Avatar
doesn't look like the Si is accelerating at all and my guess is if it was the Fit would be even with it after the SC install including a header, the injector upgrade and a test pipe.
